problem installing Visual Editor. [message #22109] |
Wed, 03 March 2004 11:05  |
Originally posted by: ramanr.adventnet.com
Hi All,
I'm a newbie to Eclipse IDE. I tried installing the VisualEditor
plugin but I failed .
Later I found some problem in the .log file present under
workspace\.metadata directory.
!SESSION Mar 02, 2004 20:15:31.364
java.version=1.4.2_03
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/Eclipse/
!ENTRY org.eclipse.core.runtime 2 1 Mar 02, 2004 20:15:31.364
!MESSAGE Problems encountered loading the plug-in registry.
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Mar 02, 2004 20:15:31.364
!MESSAGE Unable to satisfy prerequisite constraint from
"com.ibm.etools.emf.ecore.utilities" to "org.eclipse.emf.ecore.xmi".
!MESSAGE Plug-in "com.ibm.etools.emf.workbench" was disabled due to
missing or disabled prerequisite plug-in
"com.ibm.etools.emf.ecore.utilities".
!MESSAGE Plug-in "org.eclipse.jem.workbench" was disabled due to
missing or disabled prerequisite plug-in "com.ibm.etools.emf.workbench".
!MESSAGE Plug-in "org.eclipse.jem.beaninfo" was disabled due to
missing or disabled prerequisite plug-in "org.eclipse.jem.workbench".
!MESSAGE Plug-in "org.eclipse.jem.beaninfo.ui" was disabled due to
missing or disabled prerequisite plug-in "org.eclipse.jem.beaninfo".
!MESSAGE Plug-in "org.eclipse.ve.cde" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.gef".
!MESSAGE Plug-in "org.eclipse.ve.java.core" was disabled due to
missing or disabled prerequisite plug-in "org.eclipse.ve.cde".
!MESSAGE Plug-in "org.eclipse.ve.jfc" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.ve.java.core".
!MESSAGE Unknown extension point
"org.eclipse.jem.beaninfo.overrides" specified in plug-in
"org.eclipse.jem".
Can anyone help to set things straight?
regards,
rajaraman.s
Re: problem installing Visual Editor. [message #22155 is a reply to message #22109] |
Wed, 03 March 2004 11:15  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
It doesn't sound like you have the correct set of plugins.
com.ibm.etools.emf.ecore.utilities doesn't even exist in the open source
eclipse or VE. You are not trying to put this over top of WSAD are you?
That won't work. It only works on top of Eclipse.
You need to use the correct set of prereqs for each driver. They are
listed on the build page for each VE driver. It says what level of
Eclipse, GEF, and EMF you need for the driver of VE. It currently does
not work on other levels.
Thanks, Rich Kulp
Re: problem installing Visual Editor. [message #583229 is a reply to message #22109] |
Thanks, Rich Kulp
FUDForum. Page generated in 0.04276 seconds
