Re: [buckminster-dev] Plugin dependencies and cspex file [message #22253] |
Mon, 21 July 2008 10:51 |
Originally posted by: jcampolongo.cra.com
------_=_NextPart_001_01C8EB41.334CC19E
Content-Type: text/plain;
charset="US-ASCII"
> Exactly what do you mean with "dependency isn't built"?
=20
What I mean is that, when I go to 'Invoke Action-->bundle.jars' to build
the project bundle, only the one bundle is built, not all of its
dependent bundles. If my dependency is explicit in the manifest.mf,
then all of those bundles are also built (and placed in my
<home>/temp/buckminster folder). =20
=20
So, I'm seeing two different behaviors. If I put a dependency in the
manifest.mf file and call 'Invoke Action-->bundle.jars', my main project
and its dependency is built and placed in my <home>/temp/bunkminster
folder. If I put a dependency in the buckminster.cspex file (and have
it show up under 'View CSpec' as a dependency, just like if it were part
of the manifest.mf), only the main project is built, not the dependency
(even though in both cases the 'View CSpec' file looks exactly the same,
although I might have missed something there).
=20
Joseph Campolongo
=20
=20
=20
=20
THIS MESSAGE IS INTENDED FOR THE USE OF THE PERSON TO WHOM IT IS =
ADDRESSED. IT MAY CONTAIN INFORMATION THAT IS PRIVILEGED, CONFIDENTIAL =
AND EXEMPT FROM DISCLOSURE UNDER APPLICABLE LAW. If you are not the =
intended recipient, your use of this message for any purpose is strictly =
prohibited. If you have received this communication in error, please =
delete the message and notify the sender so that we may correct our =
records.
Content-Type: text/html;
charset="US-ASCII"
<HTML >
<HEAD>
<META http-equiv=3D"Content-Type" content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
pre
{margin:0in;
font-size:10.0pt;
font-family:"Courier New";}
span.EmailStyle17
{mso-style-type:personal-compose;
font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</HEAD>
<BODY lang=3DEN-US link=3Dblue vlink=3Dpurple>
<DIV>
<DIV>
<div class=3DSection1><pre><font size=3D2 face=3D"Courier New"><span
style=3D'font-size:10.0pt'>> Exactly what do you mean with =
"dependency isn't built"?<o:p></o:p></span></font></pre>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'><o:p> </o:p></span></font></p >
font-family:Arial'>What I mean is that, when I go to ‘Invoke =
Action-->bundle.jars’
to build the project bundle, only the one bundle is built, not all of =
its
dependent bundles. If my dependency is explicit in the =
manifest.mf, then all
of those bundles are also built (and placed in my =
folder). <o:p></o:p></span></font></p>
font-family:Arial'>So, I’m seeing two different behaviors. =
If I put a
dependency in the manifest.mf file and call ‘Invoke =
Action-->bundle.jars’,
my main project and its dependency is built and placed in my
<home>/temp/bunkminster folder. If I put a dependency in the =
buckminster.cspex
file (and have it show up under ‘View CSpec’ as a =
dependency, just
like if it were part of the manifest.mf), only the main project is =
built, not
the dependency (even though in both cases the ‘View CSpec’ =
file
looks exactly the same, although I might have missed something =
there).<o:p></o:p></span></font></p>
font-family:Arial'>Joseph Campolongo</span></font><o:p></o:p></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV STYLE=3D"FONT-SIZE: 9pt; FONT-FAMILY: Courier New">
<FONT FACE=3D"Arial" SIZE=3D"1">THIS MESSAGE IS INTENDED FOR THE USE OF =
THE PERSON TO WHOM IT IS ADDRESSED. IT MAY CONTAIN INFORMATION THAT IS =
PRIVILEGED, CONFIDENTIAL AND EXEMPT FROM DISCLOSURE UNDER APPLICABLE =
LAW. If you are not the intended recipient, your use of this message for =
any purpose is strictly prohibited. If you have received this =
communication in error, please delete the message and notify the sender =
so that we may correct our records.</FONT>
</DIV>
<DIV STYLE=3D"FONT-SIZE: 9pt; FONT-FAMILY: Courier New"> </DIV>
<DIV STYLE=3D"FONT-SIZE: 9pt; FONT-FAMILY: Courier New"></DIV>
</DIV></BODY></HTML>
------_=_NextPart_001_01C8EB41.334CC19E--
FUDForum. Page generated in 0.02577 seconds
