Home » Archived » DSDP - Mobile Tools for Java (MTJ) » How to add a jar file to the Midlet in MTJ?
How to add a jar file to the Midlet in MTJ? [message #22335] Fri, 14 November 2008 08:39 Go to next message
I am using MTJ and WTK 2.5.2. I have problems adding a jar file to my
midlet suite. I add the jar file to the res folder and I add it to the
build path. However, when I run the midlet it throws a
NoClassDefFoundError.
I have tried also exporting the jar file in the Build Path by checking the
jar file in the order and export option. But then, Eclipse shows errors on
my jar file and in the Problems window I get the following message:
Error preverifying class net.jxta.impl.endpoint.tcp.TcpConnection
jxta-cldc.jar FirstJXTAMidlet/res
Do you know how can I solve this problem?
Thanks in advance,
Fran
Re: How to add a jar file to the Midlet in MTJ? [message #22359 is a reply to message #22335] Fri, 14 November 2008 12:03 Go to previous messageGo to next message
hi fran,
the jar file doesn't need to be in the res folder, but you need to add it
to the project build path (Project properties->java build path->Libraries)
after that, you have to mark the jar as exported (Project
properties->java build path->Order and Export).
when you do that, MTJ build will automatically preverify the classes
inside the jar file and include them in the final midlet suite jar.
we are working to make this more "user friendly" :)
if you have issues, please let us know
gep
Francisco wrote:
> Hello,
> Thanks in advance,
> Fran
Re: How to add a jar file to the Midlet in MTJ? [message #22488 is a reply to message #22359] Fri, 14 November 2008 12:51 Go to previous messageGo to next message
Thanks Gustavo,
But that is what I have tried, but when eclipse preverifies the jar file,
it shows errors on it and the following problem:
jxta-cldc.jar
If I don't export it, the error disappear. I have tested the same midlet
using netbeans and importing the jar file and everything works.
I am using the lastest nightly builds, don't know if the problem could be
that...
Do you have any solution?
Fran
Re: How to add a jar file to the Midlet in MTJ? [message #22531 is a reply to message #22488] Fri, 14 November 2008 14:11 Go to previous messageGo to next message
i'm going to try it here to see if i find any issue with mtj. based on the
error, i assume you are trying the jxta-cldc.jar.
gustavo
Francisco wrote:
> Thanks Gustavo,
> jxta-cldc.jar
> that...
> Fran
Re: How to add a jar file to the Midlet in MTJ? [message #22573 is a reply to message #22531] Fri, 14 November 2008 14:42 Go to previous messageGo to next message
hi,
i just did the test here on the official 0.9 and also on the nightly build
and both of them worked ok.
i downloaded version 2.1.3 (jxme-2.1.3-bin.zip) and used the jxta-cldc.jar
file that is on the dist folder.
i strange aspect was that the file that you mentioned that caused the
error (net.jxta.impl.endpoint.tcp.TcpConnection) is not on the
jxta-cldc.jar that i downloaded. can you tell me which jxta version are
you using and where you downloaded it? i want to try the same version
thanks
gustavo
> gustavo
> Francisco wrote:
>> Thanks Gustavo,
>> jxta-cldc.jar
>> that...
>> Regards,
>> Fran
Re: How to add a jar file to the Midlet in MTJ? [message #22617 is a reply to message #22573] Fri, 14 November 2008 15:41 Go to previous messageGo to next message
Hello Gustavo,
Can you send me an email to my gmail account and I will send you the jar
file?
franmlsr at ...
Fran
Re: How to add a jar file to the Midlet in MTJ? [message #22659 is a reply to message #22617] Sat, 15 November 2008 19:00 Go to previous message
just did it. hope it works. and if it still doesn't work, please let me
know
gustavo
Francisco wrote:
> Hello Gustavo,
> file?
> franmlsr at ...
> Fran
Re: How to add a jar file to the Midlet in MTJ? [message #567874 is a reply to message #22335] Fri, 14 November 2008 12:03 Go to previous message
hi fran,
gep
Francisco wrote:
> Hello,
> Thanks in advance,
> Fran
Re: How to add a jar file to the Midlet in MTJ? [message #567926 is a reply to message #22359] Fri, 14 November 2008 12:51 Go to previous message
Thanks Gustavo,
jxta-cldc.jar
that...
Fran
Re: How to add a jar file to the Midlet in MTJ? [message #567957 is a reply to message #22488] Fri, 14 November 2008 14:11 Go to previous message
gustavo
Francisco wrote:
> Thanks Gustavo,
> jxta-cldc.jar
> that...
> Fran
Re: How to add a jar file to the Midlet in MTJ? [message #567982 is a reply to message #22531] Fri, 14 November 2008 14:42 Go to previous message
hi,
thanks
gustavo
> gustavo
> Francisco wrote:
>> Thanks Gustavo,
>> jxta-cldc.jar
>> that...
>> Regards,
>> Fran
Re: How to add a jar file to the Midlet in MTJ? [message #568010 is a reply to message #22573] Fri, 14 November 2008 15:41 Go to previous message
Hello Gustavo,
file?
franmlsr at ...
Fran
Re: How to add a jar file to the Midlet in MTJ? [message #568033 is a reply to message #22617] Sat, 15 November 2008 19:00 Go to previous message
know
gustavo
Francisco wrote:
> Hello Gustavo,
> file?
> franmlsr at ...
> Fran
Previous Topic:Help: WTK2.5.2 + MTJ 0.9 + Eclipse 3.4.1 + JRE6_10
Next Topic:Type java.lang.String Error preverifying class java.lang.String
Current Time: Tue Jul 22 07:27:36 EDT 2025
Powered by FUDForum. Page generated in 0.25518 seconds
