[How To] Assign sources to variables JRE_SRC and JRE_SRC_ROOT? [message #22345] |
Wed, 14 May 2003 07:03 |
------=_NextPart_000_0008_01C31A19.35369520
Content-Type: text/plain;
charset="iso-8859-1"
During setup of a new JVM (im my case JDK 1.3.1), I select the =
corresponding root directory of the JDK, the Javadoc URL directory and =
check 'use default user libaries'. After this everything is working fine =
with the exception of the two Classpath variables JRE_SRC and =
JRE_SRC_ROOT, they are empty even if the sources are available in the =
<JDK_HOME>/src. Is this a known problem or do I something wrong?
Thank's for any help in advance - Ren=E9 Sigi
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1170" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>During setup of a new JVM (im my case =
JDK 1.3.1), I=20
select the corresponding root directory of the JDK, the Javadoc URL =
directory=20
and check 'use default user libaries'. After this everything is working =
fine=20
with the exception of the two Classpath variables JRE_SRC =
and=20
JRE_SRC_ROOT, they are empty even if the sources are available in the=20
<JDK_HOME>/src. Is this a known problem or do I something=20
wrong?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Thank's for any help in advance - =
Ren=E9=20
Sigi</FONT></DIV></BODY></HTML>
------=_NextPart_000_0008_01C31A19.35369520--
FUDForum. Page generated in 0.53419 seconds
