Home » Eclipse Projects » Eclipse Platform » FileSelectionDialog deprecated
FileSelectionDialog deprecated [message #227125] Mon, 12 April 2004 16:03 Go to next message
I would like to use the FileSelectionDialog, but the java doc suggests
using FileDialog instead, because FileSelectionDialog is deprecated.
FileDialog allows users to select outside the workspace, which I want to
prevent. I have looked at ResourceListSelectionDialog but i can't figure
out how to have the pattern matching preset so that the user doesn't have
to fill anything out.
Does anyone have any suggestions? Which class are you guys using now that
FileSelectionDialog is deprecated? Or how can I get a better usage of
ResourceListSelectionDialog or one its siblings.
Thanks, Bob
Re: FileSelectionDialog deprecated [message #227171 is a reply to message #227125] Mon, 12 April 2004 18:08 Go to previous messageGo to next message
Try this code snippet
ILabelProvider lp= new WorkbenchLabelProvider();
ITreeContentProvider cp= new WorkbenchContentProvider();
ElementTreeSelectionDialog dialog= new
ElementTreeSelectionDialog(getShell(),
lp, cp);
dialog.setValidator(null);
dialog.setAllowMultiple(false);
dialog.setTitle("XXXXXXX"); //$NON-NLS-1$
dialog.setMessage("YYYYYYYYYYYYY"); //$NON-NLS-1$
//dialog.addFilter(filter);
dialog.setInput(ResourcesPlugin.getWorkspace().getRoot());
dialog.setSorter(new ResourceSorter(ResourceSorter.NAME));
if (dialog.open() == ElementTreeSelectionDialog.OK) {
Object[] elements= dialog.getResult();
if (elements.length == 1) {
String file =
((IResource)elements[0]).getLocation().toOSString();
Bob Donovan wrote:
>Hi,
>Thanks, Bob
Genady Beryozkin
http://www.genady.net/
Re: FileSelectionDialog deprecated [message #227628 is a reply to message #227171] Tue, 13 April 2004 10:08 Go to previous message
Thanks.
I took what you have an augmented it and it works really well.
Bob
> lp, cp);
> String file =
> Bob Donovan wrote:
> >Hi,
> >Thanks, Bob
Previous Topic:Integrate a plug-in using Swing
Next Topic:need help for using decorators.
Current Time: Sat Jul 26 14:10:32 EDT 2025
Powered by FUDForum. Page generated in 0.04037 seconds
