OCL and Query interdependency [message #22106] |
Tue, 14 February 2006 01:59  |
I've noticed that OCL SDK and Query SDK features are mutualy dependents.
Eclipse Modeling Framework Technology OCL Examples (1.0.0) requires
plug-in "org.eclipse.emf.query.ocl".
Eclipse Modeling Framework Technology Query OCL (1.0.0) requires plug-in
"org.eclipse.emf.ocl".
This avoids me to enable them via the configuration manager.
Didier.
Re: OCL and Query interdependency [message #22987 is a reply to message #22900] |
Thu, 16 February 2006 09:20   |
Hello, Didier.
I agree: the examples need to be separated. It will take some work,
though, so I'm not sure when we will be able to do it. I have raised
https://bugs.eclipse.org/bugs/show_bug.cgi?id=128199 to track this problem.
Christian
Ptitjes wrote:
> Hello Christian,
> In fact, there is no problem at the sub-feature level. And deleting the
> main SDK features solves the problem (but forces to enable each
> individual feature one by one as the eclipse configuration manager can't
> enable multiple-selected features !!!!)
> So as
> oe.emf.ocl.examples depends on oe.emf.query.ocl and
> oe.emf.query.ocl depends on oe.emf.ocl
> you finaly have
> oe.emf.ocl.sdk that depends on oe.emf.query.sdk and
> oe.emf.query.sdk that depends on oe.emf.ocl.sdk
> Bundling the examples separately would be a good idea as it would remove
> that mutual dependency. I can't find any eclipse best practice document
> on the website about the way to aggregate plugins in feature. However
> maybe following the EMF way is the best.
> Best regards,
> Didier
> BTW: I've just moved to transactions in my application and it rulez!
> Really great work. I'll ask you some questions in another post.
> Christian W. Damus wrote:
>> Hello, Didier,
>> I am able to install the OCL and Query features in either of the
>> following configurations:
>> - org.eclipse.emf.examples (required by OCL examples)
>> - org.eclipse.emf.ocl (required by org.eclipse.emf.query.ocl)
>> - org.eclipse.emf.query (required by org.eclipse.emf.query.ocl)
>> - org.eclipse.emf.query.ocl (required by OCL examples)
>> - org.eclipse.emf.ocl.examples
>> or
>> - org.eclipse.emf.ocl.sdk
>> - org.eclipse.emf.query.sdk
>> However, the OCL SDK cannot be installed on its own (including the
>> examples)
>> without Query. Is this the problem that you are having? Perhaps we
>> should consider bundling the examples separately from the SDK as is done
>> in the EMF project ...
>> Cheers,
>> Christian
>> Ptitjes wrote:
>>>Hello,
>>>Didier.
Re: OCL and Query interdependency [message #25154 is a reply to message #22106] |
Thu, 23 February 2006 11:12  |
Hello, Didier.
I have committed a fix that doesn't remove the OCL Examples from the SDK
feature, but which removes the dependency on org.eclipse.emf.query.ocl.
The examples don't actually require this dependency.
Christian
Ptitjes wrote:
> Hello,
> Didier.
Re: OCL and Query interdependency [message #567094 is a reply to message #22106] |
Wed, 15 February 2006 17:52  |
Hello, Didier,
I am able to install the OCL and Query features in either of the following
configurations:
or
However, the OCL SDK cannot be installed on its own (including the examples)
without Query. Is this the problem that you are having? Perhaps we should
consider bundling the examples separately from the SDK as is done in the
EMF project ...
Christian
Ptitjes wrote:
> Hello,
> Didier.
Re: OCL and Query interdependency [message #567341 is a reply to message #22553] |
Thu, 16 February 2006 14:30  |
Hello Christian,
So as
you finaly have
Didier
> Hello, Didier,
> configurations:
> or
> EMF project ...
> Cheers,
> Christian
> Ptitjes wrote:
>>Hello,
>>Didier.
Re: OCL and Query interdependency [message #567384 is a reply to message #22900] |
Hello, Didier.
Christian
Ptitjes wrote:
> Hello Christian,
> So as
> you finaly have
> Best regards,
> Didier
>> Hello, Didier,
>> or
>> examples)
>> Cheers,
>> Christian
>> Ptitjes wrote:
>>>Hello,
>>>Didier.
Re: OCL and Query interdependency [message #569365 is a reply to message #22106] |
Hello, Didier.
Christian
Ptitjes wrote:
> Hello,
> Didier.
FUDForum. Page generated in 0.05087 seconds
