Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Problems running MTJ and the new J2ME SDK 3.0
Problems running MTJ and the new J2ME SDK 3.0 [message #22145] Sat, 08 November 2008 05:34 Go to next message
I am new in the J2ME world. I have installed the MTJ into eclipse and I
have downloaded the new J2ME SDK 3.0 from Sun's webpage.
I have followed the tutorial from http://live.eclipse.org/node/614 in
order to create a simple Hello World midlet. However, I am not able to run
the middlet because it seems that the command line arguments used by MTJ
are not correct. This is the output I get when I start the middlet:
Syntax:
emulator [arguments]
Arguments are:
-version Display version information about the emulator
-help Display list of valid arguments
-Xdebug Use a remote debugger
-Xrunjdwp:[transport=<transport>,address=<address>,server= <y/n>
suspend=<y/n>]
Debugging options
-Xdevice:<device> Select a device skin for the emulator
-Xdomain:<domain_name>
Set the MIDlet suite's security domain
-Xautotest:<JAD file url>
Run in autotest mode
-Xdescriptor:<JAD file name>
The JAD file to be executed
-Xjam[:install=<JAD file url> | force | list | storageNames |
run=[<storage name> | <storage number>] |
remove=[<storage name> | <storage number> | all]]
Java Application Manager and support
for Over The Air provisioning (OTA)
-Xquery Print device information
Is there not support yet in MJT for this SDK? How can I fix the problem?
Thanks a lot in advance!
Fran
Re: Problems running MTJ and the new J2ME SDK 3.0 [message #22188 is a reply to message #22145] Sun, 09 November 2008 14:03 Go to previous message
Hi Francisco,
we have already identified this issue with the new J2ME SDK 3.0 from Sun
and fixed this issue in the 0.9.1 nightly builds.
If you are using the 0.9 release version of MTJ and don't want to use the
0.9.1 NB releases, here is what you could do:
1 - Select the "Window > Preferences..." to open the workbench
preferences.
2 - Select the "Java ME > Device Management" preference page to display
the installed SDKs.
3 - On each device form the J2ME SDK 3.0 select the "Edit..." button and
update the "Launch Command Template" to the following:
%executable% [%debugPort%|-Xdebug
-Xrunjdwp:transport=dt_socket,suspend=y,server=y,address=%de bugPort%]
[%classpath%|-classpath "%classpath%"] -Xdevice:%device%
[%jadfile%|"-Xdescriptor:%jadfile%"] [%verbose%|-Xverbose:%verbose%]
[%heapsize%|-Xheapsize:%heapsize%]
[%securityDomain%|-Xdomain:%securityDomain%] %userSpecifiedArguments%
[%otaurl%|-Xjam:transient=%otaurl%]
That should fix the problem.
Re: Problems running MTJ and the new J2ME SDK 3.0 [message #567702 is a reply to message #22145] Sun, 09 November 2008 14:03 Go to previous message
Hi Francisco,
preferences.
the installed SDKs.
Previous Topic:Problems running MTJ and the new J2ME SDK 3.0
Next Topic:preverification of non-class files
Current Time: Fri Jun 06 11:03:28 EDT 2025
Powered by FUDForum. Page generated in 0.02845 seconds
