Home » Eclipse Projects » DTP » SAAJ in Birt ODA
SAAJ in Birt ODA [message #22177] Thu, 19 October 2006 09:52 Go to next message
Originally posted by: dyashaev.yahoo.com
I'm using Eclipse 3.2 and Birt 2.1.0
I've created a Birt ODA plugin retrieving data from Web Service.
My plugin uses SAAJ (saaj-api.jar & saaj-impl.jar - both specified in
plugin classpath). There's no problem to create DataSource and DataSet. I
even see DataSet Preview tab with the data properly.
The problem starts when I try to preview a report that uses that dataset
(report just displayes couple of columns from the data set using Table).
I'm testing my plugin by calling Run -> Eclipse Application. The new
Eclipse instance is created and there I create a report with my Data
Source and DataSet. When previewing the report, at 1st
I was getting next exception right in the viewer:
javax.servlet.ServletException: Error instantiating servlet class
org.eclipse.birt.report.servlet.ViewerServlet
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:912)
root cause
java.lang.NoClassDefFoundError: javax/xml/soap/SOAPException
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 28)
at java.lang.Class.getConstructor0(Class.java:2640)
at java.lang.Class.newInstance0(Class.java:321)
at java.lang.Class.newInstance(Class.java:303)
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:903)
I've figured out that somehow viewer plugin can not find the saaj jars
from my WebService Oda plugin (is it supposed to be like that?)
So I've added these 2 jars (saaj-api.jar, saaj-impl.jar) to the viewer
plugin lib directory:
eclipse\plugins\org.eclipse.birt.report.viewer_2.1.0.N200606 28-1351\birt\WEB-INF\lib
This time the viewer didn't show exception, I could see column names in
report - but no data.
And, console in my initial Eclipse instance displayed next exception:
[Note: Package org.eclipse.datatools.connectivity.oda.mdx.xmla - is my oda
package.
The XMLAHandler is main class handling SOAP connection to Microsoft
Analysis Service via XMLA WebService.
The line of code - XMLAHandler.init(XMLAHandler.java:112) - that causes a
problem:
SOAPConnectionFactory scf = SOAPConnectionFactory.newInstance();]
INFO: The ODA driver plugin.xml has no valid <dataSet> element defined in
the data source extension (org.eclipse.birt.data.oda.adapter.dtp).
javax.xml.soap.SOAPException: Unable to create SOAP connection factory:
com.sun.xml.messaging.saaj.client.p2p.HttpSOAPConnectionFact ory
at javax.xml.soap.SOAPConnectionFactory.newInstance(Unknown Source)
org.eclipse.datatools.connectivity.oda.mdx.xmla.io.XMLAHandl er.init(XMLAHandler.java:112)
org.eclipse.datatools.connectivity.oda.mdx.xmla.io.XMLAHandl er. <init>(XMLAHandler.java:75)
org.eclipse.datatools.connectivity.oda.mdx.xmla.Connection.o pen(Connection.java:82)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.open(OdaConnection.java:235)
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:124)
org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:120)
org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:108)
org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource(DataSourceRuntime.java:206)
org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour ce(QueryExecutor.java:261)
org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:210)
org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:366)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:139)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:122)
org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:121)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:208)
org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1541)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:62)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:74)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:35)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:123)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:81)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:80)
org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:135)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:226)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:128)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:113)
at org.eclipse.birt.report.service.ReportEngineService.runRepor t(Unknown
Source)
org.eclipse.birt.report.service.BirtViewerReportService.runR eport(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.BirtRunReportA ctionHandler.__execute(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.BirtGetPageAct ionHandler.__checkDocumentExists(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.prepareParameters(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(Unknown
Source)
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(Unknown
Source)
org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(Unknown
Source)
org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:595)
org.eclipse.datatools.connectivity.oda.mdx.xmla.model.OlapEx ception:
org.eclipse.datatools.connectivity.oda.mdx.xmla.io.XMLAHandl er.init(XMLAHandler.java:147)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Caused by: javax.xml.soap.SOAPException: Unable to create SOAP connection
factory: com.sun.xml.messaging.saaj.client.p2p.HttpSOAPConnectionFact ory
... 90 more
Does anyone have an idea of the reason and of how can I approach this
problem?
Thanks.
Re: SAAJ in Birt ODA [message #22223 is a reply to message #22177] Thu, 19 October 2006 10:55 Go to previous message
Hm, I found the solution.
The preview started to work after I've set the setThreadContextClassLoader
of the DataSource (in plugin.xml - extensions section) to true. It forces
the customer thread context classlader to be set to a classloader used to
load this plugin. Works like a charm! I still have to keep these 2 saaj
jars in viewer plugin though - doesn't work otherwise.
Re: SAAJ in Birt ODA [message #582664 is a reply to message #22177] Thu, 19 October 2006 10:55 Go to previous message
Previous Topic:SAAJ in Birt ODA
Next Topic:How to add a jdbc driver that uses native code?
Current Time: Tue Jul 22 13:06:00 EDT 2025
Powered by FUDForum. Page generated in 0.04926 seconds
