Home » Eclipse Projects » JFace » Section gets larger when expand
Section gets larger when expand [message #22326] Tue, 21 July 2009 09:08 Go to next message
Hey all,
i have a problem using a Section from org.eclipse.ui.forms. I have a
Composite (with GridLayout) and put a Section on this Composite. If i
expand or collapse the section the composite gets a little bit larger. I
think layout() will be called and then the width will be calculated again.
Does anybody know why the new width is larger than the old ones?
Any advice?
Thanks alot
Thomas
Re: Section gets larger when expand [message #22990 is a reply to message #22326] Wed, 22 July 2009 15:53 Go to previous message
What's in the Section? If it's a table you might be seeing this bug
http://bugs.eclipse.org/215997
"T. Wilhelm" <t.wilhelm@msh.de> wrote in message
news:0b6312e64ed17cb0ad69626e4a88f9ac$1@www.eclipse.org...
> Hey all,
> Does anybody know why the new width is larger than the old ones? Any
> advice?
> Thanks alot
> Thomas
Previous Topic:DialogCellEditor and Navigation
Next Topic:Bind TableViewer to Multiple Objects?
Current Time: Mon Jul 21 21:01:31 EDT 2025
Powered by FUDForum. Page generated in 0.12695 seconds
