Home » Eclipse Projects » Eclipse Platform » Stuck again - ProgressMonitorDialog this time
Stuck again - ProgressMonitorDialog this time [message #22342] Tue, 29 April 2003 10:40 Go to next message
I have the following code...
try
IRunnableWithProgress op = new MyActionDelegate(String);
ProgressMonitorDialog progDiag = new ProgressMonitorDialog(shell);
progDiag.run(true, false, op);
catch (InvocationTargetException e)
// blah blah
catch (InterruptedException e)
// blah blah
But i just cannot get the dialog to disappear - I've tried setting the
dialog to hte same thread (awful performance,
so do not want to do that anyway) and then using progDiag.close(); - i'm
setting the IProgressMonitor in
MyActionDelegate.run() method to "done()". Can someone please post some
example code that they know
works - all I am after is to regain control of eclipse as I can't make my
dialog close!!
Kind regards (learning eclipse slowly...)
Matt Hawkins
Re: Stuck again - ProgressMonitorDialog this time [message #22461 is a reply to message #22342] Tue, 29 April 2003 11:21 Go to previous messageGo to next message
You're doing the right things.
Is your thread that creates the ProgressMonitor dialog maybe already
running within another ProgressMonitor dialog? Because in that case it
won't put up another dialog.
Other than that, bring up in debug mode, and put a breakpoint in your
code where you are done, and make sure that your runnable returns and
that it goes through ModelContextThread.run() on return and eventually
sets "continueEventDispatching" variable to false.
Then break into the main thread and see that it is waiting within
ModalContextThread.block().
Re: Stuck again - ProgressMonitorDialog this time [message #22636 is a reply to message #22461] Tue, 29 April 2003 11:54 Go to previous message
Well I think i've sorted it out - there was some deadlock.
If there is anyone who works for IBM, and specifically works on a websphere
component,
then can someone point me at the right place to look for getting a list of
all jar dependencies
out of the component.xml file?
I work for IBM and have already written a wsbld task - trouble is I want to
write the same kind of thing
to work in wsadie/eclipse.
If you could email any kind of info to hawkini_uk@uk.ibm.com.
Cheers!
"Richard L. Kulp" <richkulp@us.ibm.com> wrote in message
news:b8m5c0$7bq$1@rogue.oti.com...
Previous Topic:widget disposed error during save action
Next Topic:Looking for advice on plugin 'library' projects
Current Time: Mon Jul 21 20:58:34 EDT 2025
Powered by FUDForum. Page generated in 0.04109 seconds
