Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Plugin dependencies and cspex file
Re: [buckminster-dev] Plugin dependencies and cspex file [message #22123] Mon, 21 July 2008 10:14 Go to next message
Joseph Campolongo wrote:
> > Hi Joseph,
> > Do you put this in a file called buckminster.cspex (note the 'x' at the
> > end) in the project root?
> > If you right-click on the project and do "Buckminster" - "View
> > CSpec...", can you see the dependency there?
> Yes and Yes, which is why I find it so strange that the dependency
> isn’t built. I’m using the following versions:
Exactly what do you mean with "dependency isn't built"?
- thomas
Re: [buckminster-dev] Plugin dependencies and cspex file [message #22166 is a reply to message #22123] Mon, 21 July 2008 10:22 Go to previous message
I tested to add you buckminster.cspex file and then re-resolve. I
immediately get the following error:
ERROR [0002] : No suitable provider for component
OSGi_Project:osgi.bundle/1.0.0#OSGi was found in searchPath default
which is what I would expect.
- thomas
>> > Hi Joseph,
> - thomas
Previous Topic:Re: Re: [buckminster-dev] Plugin dependencies and cspex file
Next Topic:Re: [buckminster-dev] Plugin dependencies and cspex file
Current Time: Thu May 08 03:53:37 EDT 2025
Powered by FUDForum. Page generated in 0.27487 seconds
