ATL refining mode [message #22264] |
Thu, 08 March 2007 07:21  |
Originally posted by: kehrer.hdm-stuttgart.de
what about the posting on http://wiki.eclipse.org/index.php/ATL_2006:
"ATL 2006 is the name of a new version of ATL [...]
The current version does not support refining mode yet. If you need to use
refining mode, then use ATL 2004 (see remarks section below). "
Is it true that the current version (I'm using the HEAD version of the CVS
repository) of the ATL Compiler doesn't support refining mode?
Thanks in advance,
Timo Kehrer
Re: ATL refining mode [message #29515 is a reply to message #22264] |
Wed, 04 April 2007 11:41  |
Yes, the current version of ATL 2006 does not support refining mode yet.
Because you can specify which compiler to use for each transformation,
you can use ATL 2006 when you do not need refining mode, and ATL 2004
otherwise.
Frédéric Jouault
Timo Kehrer wrote:
> Hello,
> Thanks in advance,
> Timo Kehrer
FUDForum. Page generated in 0.06012 seconds
