Home » Language IDEs » ServerTools (WTP) » [XSLT Tools] XML Catalog in xsl:include
[XSLT Tools] XML Catalog in xsl:include [message #228898] Fri, 13 March 2009 11:20 Go to next message
Does anyone know if it is possible to use XML Catalogs in XSL Tools to
transform an external xsl:include to a cached one?
I would like to be able to validate an xsl template that contains
references to external xsl templates. The references look like the one
below:
<xsl:include
href="http://www.interwoven.com/livesite/xsl/HTMLTemplates.xsl"/>
I use XSL Tools version 1.0M5. I've tried an OASIS catalog with the
following instructions:
<rewriteURI uriStartString="http://www.interwoven.com/"
rewritePrefix="./"/>
<rewriteSystem systemIdStartString="http://www.interwoven.com/"
But the XSLT Project doesn’t seem to pick that up (I’ve added the catalog
to the XML catalog preferences panel).
I hope that this would be possible, because xalan transformation engine is
able to read oasis catalogs out of the box.
If that isn’t implemented can anyone point me to place where I should
start to read how can i contribute to the project? I’m pretty new to the
Eclipse community
Piotr Czapla
Re: [XSLT Tools] XML Catalog in xsl:include [message #228932 is a reply to message #228898] Fri, 13 March 2009 19:02 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Currently it doesn't look at the XML Catalog, but it is a good idea. We
would just need to setup the appropriate resolver to pass to Xalan, and
also have the XSL Tools editor be aware when navigating in includes and
imports.
As for how to contribute, this page should help get you going.
http://wiki.eclipse.org/XSLT_Project
Dave
Piotr Czapla wrote:
> below:
> <xsl:include
> But the XSLT Project doesn�t seem to pick that up (I�ve added the
> catalog to the XML catalog preferences panel).
> is able to read oasis catalogs out of the box.
> If that isn�t implemented can anyone point me to place where I should
> start to read how can i contribute to the project? I�m pretty new to the
> Eclipse community
> Piotr Czapla
Re: [XSLT Tools] XML Catalog in xsl:include [message #228940 is a reply to message #228898] Fri, 13 March 2009 19:07 Go to previous message
Forgot to mention that I opened bug 268622 for this request.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268622
You might also be interested in the OASIS XML Catalog 1.1 support that
is being worked on as well:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=112284
Dave
Piotr Czapla wrote:
> below:
> <xsl:include
> Eclipse community
> Piotr Czapla
Previous Topic:Latest Stable Build Required (M5 preferred)
Next Topic:marker & squiggle creation problem after XML validation
Current Time: Wed May 07 15:52:44 EDT 2025
Powered by FUDForum. Page generated in 0.04698 seconds
