Home » Eclipse Projects » Eclipse Platform » Extern Tool Builder and Ant
Extern Tool Builder and Ant [message #227300] Mon, 12 April 2004 21:27 Go to next message
Originally posted by: danc.us.ibm.com
I have a need to use an Ant buildfile to run a conversion process on a
non-java file prior to building my project. I found the topic "Creating a
project Ant buildfile" in the online docs and looks like it will work for
me and I have a few questions and a problem that I encountered. I'm
running WSAD 5.0.1 and the online doc matchs the Eclipse doc.
First the questions.
Q1: Where do I find detailed documentation on this capability??
Q2: On the Properties page, Main tab, for the New_Builder, what is the
Arguments window for and how do I use it??
Q3: What are the entries on the Properties tab used for??
Now for my problem. I have an Ant build file that works from a DOS
command line. The Ant build file reads in a properties file (via Ant
<property file=... >) and a commonTargets.xml file via normal XML include
method. When I create an External Tools Builder 'Ant build', I set things
up according to the online instructions mentioned above. I point to the
buildfile that I run from the command line on the main page, and on the
Targets tab, I select the target that I want. When it runs within WSAD,
the Ant target in the main build file correctly invokes the target in the
commonTargets.xml file, BUT I get an error which indicates that the
content of the properties file, which was read, is not being propagated to
the commonTarget.xml processing. In other words:
build.xml:
reads property file
includes commonTargets.xml
performs some property setup
calls target in commonTargets.xml
commonTargets.xml
attempts to run the conversion processing
error indicating a property is not set (in properties file that was read).
Any ideas??
Dan Carissimo
Re: Extern Tool Builder and Ant [message #227327 is a reply to message #227300] Tue, 13 April 2004 00:09 Go to previous messageGo to next message
"Dan Carissimo" <danc@us.ibm.com> wrote in message
news:c5ffme$m0q$1@eclipse.org...
There really is not any besides the Eclipse help. I am another resource
available to you :-)
This can be used for passing options to Ant just like at the commandline
For example you could use -DpropertyName=propertyValue as an entry in the
Arguments text pane.
The most common use is for setting the message output level using -debug
or -verbose
Almost any command listed as valid for Ant from the commandline should be
accepted from the arguments text pane.
-find is the only example off the top of my head that I know does not work.
This is just another UI way of setting properties. It is an alternative to
using -D<property>=<value> or
-propertyfile <name> in the Arguments tab as outlined above.
> build.xml:
> reads property file
> commonTargets.xml
read).
Are you sure that the <property file=...> is actually reading in the
property file?
Doing a simple echo or a property from the file in the build.xml produces
the correct result?
When you run Ant within Eclipse 2.1.* it runs in the same VM as Eclipse and
the working directory for the Java process is often not what the user
expects for Ant builds.
HTH
Darins
Re: Extern Tool Builder and Ant [message #227794 is a reply to message #227327] Tue, 13 April 2004 11:48 Go to previous message
Darin,
thanks for the answers. I put a -verbose into the Agruments section of
the Main tab, and saw that when WSAD invoked my Ant script, he put a
-Dbasedir=..... setting on the command line. It was being set to the
value that I put into the Base Directory. When I removed the Base
Directory setting, the Ant script worked just fine!!
Thanks again!!
Dan
> or -verbose
> > build.xml:
> > reads property file
> > commonTargets.xml
> read).
> property file?
> the correct result?
> HTH
> Darins
Previous Topic:Starting Ant in *new* VM / Eclipse 2.1
Next Topic:"End"- and "Pos 1"-Keys on numpad not working
Current Time: Sun Aug 31 21:14:54 EDT 2025
Powered by FUDForum. Page generated in 0.04559 seconds
