Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build failure: OutOfMemoryError: Java heap space
PDE Build failure: OutOfMemoryError: Java heap space [message #22073] |
Mon, 15 September 2008 12:29  |
Hi all,
I'm totally lost. I have an automated build that has been working for about
a month now using this command to build:
java -jar
C:/eclipse/plugins/org.eclipse.equinox.launcher_1.0.100.v200 80509-1800.jar -application
org.eclipse.ant.core.antRunner -buildfile
C:/eclipse/plugins/org.eclipse.pde.build_3.4.0.v20080604/scr ipts/productBuild/productBuild.xml
-Dbuilder=C:/DATA/build/conf
A couple days ago, it started failing. On the first failure, I actually see
an InvocationTargetException (see below). But on every subsequent build, it
runs out of memory. While running the generateFeature ant target, the
script fails because of an OutOfMemoryError. I tried adding -Xmx500 to the
build command, and it didn't help.
Also, I don't know if this makes a difference, but I also can't open eclipse
anymore. (The eclipse.exe in C:/eclipse). I don't know if that's related
or not. If I can't work this out, we'll have to find another way to build.
I desperately don't want to do that, so I would appreciate any help anyone
can give me.
Thanks!
-Matt
[java]
[java] build.jars:
[java]
[java] properties:
[java]
[java] init:
[java]
[java] @dot:
[java] [mkdir] Created dir:
C:\DATA\test\build\plugins\core\temp.folder\@dot.bin
[java] [javac] Compiling 84 source files to
[java] [parsing
C:\DATA\test\build\plugins\core\src\com\etm\AbstractEtmPlugi n.java - #1/84]
[java]
[java] BUILD FAILED
[java]
C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\productBuild\productBuild.xml:29:
The following error occurred while executing this line:
[java]
C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\build.xml:78:
[java]
C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\templates\headless-build\customTargets.xml:12:
[java]
C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\productBuild\allElements.xml:9:
[java]
C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\genericTargets.xml:95:
[java]
C:\DATA\test\build\features\org.eclipse.pde.build.container. feature\build.xml:94:
[java]
C:\DATA\test\build\features\org.eclipse.pde.build.container. feature\build.xml:20:
[java] C:\DATA\test\build\plugins\core\build.xml:169: The following
[java] C:\DATA\test\build\plugins\core\build.xml:104:
java.lang.reflect.InvocationTargetException
[java]
[java] Total time: 1 minute 51 seconds
Re: PDE Build failure: OutOfMemoryError: Java heap space [message #22263 is a reply to message #22073] |
Mon, 15 September 2008 15:02   |
In addition to the log below, I tried adding the verbose argument to get
more info. I don't see anything suspect, aside from the sudden, seemingly
untraceable OutOfMemoryError. But maybe this output means something to
someone in this group. Here it is, starting with the build.jars target.
[java] build.jars:
[java] [available] Unable to find @dot to set property @dot
[java] Project base dir set to: C:\DATA\test\build\plugins\core
[java] [antcall] calling target(s) [@dot] in build file
[java] parsing buildfile C:\DATA\test\build\plugins\core\build.xml with
URI = file:/C:/DATA/test/build/plugins/core/build.xml
[java] Override ignored for property "basews"
[java] Override ignored for property "baseos"
[java] Override ignored for property "basearch"
[java] Property "nl" has not been set
[java] Override ignored for property "basenl"
[java] Override ignored for property "bundleId"
[java] Override ignored for property "bundleVersion"
[java] Override ignored for property "javacFailOnError"
[java] Override ignored for property "javacDebugInfo"
[java] Override ignored for property "javacVerbose"
[java] Override ignored for property "logExtension"
[java] Override ignored for property "compilerArg"
[java] Override ignored for property "javacSource"
[java] Override ignored for property "javacTarget"
[java] Override ignored for property "dir_bootclasspath"
[java] Override ignored for property "bootclasspath"
[java] Override ignored for property "bundleJavacSource"
[java] Override ignored for property "bundleJavacTarget"
[java] Override ignored for property "bundleBootClasspath"
[java] Build sequence for target(s) `@dot' is [properties, init, @dot]
[java] Complete build sequence is [properties, init, @dot, zip.plugin,
copy.src.zip, refresh, gather.logs, build.jars, build.update.jar, src.zip,
gather.bin.parts, build.zips, build.sources, gather.individual.sources,
gather.sources, clean, copy.src.includes, zip.src.zip, ]
[java] [antcall] Entering
C:\DATA\test\build\plugins\core\build.xml...
[java]
[java] properties:
[java] Override ignored for property "build.compiler"
[java]
[java] init:
[java] Property "buildTempFolder" has not been set
[java] Override ignored for property "pluginTemp"
[java] Override ignored for property "build.result.folder"
[java] Override ignored for property "temp.folder"
[java] Override ignored for property "plugin.destination"
[java]
[java] @dot:
[java] [javac] com\etm\AbstractEtmPlugin.java added as
com\etm\AbstractEtmPlugin.class doesn't exist.
[java] [javac] com\etm\EtmCore.java added as com\etm\EtmCore.class
doesn't exist.
[java] [javac] com\etm\EtmLogger.java added as
com\etm\EtmLogger.class doesn't exist.
[java] [javac] com\etm\EtmPlugin.java added as
com\etm\EtmPlugin.class doesn't exist.
[java] [javac] com\etm\application\AbstractApplicationModule.java
added as com\etm\application\AbstractApplicationModule.class doesn't exist.
[java] [javac] com\etm\application\AbstractWorkspace.java added as
com\etm\application\AbstractWorkspace.class doesn't exist.
[java] [javac] com\etm\application\ApplicationEnvironment.java
added as com\etm\application\ApplicationEnvironment.class doesn't exist.
[java] [javac] com\etm\application\ApplicationException.java added
as com\etm\application\ApplicationException.class doesn't exist.
[java] [javac] com\etm\application\DefaultApplication.java added as
com\etm\application\DefaultApplication.class doesn't exist.
[java] [javac]
com\etm\application\IApplicationEnvironmentFactory.java added as
com\etm\application\IApplicationEnvironmentFactory.class doesn't exist.
[java] [javac] com\etm\application\IRepository.java added as
com\etm\application\IRepository.class doesn't exist.
[java] [javac] com\etm\application\LocalRepository.java added as
com\etm\application\LocalRepository.class doesn't exist.
[java] [javac] com\etm\application\Workspace.java added as
com\etm\application\Workspace.class doesn't exist.
[java] [javac] com\etm\application\WorkspaceState.java added as
com\etm\application\WorkspaceState.class doesn't exist.
[java] [javac] com\etm\application\module\IApplicationModule.java
added as com\etm\application\module\IApplicationModule.class doesn't exist.
[java] [javac]
com\etm\application\module\IApplicationModuleListener.java added as
com\etm\application\module\IApplicationModuleListener.class doesn't exist.
[java] [javac] com\etm\cache\Cache.java added as
com\etm\cache\Cache.class doesn't exist.
[java] [javac] com\etm\cache\CacheListener.java added as
com\etm\cache\CacheListener.class doesn't exist.
[java] [javac] com\etm\cache\ImageCache.java added as
com\etm\cache\ImageCache.class doesn't exist.
[java] [javac] com\etm\event\CardEvent.java added as
com\etm\event\CardEvent.class doesn't exist.
[java] [javac] com\etm\event\Event.java added as
com\etm\event\Event.class doesn't exist.
[java] [javac] com\etm\event\EventHistory.java added as
com\etm\event\EventHistory.class doesn't exist.
[java] [javac] com\etm\event\EventListener.java added as
com\etm\event\EventListener.class doesn't exist.
[java] [javac] com\etm\event\EventProducer.java added as
com\etm\event\EventProducer.class doesn't exist.
[java] [javac] com\etm\event\EventRelay.java added as
com\etm\event\EventRelay.class doesn't exist.
[java] [javac] com\etm\model\Access.java added as
com\etm\model\Access.class doesn't exist.
[java] [javac] com\etm\model\CardModel.java added as
com\etm\model\CardModel.class doesn't exist.
[java] [javac] com\etm\model\Comment.java added as
com\etm\model\Comment.class doesn't exist.
[java] [javac] com\etm\model\ExternalizableJaxObject.java added as
com\etm\model\ExternalizableJaxObject.class doesn't exist.
[java] [javac] com\etm\model\Modifiable.java added as
com\etm\model\Modifiable.class doesn't exist.
[java] [javac] com\etm\model\Note.java added as
com\etm\model\Note.class doesn't exist.
[java] [javac] com\etm\model\Summary.java added as
com\etm\model\Summary.class doesn't exist.
[java] [javac] com\etm\model\attachment\Attachment.java added as
com\etm\model\attachment\Attachment.class doesn't exist.
[java] [javac] com\etm\model\attachment\AttachmentListener.java
added as com\etm\model\attachment\AttachmentListener.class doesn't exist.
[java] [javac] com\etm\model\attachment\MimeType.java added as
com\etm\model\attachment\MimeType.class doesn't exist.
[java] [javac] com\etm\model\event\CardUpdate.java added as
com\etm\model\event\CardUpdate.class doesn't exist.
[java] [javac] com\etm\model\event\IPropertyListener.java added as
com\etm\model\event\IPropertyListener.class doesn't exist.
[java] [javac] com\etm\model\event\PropertyEventType.java added as
com\etm\model\event\PropertyEventType.class doesn't exist.
[java] [javac] com\etm\model\event\PropertyUpdate.java added as
com\etm\model\event\PropertyUpdate.class doesn't exist.
[java] [javac] com\etm\model\property\AbstractScopedProperty.java
added as com\etm\model\property\AbstractScopedProperty.class doesn't exist.
[java] [javac] com\etm\model\property\ComplexProperty.java added as
com\etm\model\property\ComplexProperty.class doesn't exist.
[java] [javac] com\etm\model\property\CopyOfPropertyType.java added
as com\etm\model\property\CopyOfPropertyType.class doesn't exist.
[java] [javac] com\etm\model\property\MultiComplexProperty.java
added as com\etm\model\property\MultiComplexProperty.class doesn't exist.
[java] [javac] com\etm\model\property\MultiValueProperty.java added
as com\etm\model\property\MultiValueProperty.class doesn't exist.
[java] [javac] com\etm\model\property\Property.java added as
com\etm\model\property\Property.class doesn't exist.
[java] [javac] com\etm\model\property\PropertyInfo.java added as
com\etm\model\property\PropertyInfo.class doesn't exist.
[java] [javac] com\etm\model\property\PropertyType.java added as
com\etm\model\property\PropertyType.class doesn't exist.
[java] [javac] com\etm\model\property\PropertyTypes.java added as
com\etm\model\property\PropertyTypes.class doesn't exist.
[java] [javac] com\etm\model\property\SimpleProperty.java added as
com\etm\model\property\SimpleProperty.class doesn't exist.
[java] [javac] com\etm\model\property\UserScopedProperty.java added
as com\etm\model\property\UserScopedProperty.class doesn't exist.
[java] [javac] com\etm\model\property\WorkspaceScopedProperty.java
added as com\etm\model\property\WorkspaceScopedProperty.class doesn't exist.
[java] [javac] com\etm\model\property\event\PropertyUpdater.java
added as com\etm\model\property\event\PropertyUpdater.class doesn't exist.
[java] [javac] com\etm\model\xml\XmlCards.java added as
com\etm\model\xml\XmlCards.class doesn't exist.
[java] [javac] com\etm\model\xml\XmlError.java added as
com\etm\model\xml\XmlError.class doesn't exist.
[java] [javac] com\etm\model\xml\XmlList.java added as
com\etm\model\xml\XmlList.class doesn't exist.
[java] [javac] com\etm\model\xml\XmlListListener.java added as
com\etm\model\xml\XmlListListener.class doesn't exist.
[java] [javac] com\etm\model\xml\XmlMapping.java added as
com\etm\model\xml\XmlMapping.class doesn't exist.
[java] [javac] com\etm\model\xml\XmlStackTraceElement.java added as
com\etm\model\xml\XmlStackTraceElement.class doesn't exist.
[java] [javac] com\etm\model\xml\XmlWrapper.java added as
com\etm\model\xml\XmlWrapper.class doesn't exist.
[java] [javac] com\etm\service\AttachmentService.java added as
com\etm\service\AttachmentService.class doesn't exist.
[java] [javac] com\etm\service\EtmService.java added as
com\etm\service\EtmService.class doesn't exist.
[java] [javac] com\etm\service\EtmServices.java added as
com\etm\service\EtmServices.class doesn't exist.
[java] [javac] com\etm\service\UrlInputStream.java added as
com\etm\service\UrlInputStream.class doesn't exist.
[java] [javac] com\etm\util\FileUtils.java added as
com\etm\util\FileUtils.class doesn't exist.
[java] [javac] com\etm\util\ImageUtils.java added as
com\etm\util\ImageUtils.class doesn't exist.
[java] [javac] com\etm\util\ImportExportUtils.java added as
com\etm\util\ImportExportUtils.class doesn't exist.
[java] [javac] com\etm\util\LocaleUtils.java added as
com\etm\util\LocaleUtils.class doesn't exist.
[java] [javac] com\etm\util\MhtmlUtils.java added as
com\etm\util\MhtmlUtils.class doesn't exist.
[java] [javac] com\etm\util\UrlUtils.java added as
com\etm\util\UrlUtils.class doesn't exist.
[java] [javac] com\etm\util\XmlUtils.java added as
com\etm\util\XmlUtils.class doesn't exist.
[java] [javac] com\etm\util\ZipUtility.java added as
com\etm\util\ZipUtility.class doesn't exist.
[java] [javac] com\etm\CoreTests.java added as
com\etm\CoreTests.class doesn't exist.
[java] [javac] com\etm\MockBundle.java added as
com\etm\MockBundle.class doesn't exist.
[java] [javac] com\etm\MockBundleContext.java added as
com\etm\MockBundleContext.class doesn't exist.
[java] [javac] com\etm\application\WorkspaceIOTest.java added as
com\etm\application\WorkspaceIOTest.class doesn't exist.
[java] [javac] com\etm\application\WorkspaceTest.java added as
com\etm\application\WorkspaceTest.class doesn't exist.
[java] [javac] com\etm\event\MockEventListener.java added as
com\etm\event\MockEventListener.class doesn't exist.
[java] [javac] com\etm\model\BasicCardModel.java added as
com\etm\model\BasicCardModel.class doesn't exist.
[java] [javac] com\etm\model\xml\XmlErrorTest.java added as
com\etm\model\xml\XmlErrorTest.class doesn't exist.
[java] [javac] com\etm\repository\LocalRepositoryTest.java added as
com\etm\repository\LocalRepositoryTest.class doesn't exist.
[java] [javac] com\etm\util\FileUtilsTest.java added as
com\etm\util\FileUtilsTest.class doesn't exist.
[java] [javac] com\etm\util\MhtmlUtilsTest.java added as
com\etm\util\MhtmlUtilsTest.class doesn't exist.
[java] [javac] com\etm\util\TestUtils.java added as
com\etm\util\TestUtils.class doesn't exist.
[java] [javac] com\etm\util\XmlUtilsTest.java added as
com\etm\util\XmlUtilsTest.class doesn't exist.
[java] [javac] EvtmResources.properties skipped - don't know how to
handle it
[java] [javac] filters\api\googleMaps.xml skipped - don't know how
to handle it
[java] [javac] filters\api\yahooMapImage.xml skipped - don't know
how to handle it
[java] [javac] filters\api\yahooWeather.new.xml skipped - don't
know how to handle it
[java] [javac] filters\api\yahooWeather.xml skipped - don't know
how to handle it
[java] [javac] log4j.properties skipped - don't know how to handle
it
[java] [javac] test\filter\amazon.html skipped - don't know how to
handle it
[java] [javac] test\filter\craigslist.html skipped - don't know how
to handle it
[java] [javac] test\filter\ebay.html skipped - don't know how to
handle it
[java] [javac] test\filter\netflix.html skipped - don't know how to
handle it
[java] [javac] test\filter\weather.html skipped - don't know how to
handle it
[java] [javac] test\images\logo.gif skipped - don't know how to
handle it
[java] [javac] test\repo\test.txt skipped - don't know how to
handle it
[java] [javac] test\workspaces\ebay.ews skipped - don't know how to
handle it
[java] [javac] test\xquery\cnn.xhtml skipped - don't know how to
handle it
[java] [javac] test\zip\images\logo.gif skipped - don't know how to
handle it
[java] [javac] test\zip\test.txt skipped - don't know how to handle
it
[java] [javac] Using JDT compiler
[java] dropping
C:\DATA\test\eclipse\plugins\org.eclipse.core.runtime.compat ibility.registry_3.2.200.v20080610\@dot
from path as it doesn't exist
[java] dropping
C:\DATA\test\eclipse\plugins\org.eclipse.ui.workbench.compat ibility_3.2.0.I20080509-2000\@dot
[java] [javac] Compilation arguments:
[java] [javac] '-noExit'
[java] [javac] '-bootclasspath'
[java] [javac] 'C:\Program Files
(x86)\Java\jdk1.6.0\jre\lib\charsets.jar;C:\Program Files
(x86)\Java\jdk1.6.0\jre\lib\deploy.jar;C:\Program Files
(x86)\Java\jdk1.6.0\jre\lib\javaws.jar;C:\Program Files
(x86)\Java\jdk1.6.0\jre\lib\jce.jar;C:\Program Files
(x86)\Java\jdk1.6.0\jre\lib\jsse.jar;C:\Program Files
(x86)\Java\jdk1.6.0\jre\lib\management-agent.jar;C:\Program Files
(x86)\Java\jdk1.6.0\jre\lib\plugin.jar;C:\Program Files
(x86)\Java\jdk1.6.0\jre\lib\resources.jar;C:\Program Files
(x86)\Java\jdk1.6.0\jre\lib\rt.jar'
[java] [javac] '-classpath'
[java] [javac]
'C:\DATA\test\build\plugins\core\temp.folder\@dot.bin;C:\DAT A\test\eclipse\plugins\org.eclipse.swt_3.4.0.v3448f.jar[+org /eclipse/swt/*;+org/eclipse/swt/accessibility/*;+org/eclipse /swt/awt/*;+org/eclipse/swt/browser/*;+org/eclipse/swt/custo m/*;+org/eclipse/swt/dnd/*;+org/eclipse/swt/events/*;+org/ec lipse/swt/graphics/*;+org/eclipse/swt/layout/*;+org/eclipse/ swt/opengl/*;+org/eclipse/swt/printing/*;+org/eclipse/swt/pr ogram/*;+org/eclipse/swt/widgets/*;~org/eclipse/swt/internal /*;~org/eclipse/swt/internal/image/*;~org/eclipse/swt/intern al/theme/*;+org/eclipse/swt/ole/win32/*;~org/eclipse/swt/int ernal/gdip/*;~org/eclipse/swt/internal/ole/win32/*;~org/ecli pse/swt/internal/win32/*;~org/eclipse/swt/internal/opengl/wi n32/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.swt.wi n32.win32.x86_3.4.0.v3448f.jar[+org/eclipse/swt/*;+org/eclip se/swt/accessibility/*;+org/eclipse/swt/awt/*;+org/eclipse/s wt/browser/*;+org/eclipse/swt/custom/*;+org/eclipse/swt/dnd/ *;+org/eclipse/swt/events/*;+org/eclipse/swt/graphics/*;+org /eclipse/swt/layout/*;+org/eclipse/swt/opengl/*;+org/eclipse /swt/printing/*;+org/eclipse/swt/program/*;+org/eclipse/swt/ widgets/*;~org/eclipse/swt/internal/*;~org/eclipse/swt/inter nal/image/*;~org/eclipse/swt/internal/theme/*;+org/eclipse/s wt/ole/win32/*;~org/eclipse/swt/internal/gdip/*;~org/eclipse /swt/internal/ole/win32/*;~org/eclipse/swt/internal/win32/*; ~org/eclipse/swt/internal/opengl/win32/*;?**/*];C:\DATA\test \eclipse\plugins\org.eclipse.core.runtime_3.4.0.v20080512.ja r[~org/eclipse/core/internal/preferences/legacy/*;~org/eclip se/core/internal/runtime/*;+org/eclipse/core/runtime/*;?**/* ];C:\DATA\test\eclipse\plugins\org.eclipse.osgi_3.4.0.v20080 605-1900.jar[+org/eclipse/osgi/event/*;+org/eclipse/osgi/fra mework/console/*;+org/eclipse/osgi/framework/eventmgr/*;+org /eclipse/osgi/framework/log/*;+org/eclipse/osgi/service/data location/*;+org/eclipse/osgi/service/debug/*;+org/eclipse/os gi/service/environment/*;+org/eclipse/osgi/service/localizat ion/*;+org/eclipse/osgi/service/pluginconversion/*;+org/ecli pse/osgi/service/resolver/*;+org/eclipse/osgi/service/runnab le/*;+org/eclipse/osgi/service/security/*;+org/eclipse/osgi/ service/urlconversion/*;+org/eclipse/osgi/signedcontent/*;+o rg/eclipse/osgi/storagemanager/*;+org/eclipse/osgi/util/*;+o rg/osgi/framework/*;+org/osgi/service/condpermadmin/*;+org/o sgi/service/packageadmin/*;+org/osgi/service/permissionadmin /*;+org/osgi/service/startlevel/*;+org/osgi/service/url/*;+o rg/osgi/util/tracker/*;~org/eclipse/core/runtime/adaptor/*;~ org/eclipse/core/runtime/internal/adaptor/*;~org/eclipse/cor e/runtime/internal/stats/*;~org/eclipse/osgi/baseadaptor/*;~ org/eclipse/osgi/baseadaptor/bundlefile/*;~org/eclipse/osgi/ baseadaptor/hooks/*;~org/eclipse/osgi/baseadaptor/loader/*;~ org/eclipse/osgi/framework/adaptor/*;~org/eclipse/osgi/frame work/debug/*;~org/eclipse/osgi/framework/internal/core/*;~or g/eclipse/osgi/framework/internal/protocol/*;~org/eclipse/os gi/framework/internal/protocol/bundleentry/*;~org/eclipse/os gi/framework/internal/protocol/bundleresource/*;~org/eclipse /osgi/framework/internal/protocol/reference/*;~org/eclipse/o sgi/framework/internal/reliablefile/*;~org/eclipse/osgi/fram ework/launcher/*;~org/eclipse/osgi/framework/util/*;~org/ecl ipse/osgi/internal/baseadaptor/*;~org/eclipse/osgi/internal/ module/*;~org/eclipse/osgi/internal/profile/*;~org/eclipse/o sgi/internal/resolver/*;~org/eclipse/osgi/internal/provision al/service/security/*;~org/eclipse/osgi/internal/provisional /verifier/*;~org/eclipse/osgi/internal/service/security/*;~o rg/eclipse/osgi/internal/signedcontent/*;?**/*];C:\DATA\test \eclipse\plugins\org.eclipse.equinox.common_3.4.0.v20080421- 2006.jar[~org/eclipse/core/internal/boot/*;~org/eclipse/core /internal/runtime/*;+org/eclipse/core/runtime/*;?**/*];C:\DA TA\test\eclipse\plugins\org.eclipse.core.jobs_3.4.0.v2008051 2.jar[~org/eclipse/core/internal/jobs/*;+org/eclipse/core/ru ntime/jobs/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse .core.runtime.compatibility.registry_3.2.200.v20080610\runti me_registry_compatibility.jar[~org/eclipse/core/internal/ada pter/*;~org/eclipse/core/internal/registry/*;~org/eclipse/co re/internal/registry/osgi/*;~org/eclipse/core/internal/regis try/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/core/runt ime/dynamichelpers/*;+org/eclipse/core/runtime/spi/*;?**/*]; C:\DATA\test\eclipse\plugins\org.eclipse.core.runtime.compat ibility.registry_3.2.200.v20080610[~org/eclipse/core/interna l/adapter/*;~org/eclipse/core/internal/registry/*;~org/eclip se/core/internal/registry/osgi/*;~org/eclipse/core/internal/ registry/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/core /runtime/dynamichelpers/*;+org/eclipse/core/runtime/spi/*;?* */*];C:\DATA\test\eclipse\plugins\org.eclipse.equinox.regist ry_3.4.0.v20080516-0950.jar[~org/eclipse/core/internal/adapt er/*;~org/eclipse/core/internal/registry/*;~org/eclipse/core /internal/registry/osgi/*;~org/eclipse/core/internal/registr y/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/core/runtim e/dynamichelpers/*;+org/eclipse/core/runtime/spi/*;?**/*];C: \DATA\test\eclipse\plugins\org.eclipse.equinox.preferences_3 .2.200.v20080421-2006.jar[~org/eclipse/core/internal/prefere nces/*;~org/eclipse/core/internal/preferences/exchange/*;+or g/eclipse/core/runtime/preferences/*;+org/osgi/service/prefs /*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.core.cont enttype_3.3.0.v20080604-1400.jar[~org/eclipse/core/internal/ content/*;+org/eclipse/core/runtime/content/*;?**/*];C:\DATA \test\eclipse\plugins\org.eclipse.core.runtime.compatibility .auth_3.2.100.v20070502.jar[?**/*];C:\DATA\test\eclipse\plug ins\org.eclipse.equinox.app_1.1.0.v20080421-2006.jar[+org/ec lipse/equinox/app/*;~org/eclipse/equinox/internal/app/*;+org /osgi/service/application/*;?**/*];C:\DATA\test\eclipse\plug ins\org.eclipse.osgi.services_3.1.200.v20071203.jar[?**/*];C :\DATA\test\eclipse\plugins\javax.servlet_2.4.0.v20080603160 4.jar[?**/*];C:\DATA\test\eclipse\plugins\org.junit_3.8.2.v2 0080602-1318\junit.jar[+junit/awtui/*;+junit/extensions/*;+j unit/framework/*;+junit/runner/*;+junit/swingui/*;+junit/swi ngui/icons/*;+junit/textui/*;?**/*];C:\DATA\test\eclipse\plu gins\org.apache.log4j_1.2.13.v200806030600.jar[+org/apache/l og4j/*;+org/apache/log4j/chainsaw/*;+org/apache/log4j/config /*;+org/apache/log4j/helpers/*;+org/apache/log4j/jdbc/*;+org /apache/log4j/jmx/*;+org/apache/log4j/lf5/*;+org/apache/log4 j/lf5/config/*;+org/apache/log4j/lf5/util/*;+org/apache/log4 j/lf5/viewer/*;+org/apache/log4j/lf5/viewer/categoryexplorer /*;+org/apache/log4j/lf5/viewer/configure/*;+org/apache/log4 j/lf5/viewer/images/*;+org/apache/log4j/net/*;+org/apache/lo g4j/nt/*;+org/apache/log4j/or/*;+org/apache/log4j/or/jms/*;+ org/apache/log4j/or/sax/*;+org/apache/log4j/spi/*;+org/apach e/log4j/varia/*;+org/apache/log4j/xml/*;?**/*];C:\DATA\test\ eclipse\plugins\org.eclipse.ui_3.4.0.I20080610-1200.jar[~org /eclipse/ui/internal/*;?**/*];C:\DATA\test\eclipse\plugins\o rg.eclipse.jface_3.4.0.I20080606-1300.jar[+org/eclipse/jface /*;+org/eclipse/jface/action/*;+org/eclipse/jface/action/ima ges/*;+org/eclipse/jface/bindings/*;+org/eclipse/jface/bindi ngs/keys/*;+org/eclipse/jface/bindings/keys/formatting/*;+or g/eclipse/jface/commands/*;+org/eclipse/jface/contexts/*;+or g/eclipse/jface/dialogs/*;+org/eclipse/jface/dialogs/images/ *;+org/eclipse/jface/fieldassist/*;+org/eclipse/jface/fielda ssist/images/*;+org/eclipse/jface/images/*;~org/eclipse/jfac e/internal/*;~org/eclipse/jface/internal/provisional/action/ *;+org/eclipse/jface/layout/*;+org/eclipse/jface/menus/*;+or g/eclipse/jface/operation/*;+org/eclipse/jface/preference/*; +org/eclipse/jface/preference/images/*;+org/eclipse/jface/re source/*;+org/eclipse/jface/util/*;+org/eclipse/jface/viewer s/*;+org/eclipse/jface/viewers/deferred/*;+org/eclipse/jface /window/*;+org/eclipse/jface/wizard/*;+org/eclipse/jface/wiz ard/images/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse .core.commands_3.4.0.I20080509-2000.jar[+org/eclipse/core/co mmands/*;+org/eclipse/core/commands/common/*;+org/eclipse/co re/commands/contexts/*;+org/eclipse/core/commands/operations /*;+org/eclipse/core/commands/util/*;~org/eclipse/core/inter nal/commands/operations/*;~org/eclipse/core/internal/command s/util/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.ui. workbench_3.4.0.I20080606-1300.jar[+org/eclipse/ui/*;+org/ec lipse/ui/about/*;+org/eclipse/ui/actions/*;+org/eclipse/ui/a ctivities/*;+org/eclipse/ui/application/*;+org/eclipse/ui/br anding/*;+org/eclipse/ui/browser/*;+org/eclipse/ui/commands/ *;+org/eclipse/ui/contexts/*;+org/eclipse/ui/dialogs/*;+org/ eclipse/ui/dnd/*;+org/eclipse/ui/fieldassist/*;+org/eclipse/ ui/handlers/*;+org/eclipse/ui/help/*;~org/eclipse/ui/interna l/*;~org/eclipse/ui/internal/about/*;~org/eclipse/ui/interna l/actions/*;~org/eclipse/ui/internal/activities/*;~org/eclip se/ui/internal/activities/ws/*;~org/eclipse/ui/internal/appl ication/*;~org/eclipse/ui/internal/browser/*;~org/eclipse/ui /internal/commands/*;~org/eclipse/ui/internal/contexts/*;~or g/eclipse/ui/internal/decorators/*;~org/eclipse/ui/internal/ dialogs/*;~org/eclipse/ui/internal/dnd/*;~org/eclipse/ui/int ernal/editorsupport/*;~org/eclipse/ui/internal/expressions/* ;~org/eclipse/ui/internal/handlers/*;~org/eclipse/ui/interna l/help/*;~org/eclipse/ui/internal/intro/*;~org/eclipse/ui/in ternal/keys/*;~org/eclipse/ui/internal/keys/model/*;~org/ecl ipse/ui/internal/layout/*;~org/eclipse/ui/internal/menus/*;~ org/eclipse/ui/internal/misc/*;~org/eclipse/ui/internal/mode l/*;~org/eclipse/ui/internal/operations/*;~org/eclipse/ui/in ternal/part/*;~org/eclipse/ui/internal/preferences/*;~org/ec lipse/ui/internal/presentations/*;~org/eclipse/ui/internal/p resentations/classic/*;~org/eclipse/ui/internal/presentation s/defaultpresentation/*;~org/eclipse/ui/internal/presentatio ns/util/*;~org/eclipse/ui/internal/progress/*;~org/eclipse/u i/internal/provisional/application/*;~org/eclipse/ui/interna l/provisional/presentations/*;~org/eclipse/ui/internal/quick access/*;~org/eclipse/ui/internal/registry/*;~org/eclipse/ui /internal/services/*;~org/eclipse/ui/internal/splash/*;~org/ eclipse/ui/internal/statushandlers/*;~org/eclipse/ui/interna l/testing/*;~org/eclipse/ui/internal/themes/*;~org/eclipse/u i/internal/tweaklets/*;~org/eclipse/ui/internal/util/*;~org/ eclipse/ui/internal/wizards/*;~org/eclipse/ui/internal/wizar ds/preferences/*;+org/eclipse/ui/intro/*;+org/eclipse/ui/key s/*;+org/eclipse/ui/menus/*;+org/eclipse/ui/model/*;+org/ecl ipse/ui/operations/*;+org/eclipse/ui/part/*;+org/eclipse/ui/ plugin/*;+org/eclipse/ui/preferences/*;+org/eclipse/ui/prese ntations/*;+org/eclipse/ui/progress/*;+org/eclipse/ui/servic es/*;+org/eclipse/ui/splash/*;+org/eclipse/ui/statushandlers /*;+org/eclipse/ui/swt/*;+org/eclipse/ui/testing/*;+org/ecli pse/ui/themes/*;+org/eclipse/ui/views/*;+org/eclipse/ui/wiza rds/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.ui.wor kbench.compatibility_3.2.0.I20080509-2000\compatibility.jar[ +org/eclipse/ui/*;+org/eclipse/ui/about/*;+org/eclipse/ui/ac tions/*;+org/eclipse/ui/activities/*;+org/eclipse/ui/applica tion/*;+org/eclipse/ui/branding/*;+org/eclipse/ui/browser/*; +org/eclipse/ui/commands/*;+org/eclipse/ui/contexts/*;+org/e clipse/ui/dialogs/*;+org/eclipse/ui/dnd/*;+org/eclipse/ui/fi eldassist/*;+org/eclipse/ui/handlers/*;+org/eclipse/ui/help/ *;~org/eclipse/ui/internal/*;~org/eclipse/ui/internal/about/ *;~org/eclipse/ui/internal/actions/*;~org/eclipse/ui/interna l/activities/*;~org/eclipse/ui/internal/activities/ws/*;~org /eclipse/ui/internal/application/*;~org/eclipse/ui/internal/ browser/*;~org/eclipse/ui/internal/commands/*;~org/eclipse/u i/internal/contexts/*;~org/eclipse/ui/internal/decorators/*; ~org/eclipse/ui/internal/dialogs/*;~org/eclipse/ui/internal/ dnd/*;~org/eclipse/ui/internal/editorsupport/*;~org/eclipse/ ui/internal/expressions/*;~org/eclipse/ui/internal/handlers/ *;~org/eclipse/ui/internal/help/*;~org/eclipse/ui/internal/i ntro/*;~org/eclipse/ui/internal/keys/*;~org/eclipse/ui/inter nal/keys/model/*;~org/eclipse/ui/internal/layout/*;~org/ecli pse/ui/internal/menus/*;~org/eclipse/ui/internal/misc/*;~org /eclipse/ui/internal/model/*;~org/eclipse/ui/internal/operat ions/*;~org/eclipse/ui/internal/part/*;~org/eclipse/ui/inter nal/preferences/*;~org/eclipse/ui/internal/presentations/*;~ org/eclipse/ui/internal/presentations/classic/*;~org/eclipse /ui/internal/presentations/defaultpresentation/*;~org/eclips e/ui/internal/presentations/util/*;~org/eclipse/ui/internal/ progress/*;~org/eclipse/ui/internal/provisional/application/ *;~org/eclipse/ui/internal/provisional/presentations/*;~org/ eclipse/ui/internal/quickaccess/*;~org/eclipse/ui/internal/r egistry/*;~org/eclipse/ui/internal/services/*;~org/eclipse/u i/internal/splash/*;~org/eclipse/ui/internal/statushandlers/ *;~org/eclipse/ui/internal/testing/*;~org/eclipse/ui/interna l/themes/*;~org/eclipse/ui/internal/tweaklets/*;~org/eclipse /ui/internal/util/*;~org/eclipse/ui/internal/wizards/*;~org/ eclipse/ui/internal/wizards/preferences/*;+org/eclipse/ui/in tro/*;+org/eclipse/ui/keys/*;+org/eclipse/ui/menus/*;+org/ec lipse/ui/model/*;+org/eclipse/ui/operations/*;+org/eclipse/u i/part/*;+org/eclipse/ui/plugin/*;+org/eclipse/ui/preference s/*;+org/eclipse/ui/presentations/*;+org/eclipse/ui/progress /*;+org/eclipse/ui/services/*;+org/eclipse/ui/splash/*;+org/ eclipse/ui/statushandlers/*;+org/eclipse/ui/swt/*;+org/eclip se/ui/testing/*;+org/eclipse/ui/themes/*;+org/eclipse/ui/vie ws/*;+org/eclipse/ui/wizards/*;?**/*];C:\DATA\test\eclipse\p lugins\com.ibm.icu_3.8.1.v20080530.jar[?**/*];C:\DATA\test\e clipse\plugins\org.eclipse.help_3.3.100.v20080610.jar[?**/*] ;C:\DATA\test\eclipse\plugins\org.eclipse.core.expressions_3 .4.0.v20080603-2000.jar[?**/*];C:\DATA\test\eclipse\plugins\ org.eclipse.jface.databinding_1.2.0.I20080515-2000a.jar[?**/ *];C:\DATA\test\eclipse\plugins\org.eclipse.core.databinding _1.1.0.I20080527-2000.jar[?**/*];C:\DATA\test\eclipse\plugin s\org.eclipse.core.resources_3.4.0.v20080604-1400.jar[?**/*] ;C:\DATA\test\eclipse\plugins\org.eclipse.core.resources.com patibility_3.4.0.v20080604-1400.jar[?**/*];C:\DATA\test\ecli pse\plugins\org.eclipse.core.resources.win32.x86_3.4.0.v2007 1204.jar[?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.ant .core_3.2.0.v20080529.jar[?**/*];C:\DATA\test\eclipse\plugin s\org.eclipse.core.variables_3.2.100.v20080529-1300.jar[?**/ *];C:\DATA\test\eclipse\plugins\org.eclipse.core.filesystem_ 1.2.0.v20080604-1400.jar[?**/*];C:\DATA\test\eclipse\plugins \org.eclipse.core.filesystem.win32.x86_1.1.0.v20080604-1400. jar[?**/*];C:\DATA\test\build\plugins\core\src;C:\DATA\test\ build\plugins\core\test;C:\DATA\test\build\plugins\core\reso urce'
[java] [javac] '-d'
[java] [javac]
'C:\DATA\test\build\plugins\core\temp.folder\@dot.bin'
[java] [javac] '-verbose'
[java] [javac]
'@C:\DATA\test\build\plugins\core/javaCompiler...args'
[java] [javac] '-log'
[java] [javac]
'C:\DATA\test\build\plugins\core/temp.folder/@dot.bin.log'
[java] [javac]
[java] [javac] The ' characters around the executable and arguments
are
[java] [javac] not part of the command.
[java] [javac] Files to be compiled:
[java] [javac]
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\EtmCore.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\EtmLogger.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\EtmPlugin.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Abst ractApplicationModule.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Abst ractWorkspace.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Appl icationEnvironment.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Appl icationException.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Defa ultApplication.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\IApp licationEnvironmentFactory.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\IRep ository.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Loca lRepository.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Work space.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Work spaceState.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\modu le\IApplicationModule.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\modu le\IApplicationModuleListener.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\cache\Cache.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\cache\CacheListe ner.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\cache\ImageCache .java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\CardEvent. java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\Event.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\EventHisto ry.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\EventListe ner.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\EventProdu cer.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\EventRelay .java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Access.jav a
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\CardModel. java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Comment.ja va
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Externaliz ableJaxObject.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Modifiable .java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Note.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Summary.ja va
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\attachment \Attachment.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\attachment \AttachmentListener.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\attachment \MimeType.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\event\Card Update.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\event\IPro pertyListener.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\event\Prop ertyEventType.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\event\Prop ertyUpdate.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\A bstractScopedProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\C omplexProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\C opyOfPropertyType.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\M ultiComplexProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\M ultiValueProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\P roperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\P ropertyInfo.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\P ropertyType.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\P ropertyTypes.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\S impleProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\U serScopedProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\W orkspaceScopedProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\e vent\PropertyUpdater.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlCar ds.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlErr or.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlLis t.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlLis tListener.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlMap ping.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlSta ckTraceElement.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlWra pper.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\service\Attachme ntService.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\service\EtmServi ce.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\service\EtmServi ces.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\service\UrlInput Stream.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\FileUtils.j ava
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\ImageUtils. java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\ImportExpor tUtils.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\LocaleUtils .java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\MhtmlUtils. java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\UrlUtils.ja va
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\XmlUtils.ja va
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\ZipUtility. java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\CoreTests.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\MockBundle.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\MockBundleConte xt.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\application\Wor kspaceIOTest.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\application\Wor kspaceTest.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\event\MockEvent Listener.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\model\BasicCard Model.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\model\xml\XmlEr rorTest.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\repository\Loca lRepositoryTest.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\util\FileUtilsT est.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\util\MhtmlUtils Test.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\util\TestUtils. java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\util\XmlUtilsTe st.java
[java] [javac] [parsing
C:\DATA\test\build\plugins\core\src\com\etm\EtmCore.java - #2/84]
C:\DATA\test\build\plugins\core\src\com\etm\EtmLogger.java - #3/84]
C:\DATA\test\build\plugins\core\src\com\etm\EtmPlugin.java - #4/84]
- #5/84]
- #6/84]
- #7/84]
- #8/84]
- #9/84]
- #10/84]
C:\DATA\test\build\plugins\core\src\com\etm\application\IRep ository.java -
#11/84]
[java] [javac] ----------
[java] [javac] 1. ERROR in
(at line 0)
[java] [javac] package com.etm.application;
[java] [javac] ^
[java] [javac] Internal compiler error
[java] [javac] java.lang.OutOfMemoryError: Java heap space
[java] [javac]
"Sither" <sither@mit.edu> wrote in message
news:gam2hf$l66$1@build.eclipse.org...
> Hi all,
> about a month now using this command to build:
> java -jar
> -application org.eclipse.ant.core.antRunner -buildfile
> see an InvocationTargetException (see below). But on every subsequent
> build, it runs out of memory. While running the generateFeature ant
> target, the script fails because of an OutOfMemoryError. I tried
> adding -Xmx500 to the build command, and it didn't help.
> eclipse anymore. (The eclipse.exe in C:/eclipse). I don't know if that's
> related or not. If I can't work this out, we'll have to find another way
> to build. I desperately don't want to do that, so I would appreciate any
> help anyone can give me.
> Thanks!
> -Matt
> [java]
> [java] build.jars:
> [java]
> [java] properties:
> [java]
> [java] init:
> [java]
> [java] @dot:
> [java] [parsing
> #1/84]
> [java]
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
Re: PDE Build failure: OutOfMemoryError: Java heap space [message #22320 is a reply to message #22263] |
Mon, 15 September 2008 16:51   |
Have you tried increasing the vm memory on the process that is running
out? http://www.eclipsezone.com/eclipse/forums/t61618.html
> seemingly untraceable OutOfMemoryError. But maybe this output means
> something to someone in this group. Here it is, starting with the
> build.jars target.
> [java] build.jars:
> with URI = file:/C:/DATA/test/build/plugins/core/build.xml
> zip.plugin, copy.src.zip, refresh, gather.logs, build.jars,
> build.update.jar, src.zip, gather.bin.parts, build.zips, build.sources,
> gather.individual.sources, gather.sources, clean, copy.src.includes,
> zip.src.zip, ]
> zip.src.zip, ]
> [java]
> [java] properties:
> [java]
> [java] init:
> [java]
> [java] @dot:
> com\etm\EtmCore.class doesn't exist.
> [java] [javac]
> com\etm\application\AbstractApplicationModule.java added as
> as com\etm\application\AbstractWorkspace.class doesn't exist.
> added as com\etm\application\ApplicationException.class doesn't exist.
> as com\etm\application\DefaultApplication.class doesn't exist.
> [java] [javac]
> [java] [javac]
> com\etm\application\module\IApplicationModule.java added as
> [java] [javac]
> as com\etm\model\ExternalizableJaxObject.class doesn't exist.
> as com\etm\model\event\IPropertyListener.class doesn't exist.
> as com\etm\model\event\PropertyEventType.class doesn't exist.
> [java] [javac]
> com\etm\model\property\AbstractScopedProperty.java added as
> as com\etm\model\property\ComplexProperty.class doesn't exist.
> added as com\etm\model\property\CopyOfPropertyType.class doesn't exist.
> added as com\etm\model\property\MultiValueProperty.class doesn't exist.
> as com\etm\model\property\PropertyTypes.class doesn't exist.
> as com\etm\model\property\SimpleProperty.class doesn't exist.
> added as com\etm\model\property\UserScopedProperty.class doesn't exist.
> [java] [javac]
> com\etm\model\property\WorkspaceScopedProperty.java added as
> as com\etm\model\xml\XmlStackTraceElement.class doesn't exist.
> as com\etm\repository\LocalRepositoryTest.class doesn't exist.
> to handle it
> how to handle it
> how to handle it
> handle it
> to handle it
> how to handle it
> handle it
> to handle it
> to handle it
> handle it
> handle it
> to handle it
> handle it
> to handle it
> handle it
> [java] dropping
> [java] dropping
> [java] [javac]
;+org/eclipse/swt/graphics/*;+org/eclipse/swt/layout/*;+org/ eclipse/swt/opengl/*;+org/eclipse/swt/printing/*;+org/eclips e/swt/program/*;+org/eclipse/swt/widgets/*;~org/eclipse/swt/ internal/*;~org/eclipse/swt/internal/image/*;~org/eclipse/sw t/internal/theme/*;+org/eclipse/swt/ole/win32/*;~org/eclipse /swt/internal/gdip/*;~org/eclipse/swt/internal/ole/win32/*;~ org/eclipse/swt/internal/win32/*;~org/eclipse/swt/internal/o pengl/win32/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclips e.core.runtime_3.4.0.v20080512.jar[~org/eclipse/core/interna l/preferences/legacy/*;~org/eclipse/core/internal/runtime/*; +org/eclipse/core/runtime/*;?**/*];C:\DATA\test\eclipse\plug ins\org.eclipse.osgi_3.4.0.v20080605-1900.jar[+org/eclipse/o sgi/event/*;+org/eclipse/osgi/framework/console/*;+org/eclip se/osgi/framework/eventmgr/*;+org/eclipse/osgi/framework/log /*;+org/eclipse/osgi/service/datalocation/*;+org/eclipse/osg i/service/debug/*;+org/eclipse/osgi/service/environment/*;+o rg/eclipse/osgi/service/locali
zation/*;+org/eclipse/osgi/service/pluginconversion/*;+org/e clipse/osgi/service/resolver/*;+org/eclipse/osgi/service/run nable/*;+org/eclipse/osgi/service/security/*;+org/eclipse/os gi/service/urlconversion/*;+org/eclipse/osgi/signedcontent/* ;+org/eclipse/osgi/storagemanager/*;+org/eclipse/osgi/util/* ;+org/osgi/framework/*;+org/osgi/service/condpermadmin/*;+or g/osgi/service/packageadmin/*;+org/osgi/service/permissionad min/*;+org/osgi/service/startlevel/*;+org/osgi/service/url/* ;+org/osgi/util/tracker/*;~org/eclipse/core/runtime/adaptor/ *;~org/eclipse/core/runtime/internal/adaptor/*;~org/eclipse/ core/runtime/internal/stats/*;~org/eclipse/osgi/baseadaptor/ *;~org/eclipse/osgi/baseadaptor/bundlefile/*;~org/eclipse/os gi/baseadaptor/hooks/*;~org/eclipse/osgi/baseadaptor/loader/ *;~org/eclipse/osgi/framework/adaptor/*;~org/eclipse/osgi/fr amework/debug/*;~org/eclipse/osgi/framework/internal/core/*; ~org/eclipse/osgi/framework/internal/protocol/*;~org/eclipse /osgi/framework/internal/proto
col/bundleentry/*;~org/eclipse/osgi/framework/internal/proto col/bundleresource/*;~org/eclipse/osgi/framework/internal/pr otocol/reference/*;~org/eclipse/osgi/framework/internal/reli ablefile/*;~org/eclipse/osgi/framework/launcher/*;~org/eclip se/osgi/framework/util/*;~org/eclipse/osgi/internal/baseadap tor/*;~org/eclipse/osgi/internal/module/*;~org/eclipse/osgi/ internal/profile/*;~org/eclipse/osgi/internal/resolver/*;~or g/eclipse/osgi/internal/provisional/service/security/*;~org/ eclipse/osgi/internal/provisional/verifier/*;~org/eclipse/os gi/internal/service/security/*;~org/eclipse/osgi/internal/si gnedcontent/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclips e.equinox.common_3.4.0.v20080421-2006.jar[~org/eclipse/core/ internal/boot/*;~org/eclipse/core/internal/runtime/*;+org/ec lipse/core/runtime/*;?**/*];C:\DATA\test\eclipse\plugins\org .eclipse.core.jobs_3.4.0.v20080512.jar[~org/eclipse/core/int ernal/jobs/*;+org/eclipse/core/runtime/jobs/*;?**/*];C:\DATA \test\eclipse\plugins\org.ecli
pse.core.runtime.compatibility.registry_3.2.200.v20080610\ru ntime_registry_compatibility.jar[~org/eclipse/core/internal/ adapter/*;~org/eclipse/core/internal/registry/*;~org/eclipse /core/internal/registry/osgi/*;~org/eclipse/core/internal/re gistry/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/core/r untime/dynamichelpers/*;+org/eclipse/core/runtime/spi/*;?**/ *];C:\DATA\test\eclipse\plugins\org.eclipse.core.runtime.com patibility.registry_3.2.200.v20080610[~org/eclipse/core/inte rnal/adapter/*;~org/eclipse/core/internal/registry/*;~org/ec lipse/core/internal/registry/osgi/*;~org/eclipse/core/intern al/registry/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/c ore/runtime/dynamichelpers/*;+org/eclipse/core/runtime/spi/* ;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.equinox.reg istry_3.4.0.v20080516-0950.jar[~org/eclipse/core/internal/ad apter/*;~org/eclipse/core/internal/registry/*;~org/eclipse/c ore/internal/registry/osgi/*;~org/eclipse/core/internal/regi stry/spi/*;+org/eclipse/core/r
untime/*;+org/eclipse/core/runtime/dynamichelpers/*;+org/ecl ipse/core/runtime/spi/*;?**/*];C:\DATA\test\eclipse\plugins\ org.eclipse.equinox.preferences_3.2.200.v20080421-2006.jar[~ org/eclipse/core/internal/preferences/*;~org/eclipse/core/in ternal/preferences/exchange/*;+org/eclipse/core/runtime/pref erences/*;+org/osgi/service/prefs/*;?**/*];C:\DATA\test\ecli pse\plugins\org.eclipse.core.contenttype_3.3.0.v20080604-140 0.jar[~org/eclipse/core/internal/content/*;+org/eclipse/core /runtime/content/*;?**/*];C:\DATA\test\eclipse\plugins\org.e clipse.core.runtime.compatibility.auth_3.2.100.v20070502.jar [?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.equinox.app _1.1.0.v20080421-2006.jar[+org/eclipse/equinox/app/*;~org/ec lipse/equinox/internal/app/*;+org/osgi/service/application/* ;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.osgi.servic es_3.1.200.v20071203.jar[?**/*];C:\DATA\test\eclipse\plugins \javax.servlet_2.4.0.v200806031604.jar[?**/*];C:\DATA\test\e clipse\plugins\org.junit_3.8.2
v20080602-1318\junit.jar[+junit/awtui/*;+junit/extensions/*; +junit/framework/*;+junit/runner/*;+junit/swingui/*;+junit/s wingui/icons/*;+junit/textui/*;?**/*];C:\DATA\test\eclipse\p lugins\org.apache.log4j_1.2.13.v200806030600.jar[+org/apache /log4j/*;+org/apache/log4j/chainsaw/*;+org/apache/log4j/conf ig/*;+org/apache/log4j/helpers/*;+org/apache/log4j/jdbc/*;+o rg/apache/log4j/jmx/*;+org/apache/log4j/lf5/*;+org/apache/lo g4j/lf5/config/*;+org/apache/log4j/lf5/util/*;+org/apache/lo g4j/lf5/viewer/*;+org/apache/log4j/lf5/viewer/categoryexplor er/*;+org/apache/log4j/lf5/viewer/configure/*;+org/apache/lo g4j/lf5/viewer/images/*;+org/apache/log4j/net/*;+org/apache/ log4j/nt/*;+org/apache/log4j/or/*;+org/apache/log4j/or/jms/* ;+org/apache/log4j/or/sax/*;+org/apache/log4j/spi/*;+org/apa che/log4j/varia/*;+org/apache/log4j/xml/*;?**/*];C:\DATA\tes t\eclipse\plugins\org.eclipse.ui_3.4.0.I20080610-1200.jar[~o rg/eclipse/ui/internal/*;?**/*];C:\DATA\test\eclipse\plugins \org.eclipse.jface_3.4.0.I200
80606-1300.jar[+org/eclipse/jface/*;+org/eclipse/jface/actio n/*;+org/eclipse/jface/action/images/*;+org/eclipse/jface/bi ndings/*;+org/eclipse/jface/bindings/keys/*;+org/eclipse/jfa ce/bindings/keys/formatting/*;+org/eclipse/jface/commands/*; +org/eclipse/jface/contexts/*;+org/eclipse/jface/dialogs/*;+ org/eclipse/jface/dialogs/images/*;+org/eclipse/jface/fielda ssist/*;+org/eclipse/jface/fieldassist/images/*;+org/eclipse /jface/images/*;~org/eclipse/jface/internal/*;~org/eclipse/j face/internal/provisional/action/*;+org/eclipse/jface/layout /*;+org/eclipse/jface/menus/*;+org/eclipse/jface/operation/* ;+org/eclipse/jface/preference/*;+org/eclipse/jface/preferen ce/images/*;+org/eclipse/jface/resource/*;+org/eclipse/jface /util/*;+org/eclipse/jface/viewers/*;+org/eclipse/jface/view ers/deferred/*;+org/eclipse/jface/window/*;+org/eclipse/jfac e/wizard/*;+org/eclipse/jface/wizard/images/*;?**/*];C:\DATA \test\eclipse\plugins\org.eclipse.core.commands_3.4.0.I20080 509-2000.jar[+org/eclipse/core
/commands/*;+org/eclipse/core/commands/common/*;+org/eclipse /core/commands/contexts/*;+org/eclipse/core/commands/operati ons/*;+org/eclipse/core/commands/util/*;~org/eclipse/core/in ternal/commands/operations/*;~org/eclipse/core/internal/comm ands/util/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse. ui.workbench_3.4.0.I20080606-1300.jar[+org/eclipse/ui/*;+org /eclipse/ui/about/*;+org/eclipse/ui/actions/*;+org/eclipse/u i/activities/*;+org/eclipse/ui/application/*;+org/eclipse/ui /branding/*;+org/eclipse/ui/browser/*;+org/eclipse/ui/comman ds/*;+org/eclipse/ui/contexts/*;+org/eclipse/ui/dialogs/*;+o rg/eclipse/ui/dnd/*;+org/eclipse/ui/fieldassist/*;+org/eclip se/ui/handlers/*;+org/eclipse/ui/help/*;~org/eclipse/ui/inte rnal/*;~org/eclipse/ui/internal/about/*;~org/eclipse/ui/inte rnal/actions/*;~org/eclipse/ui/internal/activities/*;~org/ec lipse/ui/internal/activities/ws/*;~org/eclipse/ui/internal/a pplication/*;~org/eclipse/ui/internal/browser/*;~org/eclipse /ui/internal/commands/*;~org/e
clipse/ui/internal/contexts/*;~org/eclipse/ui/internal/decor ators/*;~org/eclipse/ui/internal/dialogs/*;~org/eclipse/ui/i nternal/dnd/*;~org/eclipse/ui/internal/editorsupport/*;~org/ eclipse/ui/internal/expressions/*;~org/eclipse/ui/internal/h andlers/*;~org/eclipse/ui/internal/help/*;~org/eclipse/ui/in ternal/intro/*;~org/eclipse/ui/internal/keys/*;~org/eclipse/ ui/internal/keys/model/*;~org/eclipse/ui/internal/layout/*;~ org/eclipse/ui/internal/menus/*;~org/eclipse/ui/internal/mis c/*;~org/eclipse/ui/internal/model/*;~org/eclipse/ui/interna l/operations/*;~org/eclipse/ui/internal/part/*;~org/eclipse/ ui/internal/preferences/*;~org/eclipse/ui/internal/presentat ions/*;~org/eclipse/ui/internal/presentations/classic/*;~org /eclipse/ui/internal/presentations/defaultpresentation/*;~or g/eclipse/ui/internal/presentations/util/*;~org/eclipse/ui/i nternal/progress/*;~org/eclipse/ui/internal/provisional/appl ication/*;~org/eclipse/ui/internal/provisional/presentations /*;~org/eclipse/ui/internal/qu
ickaccess/*;~org/eclipse/ui/internal/registry/*;~org/eclipse /ui/internal/services/*;~org/eclipse/ui/internal/splash/*;~o rg/eclipse/ui/internal/statushandlers/*;~org/eclipse/ui/inte rnal/testing/*;~org/eclipse/ui/internal/themes/*;~org/eclips e/ui/internal/tweaklets/*;~org/eclipse/ui/internal/util/*;~o rg/eclipse/ui/internal/wizards/*;~org/eclipse/ui/internal/wi zards/preferences/*;+org/eclipse/ui/intro/*;+org/eclipse/ui/ keys/*;+org/eclipse/ui/menus/*;+org/eclipse/ui/model/*;+org/ eclipse/ui/operations/*;+org/eclipse/ui/part/*;+org/eclipse/ ui/plugin/*;+org/eclipse/ui/preferences/*;+org/eclipse/ui/pr esentations/*;+org/eclipse/ui/progress/*;+org/eclipse/ui/ser vices/*;+org/eclipse/ui/splash/*;+org/eclipse/ui/statushandl ers/*;+org/eclipse/ui/swt/*;+org/eclipse/ui/testing/*;+org/e clipse/ui/themes/*;+org/eclipse/ui/views/*;+org/eclipse/ui/w izards/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.ui. workbench.compatibility_3.2.0.I20080509-2000\compatibility.j ar[+org/eclipse/ui/*;+org/ecli
pse/ui/about/*;+org/eclipse/ui/actions/*;+org/eclipse/ui/act ivities/*;+org/eclipse/ui/application/*;+org/eclipse/ui/bran ding/*;+org/eclipse/ui/browser/*;+org/eclipse/ui/commands/*; +org/eclipse/ui/contexts/*;+org/eclipse/ui/dialogs/*;+org/ec lipse/ui/dnd/*;+org/eclipse/ui/fieldassist/*;+org/eclipse/ui /handlers/*;+org/eclipse/ui/help/*;~org/eclipse/ui/internal/ *;~org/eclipse/ui/internal/about/*;~org/eclipse/ui/internal/ actions/*;~org/eclipse/ui/internal/activities/*;~org/eclipse /ui/internal/activities/ws/*;~org/eclipse/ui/internal/applic ation/*;~org/eclipse/ui/internal/browser/*;~org/eclipse/ui/i nternal/commands/*;~org/eclipse/ui/internal/contexts/*;~org/ eclipse/ui/internal/decorators/*;~org/eclipse/ui/internal/di alogs/*;~org/eclipse/ui/internal/dnd/*;~org/eclipse/ui/inter nal/editorsupport/*;~org/eclipse/ui/internal/expressions/*;~ org/eclipse/ui/internal/handlers/*;~org/eclipse/ui/internal/ help/*;~org/eclipse/ui/internal/intro/*;~org/eclipse/ui/inte rnal/keys/*;~org/eclipse/ui/in
ternal/keys/model/*;~org/eclipse/ui/internal/layout/*;~org/e clipse/ui/internal/menus/*;~org/eclipse/ui/internal/misc/*;~ org/eclipse/ui/internal/model/*;~org/eclipse/ui/internal/ope rations/*;~org/eclipse/ui/internal/part/*;~org/eclipse/ui/in ternal/preferences/*;~org/eclipse/ui/internal/presentations/ *;~org/eclipse/ui/internal/presentations/classic/*;~org/ecli pse/ui/internal/presentations/defaultpresentation/*;~org/ecl ipse/ui/internal/presentations/util/*;~org/eclipse/ui/intern al/progress/*;~org/eclipse/ui/internal/provisional/applicati on/*;~org/eclipse/ui/internal/provisional/presentations/*;~o rg/eclipse/ui/internal/quickaccess/*;~org/eclipse/ui/interna l/registry/*;~org/eclipse/ui/internal/services/*;~org/eclips e/ui/internal/splash/*;~org/eclipse/ui/internal/statushandle rs/*;~org/eclipse/ui/internal/testing/*;~org/eclipse/ui/inte rnal/themes/*;~org/eclipse/ui/internal/tweaklets/*;~org/ecli pse/ui/internal/util/*;~org/eclipse/ui/internal/wizards/*;~o rg/eclipse/ui/internal/wizards
/preferences/*;+org/eclipse/ui/intro/*;+org/eclipse/ui/keys/ *;+org/eclipse/ui/menus/*;+org/eclipse/ui/model/*;+org/eclip se/ui/operations/*;+org/eclipse/ui/part/*;+org/eclipse/ui/pl ugin/*;+org/eclipse/ui/preferences/*;+org/eclipse/ui/present ations/*;+org/eclipse/ui/progress/*;+org/eclipse/ui/services /*;+org/eclipse/ui/splash/*;+org/eclipse/ui/statushandlers/* ;+org/eclipse/ui/swt/*;+org/eclipse/ui/testing/*;+org/eclips e/ui/themes/*;+org/eclipse/ui/views/*;+org/eclipse/ui/wizard s/*;?**/*];C:\DATA\test\eclipse\plugins\com.ibm.icu_3.8.1.v2 0080530.jar[?**/*];C:\DATA\test\eclipse\plugins\org.eclipse. help_3.3.100.v20080610.jar[?**/*];C:\DATA\test\eclipse\plugi ns\org.eclipse.core.expressions_3.4.0.v20080603-2000.jar[?** /*];C:\DATA\test\eclipse\plugins\org.eclipse.jface.databindi ng_1.2.0.I20080515-2000a.jar[?**/*];C:\DATA\test\eclipse\plu gins\org.eclipse.core.databinding_1.1.0.I20080527-2000.jar[? **/*];C:\DATA\test\eclipse\plugins\org.eclipse.core.resource s_3.4.0.v20080604-1400.jar[?**
/*];C:\DATA\test\eclipse\plugins\org.eclipse.core.resources. compatibility_3.4.0.v20080604-1400.jar[?**/*];C:\DATA\test\e clipse\plugins\org.eclipse.core.resources.win32.x86_3.4.0.v2 0071204.jar[?**/*];C:\DATA\test\eclipse\plugins\org.eclipse. ant.core_3.2.0.v20080529.jar[?**/*];C:\DATA\test\eclipse\plu gins\org.eclipse.core.variables_3.2.100.v20080529-1300.jar[? **/*];C:\DATA\test\eclipse\plugins\org.eclipse.core.filesyst em_1.2.0.v20080604-1400.jar[?**/*];C:\DATA\test\eclipse\plug ins\org.eclipse.core.filesystem.win32.x86_1.1.0.v20080604-14 00.jar[?**/*];C:\DATA\test\build\plugins\core\src;C:\DATA\te st\build\plugins\core\test;C:\DATA\test\build\plugins\core\r esource'
> [java] [javac] '-d'
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> arguments are
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> - #5/84]
> - #6/84]
> - #7/84]
> - #8/84]
> - #9/84]
> - #10/84]
> - #11/84]
> (at line 0)
> [java] [javac] ^
> [java] [javac]
>> Hi all,
>> java -jar
>> actually see an InvocationTargetException (see below). But on every
>> subsequent build, it runs out of memory. While running the
>> generateFeature ant target, the script fails because of an
>> OutOfMemoryError. I tried adding -Xmx500 to the build command, and it
>> didn't help.
>> that's related or not. If I can't work this out, we'll have to find
>> another way to build. I desperately don't want to do that, so I would
>> appreciate any help anyone can give me.
>> Thanks!
>> -Matt
>> [java]
>> [java] build.jars:
>> [java]
>> [java] properties:
>> [java]
>> [java] init:
>> [java]
>> [java] @dot:
>> [java] [parsing
>> #1/84]
>> [java]
>> [java] BUILD FAILED
>> [java]
>> [java]
>> [java]
>> [java]
>> [java]
>> [java]
>> [java]
>> [java]
Re: PDE Build failure: OutOfMemoryError: Java heap space [message #22363 is a reply to message #22320] |
Mon, 15 September 2008 20:42   |
I tried upping the memory in numerous places. Mainly, I tried adding
the -Xmx arg to the java task that runs ant on productBuild.xml. I also
tried adding the -Xmx arg to the compileArgs property in the
build.properties that I pass to productBuild.xml. Neither fixed the
problem.
However, I tried a bunch of almost random things today, and it finally
started working. One of the changes I made was setting the ANT_OPTS
environment variable to -Xmx1024M -XX:CompileThreshold=1500 -Xms512M. Does
that sound right? I'm glad it's working now, but I'd still like to get to
the bottom of this so I can prevent the problem in the future.
Matt
"Will Horn" <will.horn@gmail.com> wrote in message
news:gamhsu$jp9$1@build.eclipse.org...
>> build.jars target.
>> [java] build.jars:
>> @dot]
>> zip.src.zip, ]
>> @dot]
>> zip.src.zip, ]
>> [java]
>> [java] properties:
>> [java]
>> [java] init:
>> [java]
>> [java] @dot:
>> exist.
>> [java] [javac]
>> exist.
>> [java] [javac]
>> exist.
>> exist.
>> [java] [javac]
>> exist.
>> to handle it
>> how to handle it
>> how to handle it
>> how to handle it
>> handle it
>> to handle it
>> how to handle it
>> handle it
>> to handle it
>> to handle it
>> handle it
>> handle it
>> to handle it
>> handle it
>> to handle it
>> handle it
>> [java] dropping
>> [java] dropping
>> [java] [javac]
>> [java] [javac] '-d'
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> arguments are
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> C:\DATA\test\build\plugins\core\src\com\etm\AbstractEtmPlugi n.java -
>> #1/84]
>> - #5/84]
>> - #6/84]
>> - #7/84]
>> - #8/84]
>> - #9/84]
>> - #10/84]
>> - #11/84]
>> (at line 0)
>> [java] [javac] ^
>> [java] [javac]
>>> Hi all,
>>> I'm totally lost. I have an automated build that has been working for
>>> java -jar
>>> C:/eclipse/plugins/org.eclipse.equinox.launcher_1.0.100.v200 80509-1800.jar
>>> C:/eclipse/plugins/org.eclipse.pde.build_3.4.0.v20080604/scr ipts/productBuild/productBuild.xml
>>> -Dbuilder=C:/DATA/build/conf
>>> A couple days ago, it started failing. On the first failure, I actually
>>> Also, I don't know if this makes a difference, but I also can't open
>>> Thanks!
>>> -Matt
>>> [java]
>>> [java] build.jars:
>>> [java]
>>> [java] properties:
>>> [java]
>>> [java] init:
>>> [java]
>>> [java] @dot:
>>> [java] [mkdir] Created dir:
>>> [java] [javac] Compiling 84 source files to
>>> [java] [parsing
>>> #1/84]
>>> [java]
>>> [java] BUILD FAILED
>>> [java]
>>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\productBuild\productBuild.xml:29:
>>> The following error occurred while executing this line:
>>> [java]
>>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\build.xml:78:
>>> [java]
>>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\templates\headless-build\customTargets.xml:12:
>>> [java]
>>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\productBuild\allElements.xml:9:
>>> [java]
>>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\genericTargets.xml:95:
>>> [java]
>>> C:\DATA\test\build\features\org.eclipse.pde.build.container. feature\build.xml:94:
>>> [java]
>>> C:\DATA\test\build\features\org.eclipse.pde.build.container. feature\build.xml:20:
>>> [java] C:\DATA\test\build\plugins\core\build.xml:169: The following
>>> [java] C:\DATA\test\build\plugins\core\build.xml:104:
>>> java.lang.reflect.InvocationTargetException
>>> [java]
>>> [java] Total time: 1 minute 51 seconds
Re: PDE Build failure: OutOfMemoryError: Java heap space [message #22367 is a reply to message #22363] |
Tue, 16 September 2008 12:00  |
That sounds exactly right to me. The Ant Java process was running out
of memory and ANT_OPTS is the way to configure its VM parameters.
At least on Windows (but I think everywhere), "ant" is a script that
eventually calls something like "java %ANT_OPTS%". So if you pass -Xmx
to the script it doesn't do anything.
-Will
> problem.
> Does that sound right? I'm glad it's working now, but I'd still like to
> get to the bottom of this so I can prevent the problem in the future.
> Matt
>> Sither wrote:
>>> In addition to the log below, I tried adding the verbose argument to
>>> get more info. I don't see anything suspect, aside from the sudden,
>>> build.jars target.
>>> [java] build.jars:
>>> [java] [available] Unable to find @dot to set property @dot
>>> [java] Project base dir set to: C:\DATA\test\build\plugins\core
>>> [java] [antcall] calling target(s) [@dot] in build file
>>> [java] parsing buildfile
>>> C:\DATA\test\build\plugins\core\build.xml with URI =
>>> [java] Override ignored for property "basews"
>>> [java] Override ignored for property "baseos"
>>> [java] Override ignored for property "basearch"
>>> [java] Property "nl" has not been set
>>> [java] Override ignored for property "basenl"
>>> [java] Override ignored for property "bundleId"
>>> [java] Override ignored for property "bundleVersion"
>>> [java] Override ignored for property "javacFailOnError"
>>> [java] Override ignored for property "javacDebugInfo"
>>> [java] Override ignored for property "javacVerbose"
>>> [java] Override ignored for property "logExtension"
>>> [java] Override ignored for property "compilerArg"
>>> [java] Override ignored for property "javacSource"
>>> [java] Override ignored for property "javacTarget"
>>> [java] Override ignored for property "dir_bootclasspath"
>>> [java] Override ignored for property "bootclasspath"
>>> [java] Override ignored for property "bundleJavacSource"
>>> [java] Override ignored for property "bundleJavacTarget"
>>> [java] Override ignored for property "bundleBootClasspath"
>>> [java] Build sequence for target(s) `@dot' is [properties, init,
>>> @dot]
>>> [java] Complete build sequence is [properties, init, @dot,
>>> build.sources, gather.individual.sources, gather.sources, clean,
>>> copy.src.includes, zip.src.zip, ]
>>> [java] [antcall] Entering
>>> C:\DATA\test\build\plugins\core\build.xml...
>>> @dot]
>>> [java]
>>> [java] properties:
>>> [java] Override ignored for property "build.compiler"
>>> [java]
>>> [java] init:
>>> [java] Property "buildTempFolder" has not been set
>>> [java] Override ignored for property "pluginTemp"
>>> [java] Override ignored for property "build.result.folder"
>>> [java] Override ignored for property "temp.folder"
>>> [java] Override ignored for property "plugin.destination"
>>> [java]
>>> [java] @dot:
>>> [java] [javac] com\etm\AbstractEtmPlugin.java added as
>>> com\etm\AbstractEtmPlugin.class doesn't exist.
>>> [java] [javac] com\etm\EtmCore.java added as
>>> [java] [javac] com\etm\EtmLogger.java added as
>>> com\etm\EtmLogger.class doesn't exist.
>>> [java] [javac] com\etm\EtmPlugin.java added as
>>> com\etm\EtmPlugin.class doesn't exist.
>>> [java] [javac]
>>> com\etm\application\AbstractApplicationModule.class doesn't exist.
>>> [java] [javac] com\etm\application\AbstractWorkspace.java
>>> added as com\etm\application\AbstractWorkspace.class doesn't exist.
>>> [java] [javac]
>>> com\etm\application\ApplicationEnvironment.java added as
>>> com\etm\application\ApplicationEnvironment.class doesn't exist.
>>> [java] [javac] com\etm\application\ApplicationException.java
>>> [java] [javac] com\etm\application\DefaultApplication.java
>>> added as com\etm\application\DefaultApplication.class doesn't exist.
>>> [java] [javac]
>>> com\etm\application\IApplicationEnvironmentFactory.java added as
>>> com\etm\application\IApplicationEnvironmentFactory.class doesn't exist.
>>> [java] [javac] com\etm\application\IRepository.java added as
>>> com\etm\application\IRepository.class doesn't exist.
>>> [java] [javac] com\etm\application\LocalRepository.java added
>>> as com\etm\application\LocalRepository.class doesn't exist.
>>> [java] [javac] com\etm\application\Workspace.java added as
>>> com\etm\application\Workspace.class doesn't exist.
>>> [java] [javac] com\etm\application\WorkspaceState.java added
>>> as com\etm\application\WorkspaceState.class doesn't exist.
>>> [java] [javac]
>>> com\etm\application\module\IApplicationModule.class doesn't exist.
>>> [java] [javac]
>>> com\etm\application\module\IApplicationModuleListener.java added as
>>> com\etm\application\module\IApplicationModuleListener.class doesn't
>>> exist.
>>> [java] [javac] com\etm\cache\Cache.java added as
>>> com\etm\cache\Cache.class doesn't exist.
>>> [java] [javac] com\etm\cache\CacheListener.java added as
>>> com\etm\cache\CacheListener.class doesn't exist.
>>> [java] [javac] com\etm\cache\ImageCache.java added as
>>> com\etm\cache\ImageCache.class doesn't exist.
>>> [java] [javac] com\etm\event\CardEvent.java added as
>>> com\etm\event\CardEvent.class doesn't exist.
>>> [java] [javac] com\etm\event\Event.java added as
>>> com\etm\event\Event.class doesn't exist.
>>> [java] [javac] com\etm\event\EventHistory.java added as
>>> com\etm\event\EventHistory.class doesn't exist.
>>> [java] [javac] com\etm\event\EventListener.java added as
>>> com\etm\event\EventListener.class doesn't exist.
>>> [java] [javac] com\etm\event\EventProducer.java added as
>>> com\etm\event\EventProducer.class doesn't exist.
>>> [java] [javac] com\etm\event\EventRelay.java added as
>>> com\etm\event\EventRelay.class doesn't exist.
>>> [java] [javac] com\etm\model\Access.java added as
>>> com\etm\model\Access.class doesn't exist.
>>> [java] [javac] com\etm\model\CardModel.java added as
>>> com\etm\model\CardModel.class doesn't exist.
>>> [java] [javac] com\etm\model\Comment.java added as
>>> com\etm\model\Comment.class doesn't exist.
>>> [java] [javac] com\etm\model\ExternalizableJaxObject.java
>>> added as com\etm\model\ExternalizableJaxObject.class doesn't exist.
>>> [java] [javac] com\etm\model\Modifiable.java added as
>>> com\etm\model\Modifiable.class doesn't exist.
>>> [java] [javac] com\etm\model\Note.java added as
>>> com\etm\model\Note.class doesn't exist.
>>> [java] [javac] com\etm\model\Summary.java added as
>>> com\etm\model\Summary.class doesn't exist.
>>> [java] [javac] com\etm\model\attachment\Attachment.java added
>>> as com\etm\model\attachment\Attachment.class doesn't exist.
>>> [java] [javac]
>>> com\etm\model\attachment\AttachmentListener.java added as
>>> com\etm\model\attachment\AttachmentListener.class doesn't exist.
>>> [java] [javac] com\etm\model\attachment\MimeType.java added
>>> as com\etm\model\attachment\MimeType.class doesn't exist.
>>> [java] [javac] com\etm\model\event\CardUpdate.java added as
>>> com\etm\model\event\CardUpdate.class doesn't exist.
>>> [java] [javac] com\etm\model\event\IPropertyListener.java
>>> added as com\etm\model\event\IPropertyListener.class doesn't exist.
>>> [java] [javac] com\etm\model\event\PropertyEventType.java
>>> added as com\etm\model\event\PropertyEventType.class doesn't exist.
>>> [java] [javac] com\etm\model\event\PropertyUpdate.java added
>>> as com\etm\model\event\PropertyUpdate.class doesn't exist.
>>> [java] [javac]
>>> com\etm\model\property\AbstractScopedProperty.class doesn't exist.
>>> [java] [javac] com\etm\model\property\ComplexProperty.java
>>> added as com\etm\model\property\ComplexProperty.class doesn't exist.
>>> [java] [javac] com\etm\model\property\CopyOfPropertyType.java
>>> [java] [javac]
>>> com\etm\model\property\MultiComplexProperty.java added as
>>> com\etm\model\property\MultiComplexProperty.class doesn't exist.
>>> [java] [javac] com\etm\model\property\MultiValueProperty.java
>>> [java] [javac] com\etm\model\property\Property.java added as
>>> com\etm\model\property\Property.class doesn't exist.
>>> [java] [javac] com\etm\model\property\PropertyInfo.java added
>>> as com\etm\model\property\PropertyInfo.class doesn't exist.
>>> [java] [javac] com\etm\model\property\PropertyType.java added
>>> as com\etm\model\property\PropertyType.class doesn't exist.
>>> [java] [javac] com\etm\model\property\PropertyTypes.java
>>> added as com\etm\model\property\PropertyTypes.class doesn't exist.
>>> [java] [javac] com\etm\model\property\SimpleProperty.java
>>> added as com\etm\model\property\SimpleProperty.class doesn't exist.
>>> [java] [javac] com\etm\model\property\UserScopedProperty.java
>>> [java] [javac]
>>> com\etm\model\property\WorkspaceScopedProperty.class doesn't exist.
>>> [java] [javac]
>>> com\etm\model\property\event\PropertyUpdater.java added as
>>> com\etm\model\property\event\PropertyUpdater.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlCards.java added as
>>> com\etm\model\xml\XmlCards.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlError.java added as
>>> com\etm\model\xml\XmlError.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlList.java added as
>>> com\etm\model\xml\XmlList.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlListListener.java added
>>> as com\etm\model\xml\XmlListListener.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlMapping.java added as
>>> com\etm\model\xml\XmlMapping.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlStackTraceElement.java
>>> added as com\etm\model\xml\XmlStackTraceElement.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlWrapper.java added as
>>> com\etm\model\xml\XmlWrapper.class doesn't exist.
>>> [java] [javac] com\etm\service\AttachmentService.java added
>>> as com\etm\service\AttachmentService.class doesn't exist.
>>> [java] [javac] com\etm\service\EtmService.java added as
>>> com\etm\service\EtmService.class doesn't exist.
>>> [java] [javac] com\etm\service\EtmServices.java added as
>>> com\etm\service\EtmServices.class doesn't exist.
>>> [java] [javac] com\etm\service\UrlInputStream.java added as
>>> com\etm\service\UrlInputStream.class doesn't exist.
>>> [java] [javac] com\etm\util\FileUtils.java added as
>>> com\etm\util\FileUtils.class doesn't exist.
>>> [java] [javac] com\etm\util\ImageUtils.java added as
>>> com\etm\util\ImageUtils.class doesn't exist.
>>> [java] [javac] com\etm\util\ImportExportUtils.java added as
>>> com\etm\util\ImportExportUtils.class doesn't exist.
>>> [java] [javac] com\etm\util\LocaleUtils.java added as
>>> com\etm\util\LocaleUtils.class doesn't exist.
>>> [java] [javac] com\etm\util\MhtmlUtils.java added as
>>> com\etm\util\MhtmlUtils.class doesn't exist.
>>> [java] [javac] com\etm\util\UrlUtils.java added as
>>> com\etm\util\UrlUtils.class doesn't exist.
>>> [java] [javac] com\etm\util\XmlUtils.java added as
>>> com\etm\util\XmlUtils.class doesn't exist.
>>> [java] [javac] com\etm\util\ZipUtility.java added as
>>> com\etm\util\ZipUtility.class doesn't exist.
>>> [java] [javac] com\etm\CoreTests.java added as
>>> com\etm\CoreTests.class doesn't exist.
>>> [java] [javac] com\etm\MockBundle.java added as
>>> com\etm\MockBundle.class doesn't exist.
>>> [java] [javac] com\etm\MockBundleContext.java added as
>>> com\etm\MockBundleContext.class doesn't exist.
>>> [java] [javac] com\etm\application\WorkspaceIOTest.java added
>>> as com\etm\application\WorkspaceIOTest.class doesn't exist.
>>> [java] [javac] com\etm\application\WorkspaceTest.java added
>>> as com\etm\application\WorkspaceTest.class doesn't exist.
>>> [java] [javac] com\etm\event\MockEventListener.java added as
>>> com\etm\event\MockEventListener.class doesn't exist.
>>> [java] [javac] com\etm\model\BasicCardModel.java added as
>>> com\etm\model\BasicCardModel.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlErrorTest.java added as
>>> com\etm\model\xml\XmlErrorTest.class doesn't exist.
>>> [java] [javac] com\etm\repository\LocalRepositoryTest.java
>>> added as com\etm\repository\LocalRepositoryTest.class doesn't exist.
>>> [java] [javac] com\etm\util\FileUtilsTest.java added as
>>> com\etm\util\FileUtilsTest.class doesn't exist.
>>> [java] [javac] com\etm\util\MhtmlUtilsTest.java added as
>>> com\etm\util\MhtmlUtilsTest.class doesn't exist.
>>> [java] [javac] com\etm\util\TestUtils.java added as
>>> com\etm\util\TestUtils.class doesn't exist.
>>> [java] [javac] com\etm\util\XmlUtilsTest.java added as
>>> com\etm\util\XmlUtilsTest.class doesn't exist.
>>> [java] [javac] EvtmResources.properties skipped - don't know
>>> how to handle it
>>> [java] [javac] filters\api\googleMaps.xml skipped - don't
>>> know how to handle it
>>> [java] [javac] filters\api\yahooMapImage.xml skipped - don't
>>> [java] [javac] filters\api\yahooWeather.new.xml skipped -
>>> don't know how to handle it
>>> [java] [javac] filters\api\yahooWeather.xml skipped - don't
>>> [java] [javac] log4j.properties skipped - don't know how to
>>> handle it
>>> [java] [javac] test\filter\amazon.html skipped - don't know
>>> how to handle it
>>> [java] [javac] test\filter\craigslist.html skipped - don't
>>> [java] [javac] test\filter\ebay.html skipped - don't know how
>>> to handle it
>>> [java] [javac] test\filter\netflix.html skipped - don't know
>>> how to handle it
>>> [java] [javac] test\filter\weather.html skipped - don't know
>>> how to handle it
>>> [java] [javac] test\images\logo.gif skipped - don't know how
>>> to handle it
>>> [java] [javac] test\repo\test.txt skipped - don't know how to
>>> handle it
>>> [java] [javac] test\workspaces\ebay.ews skipped - don't know
>>> how to handle it
>>> [java] [javac] test\xquery\cnn.xhtml skipped - don't know how
>>> to handle it
>>> [java] [javac] test\zip\images\logo.gif skipped - don't know
>>> how to handle it
>>> [java] [javac] test\zip\test.txt skipped - don't know how to
>>> handle it
>>> [java] [javac] Using JDT compiler
>>> [java] dropping
>>> C:\DATA\test\eclipse\plugins\org.eclipse.core.runtime.compat ibility.registry_3.2.200.v20080610\@dot
>>> from path as it doesn't exist
>>> [java] dropping
>>> C:\DATA\test\eclipse\plugins\org.eclipse.ui.workbench.compat ibility_3.2.0.I20080509-2000\@dot
>>> [java] [javac] Compilation arguments:
>>> [java] [javac] '-noExit'
>>> [java] [javac] '-bootclasspath'
>>> [java] [javac] 'C:\Program Files
>>> (x86)\Java\jdk1.6.0\jre\lib\charsets.jar;C:\Program Files
>>> (x86)\Java\jdk1.6.0\jre\lib\deploy.jar;C:\Program Files
>>> (x86)\Java\jdk1.6.0\jre\lib\javaws.jar;C:\Program Files
>>> (x86)\Java\jdk1.6.0\jre\lib\jce.jar;C:\Program Files
>>> (x86)\Java\jdk1.6.0\jre\lib\jsse.jar;C:\Program Files
>>> (x86)\Java\jdk1.6.0\jre\lib\management-agent.jar;C:\Program Files
>>> (x86)\Java\jdk1.6.0\jre\lib\plugin.jar;C:\Program Files
>>> (x86)\Java\jdk1.6.0\jre\lib\resources.jar;C:\Program Files
>>> (x86)\Java\jdk1.6.0\jre\lib\rt.jar'
>>> [java] [javac] '-classpath'
>>> [java] [javac]
>>> 'C:\DATA\test\build\plugins\core\temp.folder\@dot.bin;C:\DAT A\test\eclipse\plugins\org.eclipse.swt_3.4.0.v3448f.jar[+org /eclipse/swt/*;+org/eclipse/swt/accessibility/*;+org/eclipse /swt/awt/*;+org/eclipse/swt/browser/*;+org/eclipse/swt/custo m/*;+org/eclipse/swt/dnd/*;+org/eclipse/swt/events/*;+org/ec lipse/swt/graphics/*;+org/eclipse/swt/layout/*;+org/eclipse/ swt/opengl/*;+org/eclipse/swt/printing/*;+org/eclipse/swt/pr ogram/*;+org/eclipse/swt/widgets/*;~org/eclipse/swt/internal /*;~org/eclipse/swt/internal/image/*;~org/eclipse/swt/intern al/theme/*;+org/eclipse/swt/ole/win32/*;~org/eclipse/swt/int ernal/gdip/*;~org/eclipse/swt/internal/ole/win32/*;~org/ecli pse/swt/internal/win32/*;~org/eclipse/swt/internal/opengl/wi n32/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.swt.wi n32.win32.x86_3.4.0.v3448f.jar[+org/eclipse/swt/*;+org/eclip se/swt/accessibility/*;+org/eclipse/swt/awt/*;+org/eclipse/s wt/browser/*;+org/eclipse/swt/custom/*;+org/eclipse/swt/dnd/ *;+org/eclipse/swt/events
cali
roto
ecli
re/r
..8.2
200
core
rg/e
l/qu
ecli
i/in
ards
>>> [java] [javac] '-d'
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> arguments are
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> #1/84]
>>> - #5/84]
>>> - #6/84]
>>> - #7/84]
>>> - #8/84]
>>> - #9/84]
>>> - #10/84]
>>> - #11/84]
>>> (at line 0)
>>> [java] [javac] ^
>>> [java] [javac]
>>>> Hi all,
>>>> for about a month now using this command to build:
>>>> java -jar
>>>> it didn't help.
>>>> would appreciate any help anyone can give me.
>>>> Thanks!
>>>> -Matt
>>>> [java]
>>>> [java] build.jars:
>>>> [java]
>>>> [java] properties:
>>>> [java]
>>>> [java] init:
>>>> [java]
>>>> [java] @dot:
>>>> [java] [parsing
>>>> #1/84]
>>>> [java]
>>>> [java] BUILD FAILED
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
Re: PDE Build failure: OutOfMemoryError: Java heap space [message #580483 is a reply to message #22073] |
Mon, 15 September 2008 15:02  |
In addition to the log below, I tried adding the verbose argument to get
more info. I don't see anything suspect, aside from the sudden, seemingly
untraceable OutOfMemoryError. But maybe this output means something to
someone in this group. Here it is, starting with the build.jars target.
[java] build.jars:
[java] parsing buildfile C:\DATA\test\build\plugins\core\build.xml with
[java] Build sequence for target(s) `@dot' is [properties, init, @dot]
[java] Complete build sequence is [properties, init, @dot, zip.plugin,
copy.src.zip, refresh, gather.logs, build.jars, build.update.jar, src.zip,
gather.bin.parts, build.zips, build.sources, gather.individual.sources,
gather.sources, clean, copy.src.includes, zip.src.zip, ]
[java]
[java] properties:
[java]
[java] init:
[java]
[java] @dot:
[java] [javac] com\etm\EtmCore.java added as com\etm\EtmCore.class
doesn't exist.
[java] [javac] com\etm\application\AbstractApplicationModule.java
added as com\etm\application\AbstractApplicationModule.class doesn't exist.
[java] [javac] com\etm\application\AbstractWorkspace.java added as
[java] [javac] com\etm\application\ApplicationEnvironment.java
added as com\etm\application\ApplicationEnvironment.class doesn't exist.
[java] [javac] com\etm\application\ApplicationException.java added
[java] [javac] com\etm\application\DefaultApplication.java added as
[java] [javac]
[java] [javac] com\etm\application\LocalRepository.java added as
[java] [javac] com\etm\application\WorkspaceState.java added as
[java] [javac] com\etm\application\module\IApplicationModule.java
added as com\etm\application\module\IApplicationModule.class doesn't exist.
[java] [javac]
com\etm\application\module\IApplicationModuleListener.class doesn't exist.
[java] [javac] com\etm\model\ExternalizableJaxObject.java added as
[java] [javac] com\etm\model\attachment\Attachment.java added as
[java] [javac] com\etm\model\attachment\AttachmentListener.java
added as com\etm\model\attachment\AttachmentListener.class doesn't exist.
[java] [javac] com\etm\model\attachment\MimeType.java added as
[java] [javac] com\etm\model\event\IPropertyListener.java added as
[java] [javac] com\etm\model\event\PropertyEventType.java added as
[java] [javac] com\etm\model\event\PropertyUpdate.java added as
[java] [javac] com\etm\model\property\AbstractScopedProperty.java
added as com\etm\model\property\AbstractScopedProperty.class doesn't exist.
[java] [javac] com\etm\model\property\ComplexProperty.java added as
[java] [javac] com\etm\model\property\CopyOfPropertyType.java added
[java] [javac] com\etm\model\property\MultiComplexProperty.java
added as com\etm\model\property\MultiComplexProperty.class doesn't exist.
[java] [javac] com\etm\model\property\MultiValueProperty.java added
[java] [javac] com\etm\model\property\PropertyInfo.java added as
[java] [javac] com\etm\model\property\PropertyType.java added as
[java] [javac] com\etm\model\property\PropertyTypes.java added as
[java] [javac] com\etm\model\property\SimpleProperty.java added as
[java] [javac] com\etm\model\property\UserScopedProperty.java added
[java] [javac] com\etm\model\property\WorkspaceScopedProperty.java
added as com\etm\model\property\WorkspaceScopedProperty.class doesn't exist.
[java] [javac] com\etm\model\property\event\PropertyUpdater.java
added as com\etm\model\property\event\PropertyUpdater.class doesn't exist.
[java] [javac] com\etm\model\xml\XmlListListener.java added as
[java] [javac] com\etm\model\xml\XmlStackTraceElement.java added as
[java] [javac] com\etm\service\AttachmentService.java added as
[java] [javac] com\etm\application\WorkspaceIOTest.java added as
[java] [javac] com\etm\application\WorkspaceTest.java added as
[java] [javac] com\etm\repository\LocalRepositoryTest.java added as
[java] [javac] EvtmResources.properties skipped - don't know how to
handle it
[java] [javac] filters\api\googleMaps.xml skipped - don't know how
to handle it
[java] [javac] filters\api\yahooMapImage.xml skipped - don't know
how to handle it
[java] [javac] filters\api\yahooWeather.new.xml skipped - don't
[java] [javac] filters\api\yahooWeather.xml skipped - don't know
how to handle it
[java] [javac] log4j.properties skipped - don't know how to handle
it
[java] [javac] test\filter\amazon.html skipped - don't know how to
handle it
[java] [javac] test\filter\craigslist.html skipped - don't know how
to handle it
[java] [javac] test\filter\ebay.html skipped - don't know how to
handle it
[java] [javac] test\filter\netflix.html skipped - don't know how to
handle it
[java] [javac] test\filter\weather.html skipped - don't know how to
handle it
[java] [javac] test\images\logo.gif skipped - don't know how to
handle it
handle it
[java] [javac] test\workspaces\ebay.ews skipped - don't know how to
handle it
[java] [javac] test\xquery\cnn.xhtml skipped - don't know how to
handle it
[java] [javac] test\zip\images\logo.gif skipped - don't know how to
handle it
[java] [javac] test\zip\test.txt skipped - don't know how to handle
it
[java] dropping
[java] dropping
[java] [javac]
'C:\DATA\test\build\plugins\core\temp.folder\@dot.bin;C:\DAT A\test\eclipse\plugins\org.eclipse.swt_3.4.0.v3448f.jar[+org /eclipse/swt/*;+org/eclipse/swt/accessibility/*;+org/eclipse /swt/awt/*;+org/eclipse/swt/browser/*;+org/eclipse/swt/custo m/*;+org/eclipse/swt/dnd/*;+org/eclipse/swt/events/*;+org/ec lipse/swt/graphics/*;+org/eclipse/swt/layout/*;+org/eclipse/ swt/opengl/*;+org/eclipse/swt/printing/*;+org/eclipse/swt/pr ogram/*;+org/eclipse/swt/widgets/*;~org/eclipse/swt/internal /*;~org/eclipse/swt/internal/image/*;~org/eclipse/swt/intern al/theme/*;+org/eclipse/swt/ole/win32/*;~org/eclipse/swt/int ernal/gdip/*;~org/eclipse/swt/internal/ole/win32/*;~org/ecli pse/swt/internal/win32/*;~org/eclipse/swt/internal/opengl/wi n32/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.swt.wi n32.win32.x86_3.4.0.v3448f.jar[+org/eclipse/swt/*;+org/eclip se/swt/accessibility/*;+org/eclipse/swt/awt/*;+org/eclipse/s wt/browser/*;+org/eclipse/swt/custom/*;+org/eclipse/swt/dnd/ *;+org/eclipse/swt/events/*;+org/eclipse/swt/graphics/*;+org /eclipse/swt/layout/*;+org/eclipse/swt/opengl/*;+org/eclipse /swt/printing/*;+org/eclipse/swt/program/*;+org/eclipse/swt/ widgets/*;~org/eclipse/swt/internal/*;~org/eclipse/swt/inter nal/image/*;~org/eclipse/swt/internal/theme/*;+org/eclipse/s wt/ole/win32/*;~org/eclipse/swt/internal/gdip/*;~org/eclipse /swt/internal/ole/win32/*;~org/eclipse/swt/internal/win32/*; ~org/eclipse/swt/internal/opengl/win32/*;?**/*];C:\DATA\test \eclipse\plugins\org.eclipse.core.runtime_3.4.0.v20080512.ja r[~org/eclipse/core/internal/preferences/legacy/*;~org/eclip se/core/internal/runtime/*;+org/eclipse/core/runtime/*;?**/* ];C:\DATA\test\eclipse\plugins\org.eclipse.osgi_3.4.0.v20080 605-1900.jar[+org/eclipse/osgi/event/*;+org/eclipse/osgi/fra mework/console/*;+org/eclipse/osgi/framework/eventmgr/*;+org /eclipse/osgi/framework/log/*;+org/eclipse/osgi/service/data location/*;+org/eclipse/osgi/service/debug/*;+org/eclipse/os gi/service/environment/*;+org/eclipse/osgi/service/localizat ion/*;+org/eclipse/osgi/service/pluginconversion/*;+org/ecli pse/osgi/service/resolver/*;+org/eclipse/osgi/service/runnab le/*;+org/eclipse/osgi/service/security/*;+org/eclipse/osgi/ service/urlconversion/*;+org/eclipse/osgi/signedcontent/*;+o rg/eclipse/osgi/storagemanager/*;+org/eclipse/osgi/util/*;+o rg/osgi/framework/*;+org/osgi/service/condpermadmin/*;+org/o sgi/service/packageadmin/*;+org/osgi/service/permissionadmin /*;+org/osgi/service/startlevel/*;+org/osgi/service/url/*;+o rg/osgi/util/tracker/*;~org/eclipse/core/runtime/adaptor/*;~ org/eclipse/core/runtime/internal/adaptor/*;~org/eclipse/cor e/runtime/internal/stats/*;~org/eclipse/osgi/baseadaptor/*;~ org/eclipse/osgi/baseadaptor/bundlefile/*;~org/eclipse/osgi/ baseadaptor/hooks/*;~org/eclipse/osgi/baseadaptor/loader/*;~ org/eclipse/osgi/framework/adaptor/*;~org/eclipse/osgi/frame work/debug/*;~org/eclipse/osgi/framework/internal/core/*;~or g/eclipse/osgi/framework/internal/protocol/*;~org/eclipse/os gi/framework/internal/protocol/bundleentry/*;~org/eclipse/os gi/framework/internal/protocol/bundleresource/*;~org/eclipse /osgi/framework/internal/protocol/reference/*;~org/eclipse/o sgi/framework/internal/reliablefile/*;~org/eclipse/osgi/fram ework/launcher/*;~org/eclipse/osgi/framework/util/*;~org/ecl ipse/osgi/internal/baseadaptor/*;~org/eclipse/osgi/internal/ module/*;~org/eclipse/osgi/internal/profile/*;~org/eclipse/o sgi/internal/resolver/*;~org/eclipse/osgi/internal/provision al/service/security/*;~org/eclipse/osgi/internal/provisional /verifier/*;~org/eclipse/osgi/internal/service/security/*;~o rg/eclipse/osgi/internal/signedcontent/*;?**/*];C:\DATA\test \eclipse\plugins\org.eclipse.equinox.common_3.4.0.v20080421- 2006.jar[~org/eclipse/core/internal/boot/*;~org/eclipse/core /internal/runtime/*;+org/eclipse/core/runtime/*;?**/*];C:\DA TA\test\eclipse\plugins\org.eclipse.core.jobs_3.4.0.v2008051 2.jar[~org/eclipse/core/internal/jobs/*;+org/eclipse/core/ru ntime/jobs/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse .core.runtime.compatibility.registry_3.2.200.v20080610\runti me_registry_compatibility.jar[~org/eclipse/core/internal/ada pter/*;~org/eclipse/core/internal/registry/*;~org/eclipse/co re/internal/registry/osgi/*;~org/eclipse/core/internal/regis try/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/core/runt ime/dynamichelpers/*;+org/eclipse/core/runtime/spi/*;?**/*]; C:\DATA\test\eclipse\plugins\org.eclipse.core.runtime.compat ibility.registry_3.2.200.v20080610[~org/eclipse/core/interna l/adapter/*;~org/eclipse/core/internal/registry/*;~org/eclip se/core/internal/registry/osgi/*;~org/eclipse/core/internal/ registry/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/core /runtime/dynamichelpers/*;+org/eclipse/core/runtime/spi/*;?* */*];C:\DATA\test\eclipse\plugins\org.eclipse.equinox.regist ry_3.4.0.v20080516-0950.jar[~org/eclipse/core/internal/adapt er/*;~org/eclipse/core/internal/registry/*;~org/eclipse/core /internal/registry/osgi/*;~org/eclipse/core/internal/registr y/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/core/runtim e/dynamichelpers/*;+org/eclipse/core/runtime/spi/*;?**/*];C: \DATA\test\eclipse\plugins\org.eclipse.equinox.preferences_3 .2.200.v20080421-2006.jar[~org/eclipse/core/internal/prefere nces/*;~org/eclipse/core/internal/preferences/exchange/*;+or g/eclipse/core/runtime/preferences/*;+org/osgi/service/prefs /*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.core.cont enttype_3.3.0.v20080604-1400.jar[~org/eclipse/core/internal/ content/*;+org/eclipse/core/runtime/content/*;?**/*];C:\DATA \test\eclipse\plugins\org.eclipse.core.runtime.compatibility .auth_3.2.100.v20070502.jar[?**/*];C:\DATA\test\eclipse\plug ins\org.eclipse.equinox.app_1.1.0.v20080421-2006.jar[+org/ec lipse/equinox/app/*;~org/eclipse/equinox/internal/app/*;+org /osgi/service/application/*;?**/*];C:\DATA\test\eclipse\plug ins\org.eclipse.osgi.services_3.1.200.v20071203.jar[?**/*];C :\DATA\test\eclipse\plugins\javax.servlet_2.4.0.v20080603160 4.jar[?**/*];C:\DATA\test\eclipse\plugins\org.junit_3.8.2.v2 0080602-1318\junit.jar[+junit/awtui/*;+junit/extensions/*;+j unit/framework/*;+junit/runner/*;+junit/swingui/*;+junit/swi ngui/icons/*;+junit/textui/*;?**/*];C:\DATA\test\eclipse\plu gins\org.apache.log4j_1.2.13.v200806030600.jar[+org/apache/l og4j/*;+org/apache/log4j/chainsaw/*;+org/apache/log4j/config /*;+org/apache/log4j/helpers/*;+org/apache/log4j/jdbc/*;+org /apache/log4j/jmx/*;+org/apache/log4j/lf5/*;+org/apache/log4 j/lf5/config/*;+org/apache/log4j/lf5/util/*;+org/apache/log4 j/lf5/viewer/*;+org/apache/log4j/lf5/viewer/categoryexplorer /*;+org/apache/log4j/lf5/viewer/configure/*;+org/apache/log4 j/lf5/viewer/images/*;+org/apache/log4j/net/*;+org/apache/lo g4j/nt/*;+org/apache/log4j/or/*;+org/apache/log4j/or/jms/*;+ org/apache/log4j/or/sax/*;+org/apache/log4j/spi/*;+org/apach e/log4j/varia/*;+org/apache/log4j/xml/*;?**/*];C:\DATA\test\ eclipse\plugins\org.eclipse.ui_3.4.0.I20080610-1200.jar[~org /eclipse/ui/internal/*;?**/*];C:\DATA\test\eclipse\plugins\o rg.eclipse.jface_3.4.0.I20080606-1300.jar[+org/eclipse/jface /*;+org/eclipse/jface/action/*;+org/eclipse/jface/action/ima ges/*;+org/eclipse/jface/bindings/*;+org/eclipse/jface/bindi ngs/keys/*;+org/eclipse/jface/bindings/keys/formatting/*;+or g/eclipse/jface/commands/*;+org/eclipse/jface/contexts/*;+or g/eclipse/jface/dialogs/*;+org/eclipse/jface/dialogs/images/ *;+org/eclipse/jface/fieldassist/*;+org/eclipse/jface/fielda ssist/images/*;+org/eclipse/jface/images/*;~org/eclipse/jfac e/internal/*;~org/eclipse/jface/internal/provisional/action/ *;+org/eclipse/jface/layout/*;+org/eclipse/jface/menus/*;+or g/eclipse/jface/operation/*;+org/eclipse/jface/preference/*; +org/eclipse/jface/preference/images/*;+org/eclipse/jface/re source/*;+org/eclipse/jface/util/*;+org/eclipse/jface/viewer s/*;+org/eclipse/jface/viewers/deferred/*;+org/eclipse/jface /window/*;+org/eclipse/jface/wizard/*;+org/eclipse/jface/wiz ard/images/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse .core.commands_3.4.0.I20080509-2000.jar[+org/eclipse/core/co mmands/*;+org/eclipse/core/commands/common/*;+org/eclipse/co re/commands/contexts/*;+org/eclipse/core/commands/operations /*;+org/eclipse/core/commands/util/*;~org/eclipse/core/inter nal/commands/operations/*;~org/eclipse/core/internal/command s/util/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.ui. workbench_3.4.0.I20080606-1300.jar[+org/eclipse/ui/*;+org/ec lipse/ui/about/*;+org/eclipse/ui/actions/*;+org/eclipse/ui/a ctivities/*;+org/eclipse/ui/application/*;+org/eclipse/ui/br anding/*;+org/eclipse/ui/browser/*;+org/eclipse/ui/commands/ *;+org/eclipse/ui/contexts/*;+org/eclipse/ui/dialogs/*;+org/ eclipse/ui/dnd/*;+org/eclipse/ui/fieldassist/*;+org/eclipse/ ui/handlers/*;+org/eclipse/ui/help/*;~org/eclipse/ui/interna l/*;~org/eclipse/ui/internal/about/*;~org/eclipse/ui/interna l/actions/*;~org/eclipse/ui/internal/activities/*;~org/eclip se/ui/internal/activities/ws/*;~org/eclipse/ui/internal/appl ication/*;~org/eclipse/ui/internal/browser/*;~org/eclipse/ui /internal/commands/*;~org/eclipse/ui/internal/contexts/*;~or g/eclipse/ui/internal/decorators/*;~org/eclipse/ui/internal/ dialogs/*;~org/eclipse/ui/internal/dnd/*;~org/eclipse/ui/int ernal/editorsupport/*;~org/eclipse/ui/internal/expressions/* ;~org/eclipse/ui/internal/handlers/*;~org/eclipse/ui/interna l/help/*;~org/eclipse/ui/internal/intro/*;~org/eclipse/ui/in ternal/keys/*;~org/eclipse/ui/internal/keys/model/*;~org/ecl ipse/ui/internal/layout/*;~org/eclipse/ui/internal/menus/*;~ org/eclipse/ui/internal/misc/*;~org/eclipse/ui/internal/mode l/*;~org/eclipse/ui/internal/operations/*;~org/eclipse/ui/in ternal/part/*;~org/eclipse/ui/internal/preferences/*;~org/ec lipse/ui/internal/presentations/*;~org/eclipse/ui/internal/p resentations/classic/*;~org/eclipse/ui/internal/presentation s/defaultpresentation/*;~org/eclipse/ui/internal/presentatio ns/util/*;~org/eclipse/ui/internal/progress/*;~org/eclipse/u i/internal/provisional/application/*;~org/eclipse/ui/interna l/provisional/presentations/*;~org/eclipse/ui/internal/quick access/*;~org/eclipse/ui/internal/registry/*;~org/eclipse/ui /internal/services/*;~org/eclipse/ui/internal/splash/*;~org/ eclipse/ui/internal/statushandlers/*;~org/eclipse/ui/interna l/testing/*;~org/eclipse/ui/internal/themes/*;~org/eclipse/u i/internal/tweaklets/*;~org/eclipse/ui/internal/util/*;~org/ eclipse/ui/internal/wizards/*;~org/eclipse/ui/internal/wizar ds/preferences/*;+org/eclipse/ui/intro/*;+org/eclipse/ui/key s/*;+org/eclipse/ui/menus/*;+org/eclipse/ui/model/*;+org/ecl ipse/ui/operations/*;+org/eclipse/ui/part/*;+org/eclipse/ui/ plugin/*;+org/eclipse/ui/preferences/*;+org/eclipse/ui/prese ntations/*;+org/eclipse/ui/progress/*;+org/eclipse/ui/servic es/*;+org/eclipse/ui/splash/*;+org/eclipse/ui/statushandlers /*;+org/eclipse/ui/swt/*;+org/eclipse/ui/testing/*;+org/ecli pse/ui/themes/*;+org/eclipse/ui/views/*;+org/eclipse/ui/wiza rds/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.ui.wor kbench.compatibility_3.2.0.I20080509-2000\compatibility.jar[ +org/eclipse/ui/*;+org/eclipse/ui/about/*;+org/eclipse/ui/ac tions/*;+org/eclipse/ui/activities/*;+org/eclipse/ui/applica tion/*;+org/eclipse/ui/branding/*;+org/eclipse/ui/browser/*; +org/eclipse/ui/commands/*;+org/eclipse/ui/contexts/*;+org/e clipse/ui/dialogs/*;+org/eclipse/ui/dnd/*;+org/eclipse/ui/fi eldassist/*;+org/eclipse/ui/handlers/*;+org/eclipse/ui/help/ *;~org/eclipse/ui/internal/*;~org/eclipse/ui/internal/about/ *;~org/eclipse/ui/internal/actions/*;~org/eclipse/ui/interna l/activities/*;~org/eclipse/ui/internal/activities/ws/*;~org /eclipse/ui/internal/application/*;~org/eclipse/ui/internal/ browser/*;~org/eclipse/ui/internal/commands/*;~org/eclipse/u i/internal/contexts/*;~org/eclipse/ui/internal/decorators/*; ~org/eclipse/ui/internal/dialogs/*;~org/eclipse/ui/internal/ dnd/*;~org/eclipse/ui/internal/editorsupport/*;~org/eclipse/ ui/internal/expressions/*;~org/eclipse/ui/internal/handlers/ *;~org/eclipse/ui/internal/help/*;~org/eclipse/ui/internal/i ntro/*;~org/eclipse/ui/internal/keys/*;~org/eclipse/ui/inter nal/keys/model/*;~org/eclipse/ui/internal/layout/*;~org/ecli pse/ui/internal/menus/*;~org/eclipse/ui/internal/misc/*;~org /eclipse/ui/internal/model/*;~org/eclipse/ui/internal/operat ions/*;~org/eclipse/ui/internal/part/*;~org/eclipse/ui/inter nal/preferences/*;~org/eclipse/ui/internal/presentations/*;~ org/eclipse/ui/internal/presentations/classic/*;~org/eclipse /ui/internal/presentations/defaultpresentation/*;~org/eclips e/ui/internal/presentations/util/*;~org/eclipse/ui/internal/ progress/*;~org/eclipse/ui/internal/provisional/application/ *;~org/eclipse/ui/internal/provisional/presentations/*;~org/ eclipse/ui/internal/quickaccess/*;~org/eclipse/ui/internal/r egistry/*;~org/eclipse/ui/internal/services/*;~org/eclipse/u i/internal/splash/*;~org/eclipse/ui/internal/statushandlers/ *;~org/eclipse/ui/internal/testing/*;~org/eclipse/ui/interna l/themes/*;~org/eclipse/ui/internal/tweaklets/*;~org/eclipse /ui/internal/util/*;~org/eclipse/ui/internal/wizards/*;~org/ eclipse/ui/internal/wizards/preferences/*;+org/eclipse/ui/in tro/*;+org/eclipse/ui/keys/*;+org/eclipse/ui/menus/*;+org/ec lipse/ui/model/*;+org/eclipse/ui/operations/*;+org/eclipse/u i/part/*;+org/eclipse/ui/plugin/*;+org/eclipse/ui/preference s/*;+org/eclipse/ui/presentations/*;+org/eclipse/ui/progress /*;+org/eclipse/ui/services/*;+org/eclipse/ui/splash/*;+org/ eclipse/ui/statushandlers/*;+org/eclipse/ui/swt/*;+org/eclip se/ui/testing/*;+org/eclipse/ui/themes/*;+org/eclipse/ui/vie ws/*;+org/eclipse/ui/wizards/*;?**/*];C:\DATA\test\eclipse\p lugins\com.ibm.icu_3.8.1.v20080530.jar[?**/*];C:\DATA\test\e clipse\plugins\org.eclipse.help_3.3.100.v20080610.jar[?**/*] ;C:\DATA\test\eclipse\plugins\org.eclipse.core.expressions_3 .4.0.v20080603-2000.jar[?**/*];C:\DATA\test\eclipse\plugins\ org.eclipse.jface.databinding_1.2.0.I20080515-2000a.jar[?**/ *];C:\DATA\test\eclipse\plugins\org.eclipse.core.databinding _1.1.0.I20080527-2000.jar[?**/*];C:\DATA\test\eclipse\plugin s\org.eclipse.core.resources_3.4.0.v20080604-1400.jar[?**/*] ;C:\DATA\test\eclipse\plugins\org.eclipse.core.resources.com patibility_3.4.0.v20080604-1400.jar[?**/*];C:\DATA\test\ecli pse\plugins\org.eclipse.core.resources.win32.x86_3.4.0.v2007 1204.jar[?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.ant .core_3.2.0.v20080529.jar[?**/*];C:\DATA\test\eclipse\plugin s\org.eclipse.core.variables_3.2.100.v20080529-1300.jar[?**/ *];C:\DATA\test\eclipse\plugins\org.eclipse.core.filesystem_ 1.2.0.v20080604-1400.jar[?**/*];C:\DATA\test\eclipse\plugins \org.eclipse.core.filesystem.win32.x86_1.1.0.v20080604-1400. jar[?**/*];C:\DATA\test\build\plugins\core\src;C:\DATA\test\ build\plugins\core\test;C:\DATA\test\build\plugins\core\reso urce'
[java] [javac] '-d'
[java] [javac]
'C:\DATA\test\build\plugins\core\temp.folder\@dot.bin'
[java] [javac] '-verbose'
[java] [javac]
'@C:\DATA\test\build\plugins\core/javaCompiler...args'
[java] [javac] '-log'
[java] [javac]
'C:\DATA\test\build\plugins\core/temp.folder/@dot.bin.log'
[java] [javac]
[java] [javac] The ' characters around the executable and arguments
are
[java] [javac] not part of the command.
[java] [javac] Files to be compiled:
[java] [javac]
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\EtmCore.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\EtmLogger.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\EtmPlugin.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Abst ractApplicationModule.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Abst ractWorkspace.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Appl icationEnvironment.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Appl icationException.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Defa ultApplication.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\IApp licationEnvironmentFactory.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\IRep ository.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Loca lRepository.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Work space.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\Work spaceState.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\modu le\IApplicationModule.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\application\modu le\IApplicationModuleListener.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\cache\Cache.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\cache\CacheListe ner.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\cache\ImageCache .java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\CardEvent. java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\Event.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\EventHisto ry.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\EventListe ner.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\EventProdu cer.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\event\EventRelay .java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Access.jav a
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\CardModel. java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Comment.ja va
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Externaliz ableJaxObject.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Modifiable .java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Note.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\Summary.ja va
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\attachment \Attachment.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\attachment \AttachmentListener.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\attachment \MimeType.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\event\Card Update.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\event\IPro pertyListener.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\event\Prop ertyEventType.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\event\Prop ertyUpdate.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\A bstractScopedProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\C omplexProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\C opyOfPropertyType.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\M ultiComplexProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\M ultiValueProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\P roperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\P ropertyInfo.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\P ropertyType.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\P ropertyTypes.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\S impleProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\U serScopedProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\W orkspaceScopedProperty.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\property\e vent\PropertyUpdater.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlCar ds.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlErr or.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlLis t.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlLis tListener.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlMap ping.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlSta ckTraceElement.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\model\xml\XmlWra pper.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\service\Attachme ntService.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\service\EtmServi ce.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\service\EtmServi ces.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\service\UrlInput Stream.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\FileUtils.j ava
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\ImageUtils. java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\ImportExpor tUtils.java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\LocaleUtils .java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\MhtmlUtils. java
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\UrlUtils.ja va
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\XmlUtils.ja va
[java] [javac]
C:\DATA\test\build\plugins\core\src\com\etm\util\ZipUtility. java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\CoreTests.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\MockBundle.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\MockBundleConte xt.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\application\Wor kspaceIOTest.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\application\Wor kspaceTest.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\event\MockEvent Listener.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\model\BasicCard Model.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\model\xml\XmlEr rorTest.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\repository\Loca lRepositoryTest.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\util\FileUtilsT est.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\util\MhtmlUtils Test.java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\util\TestUtils. java
[java] [javac]
C:\DATA\test\build\plugins\core\test\com\etm\util\XmlUtilsTe st.java
[java] [javac] [parsing
C:\DATA\test\build\plugins\core\src\com\etm\AbstractEtmPlugi n.java - #1/84]
C:\DATA\test\build\plugins\core\src\com\etm\EtmCore.java - #2/84]
C:\DATA\test\build\plugins\core\src\com\etm\EtmLogger.java - #3/84]
C:\DATA\test\build\plugins\core\src\com\etm\EtmPlugin.java - #4/84]
- #5/84]
- #6/84]
- #7/84]
- #8/84]
- #9/84]
- #10/84]
C:\DATA\test\build\plugins\core\src\com\etm\application\IRep ository.java -
#11/84]
[java] [javac] ----------
[java] [javac] 1. ERROR in
(at line 0)
[java] [javac] package com.etm.application;
[java] [javac] ^
[java] [javac] Internal compiler error
[java] [javac] java.lang.OutOfMemoryError: Java heap space
[java] [javac]
"Sither" <sither@mit.edu> wrote in message
news:gam2hf$l66$1@build.eclipse.org...
> Hi all,
> java -jar
> -application org.eclipse.ant.core.antRunner -buildfile
> see an InvocationTargetException (see below). But on every subsequent
> build, it runs out of memory. While running the generateFeature ant
> target, the script fails because of an OutOfMemoryError. I tried
> adding -Xmx500 to the build command, and it didn't help.
> eclipse anymore. (The eclipse.exe in C:/eclipse). I don't know if that's
> related or not. If I can't work this out, we'll have to find another way
> to build. I desperately don't want to do that, so I would appreciate any
> Thanks!
> -Matt
> [java]
> [java] build.jars:
> [java]
> [java] properties:
> [java]
> [java] init:
> [java]
> [java] @dot:
> [java] [parsing
> #1/84]
> [java]
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
Re: PDE Build failure: OutOfMemoryError: Java heap space [message #580500 is a reply to message #22263] |
Mon, 15 September 2008 16:51  |
Have you tried increasing the vm memory on the process that is running
out? http://www.eclipsezone.com/eclipse/forums/t61618.html
> seemingly untraceable OutOfMemoryError. But maybe this output means
> something to someone in this group. Here it is, starting with the
> build.jars target.
> [java] build.jars:
> with URI = file:/C:/DATA/test/build/plugins/core/build.xml
> zip.plugin, copy.src.zip, refresh, gather.logs, build.jars,
> build.update.jar, src.zip, gather.bin.parts, build.zips, build.sources,
> gather.individual.sources, gather.sources, clean, copy.src.includes,
> zip.src.zip, ]
> zip.src.zip, ]
> [java]
> [java] properties:
> [java]
> [java] init:
> [java]
> [java] @dot:
> com\etm\EtmCore.class doesn't exist.
> [java] [javac]
> com\etm\application\AbstractApplicationModule.java added as
> added as com\etm\application\ApplicationException.class doesn't exist.
> [java] [javac]
> [java] [javac]
> com\etm\application\module\IApplicationModule.java added as
> [java] [javac]
> [java] [javac]
> com\etm\model\property\AbstractScopedProperty.java added as
> added as com\etm\model\property\CopyOfPropertyType.class doesn't exist.
> added as com\etm\model\property\MultiValueProperty.class doesn't exist.
> added as com\etm\model\property\UserScopedProperty.class doesn't exist.
> [java] [javac]
> com\etm\model\property\WorkspaceScopedProperty.java added as
> to handle it
> how to handle it
> how to handle it
> handle it
> to handle it
> how to handle it
> handle it
> to handle it
> to handle it
> handle it
> handle it
> to handle it
> handle it
> to handle it
> handle it
> [java] dropping
> [java] dropping
> [java] [javac]
;+org/eclipse/swt/graphics/*;+org/eclipse/swt/layout/*;+org/ eclipse/swt/opengl/*;+org/eclipse/swt/printing/*;+org/eclips e/swt/program/*;+org/eclipse/swt/widgets/*;~org/eclipse/swt/ internal/*;~org/eclipse/swt/internal/image/*;~org/eclipse/sw t/internal/theme/*;+org/eclipse/swt/ole/win32/*;~org/eclipse /swt/internal/gdip/*;~org/eclipse/swt/internal/ole/win32/*;~ org/eclipse/swt/internal/win32/*;~org/eclipse/swt/internal/o pengl/win32/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclips e.core.runtime_3.4.0.v20080512.jar[~org/eclipse/core/interna l/preferences/legacy/*;~org/eclipse/core/internal/runtime/*; +org/eclipse/core/runtime/*;?**/*];C:\DATA\test\eclipse\plug ins\org.eclipse.osgi_3.4.0.v20080605-1900.jar[+org/eclipse/o sgi/event/*;+org/eclipse/osgi/framework/console/*;+org/eclip se/osgi/framework/eventmgr/*;+org/eclipse/osgi/framework/log /*;+org/eclipse/osgi/service/datalocation/*;+org/eclipse/osg i/service/debug/*;+org/eclipse/osgi/service/environment/*;+o rg/eclipse/osgi/service/locali
zation/*;+org/eclipse/osgi/service/pluginconversion/*;+org/e clipse/osgi/service/resolver/*;+org/eclipse/osgi/service/run nable/*;+org/eclipse/osgi/service/security/*;+org/eclipse/os gi/service/urlconversion/*;+org/eclipse/osgi/signedcontent/* ;+org/eclipse/osgi/storagemanager/*;+org/eclipse/osgi/util/* ;+org/osgi/framework/*;+org/osgi/service/condpermadmin/*;+or g/osgi/service/packageadmin/*;+org/osgi/service/permissionad min/*;+org/osgi/service/startlevel/*;+org/osgi/service/url/* ;+org/osgi/util/tracker/*;~org/eclipse/core/runtime/adaptor/ *;~org/eclipse/core/runtime/internal/adaptor/*;~org/eclipse/ core/runtime/internal/stats/*;~org/eclipse/osgi/baseadaptor/ *;~org/eclipse/osgi/baseadaptor/bundlefile/*;~org/eclipse/os gi/baseadaptor/hooks/*;~org/eclipse/osgi/baseadaptor/loader/ *;~org/eclipse/osgi/framework/adaptor/*;~org/eclipse/osgi/fr amework/debug/*;~org/eclipse/osgi/framework/internal/core/*; ~org/eclipse/osgi/framework/internal/protocol/*;~org/eclipse /osgi/framework/internal/proto
col/bundleentry/*;~org/eclipse/osgi/framework/internal/proto col/bundleresource/*;~org/eclipse/osgi/framework/internal/pr otocol/reference/*;~org/eclipse/osgi/framework/internal/reli ablefile/*;~org/eclipse/osgi/framework/launcher/*;~org/eclip se/osgi/framework/util/*;~org/eclipse/osgi/internal/baseadap tor/*;~org/eclipse/osgi/internal/module/*;~org/eclipse/osgi/ internal/profile/*;~org/eclipse/osgi/internal/resolver/*;~or g/eclipse/osgi/internal/provisional/service/security/*;~org/ eclipse/osgi/internal/provisional/verifier/*;~org/eclipse/os gi/internal/service/security/*;~org/eclipse/osgi/internal/si gnedcontent/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclips e.equinox.common_3.4.0.v20080421-2006.jar[~org/eclipse/core/ internal/boot/*;~org/eclipse/core/internal/runtime/*;+org/ec lipse/core/runtime/*;?**/*];C:\DATA\test\eclipse\plugins\org .eclipse.core.jobs_3.4.0.v20080512.jar[~org/eclipse/core/int ernal/jobs/*;+org/eclipse/core/runtime/jobs/*;?**/*];C:\DATA \test\eclipse\plugins\org.ecli
pse.core.runtime.compatibility.registry_3.2.200.v20080610\ru ntime_registry_compatibility.jar[~org/eclipse/core/internal/ adapter/*;~org/eclipse/core/internal/registry/*;~org/eclipse /core/internal/registry/osgi/*;~org/eclipse/core/internal/re gistry/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/core/r untime/dynamichelpers/*;+org/eclipse/core/runtime/spi/*;?**/ *];C:\DATA\test\eclipse\plugins\org.eclipse.core.runtime.com patibility.registry_3.2.200.v20080610[~org/eclipse/core/inte rnal/adapter/*;~org/eclipse/core/internal/registry/*;~org/ec lipse/core/internal/registry/osgi/*;~org/eclipse/core/intern al/registry/spi/*;+org/eclipse/core/runtime/*;+org/eclipse/c ore/runtime/dynamichelpers/*;+org/eclipse/core/runtime/spi/* ;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.equinox.reg istry_3.4.0.v20080516-0950.jar[~org/eclipse/core/internal/ad apter/*;~org/eclipse/core/internal/registry/*;~org/eclipse/c ore/internal/registry/osgi/*;~org/eclipse/core/internal/regi stry/spi/*;+org/eclipse/core/r
untime/*;+org/eclipse/core/runtime/dynamichelpers/*;+org/ecl ipse/core/runtime/spi/*;?**/*];C:\DATA\test\eclipse\plugins\ org.eclipse.equinox.preferences_3.2.200.v20080421-2006.jar[~ org/eclipse/core/internal/preferences/*;~org/eclipse/core/in ternal/preferences/exchange/*;+org/eclipse/core/runtime/pref erences/*;+org/osgi/service/prefs/*;?**/*];C:\DATA\test\ecli pse\plugins\org.eclipse.core.contenttype_3.3.0.v20080604-140 0.jar[~org/eclipse/core/internal/content/*;+org/eclipse/core /runtime/content/*;?**/*];C:\DATA\test\eclipse\plugins\org.e clipse.core.runtime.compatibility.auth_3.2.100.v20070502.jar [?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.equinox.app _1.1.0.v20080421-2006.jar[+org/eclipse/equinox/app/*;~org/ec lipse/equinox/internal/app/*;+org/osgi/service/application/* ;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.osgi.servic es_3.1.200.v20071203.jar[?**/*];C:\DATA\test\eclipse\plugins \javax.servlet_2.4.0.v200806031604.jar[?**/*];C:\DATA\test\e clipse\plugins\org.junit_3.8.2
v20080602-1318\junit.jar[+junit/awtui/*;+junit/extensions/*; +junit/framework/*;+junit/runner/*;+junit/swingui/*;+junit/s wingui/icons/*;+junit/textui/*;?**/*];C:\DATA\test\eclipse\p lugins\org.apache.log4j_1.2.13.v200806030600.jar[+org/apache /log4j/*;+org/apache/log4j/chainsaw/*;+org/apache/log4j/conf ig/*;+org/apache/log4j/helpers/*;+org/apache/log4j/jdbc/*;+o rg/apache/log4j/jmx/*;+org/apache/log4j/lf5/*;+org/apache/lo g4j/lf5/config/*;+org/apache/log4j/lf5/util/*;+org/apache/lo g4j/lf5/viewer/*;+org/apache/log4j/lf5/viewer/categoryexplor er/*;+org/apache/log4j/lf5/viewer/configure/*;+org/apache/lo g4j/lf5/viewer/images/*;+org/apache/log4j/net/*;+org/apache/ log4j/nt/*;+org/apache/log4j/or/*;+org/apache/log4j/or/jms/* ;+org/apache/log4j/or/sax/*;+org/apache/log4j/spi/*;+org/apa che/log4j/varia/*;+org/apache/log4j/xml/*;?**/*];C:\DATA\tes t\eclipse\plugins\org.eclipse.ui_3.4.0.I20080610-1200.jar[~o rg/eclipse/ui/internal/*;?**/*];C:\DATA\test\eclipse\plugins \org.eclipse.jface_3.4.0.I200
80606-1300.jar[+org/eclipse/jface/*;+org/eclipse/jface/actio n/*;+org/eclipse/jface/action/images/*;+org/eclipse/jface/bi ndings/*;+org/eclipse/jface/bindings/keys/*;+org/eclipse/jfa ce/bindings/keys/formatting/*;+org/eclipse/jface/commands/*; +org/eclipse/jface/contexts/*;+org/eclipse/jface/dialogs/*;+ org/eclipse/jface/dialogs/images/*;+org/eclipse/jface/fielda ssist/*;+org/eclipse/jface/fieldassist/images/*;+org/eclipse /jface/images/*;~org/eclipse/jface/internal/*;~org/eclipse/j face/internal/provisional/action/*;+org/eclipse/jface/layout /*;+org/eclipse/jface/menus/*;+org/eclipse/jface/operation/* ;+org/eclipse/jface/preference/*;+org/eclipse/jface/preferen ce/images/*;+org/eclipse/jface/resource/*;+org/eclipse/jface /util/*;+org/eclipse/jface/viewers/*;+org/eclipse/jface/view ers/deferred/*;+org/eclipse/jface/window/*;+org/eclipse/jfac e/wizard/*;+org/eclipse/jface/wizard/images/*;?**/*];C:\DATA \test\eclipse\plugins\org.eclipse.core.commands_3.4.0.I20080 509-2000.jar[+org/eclipse/core
/commands/*;+org/eclipse/core/commands/common/*;+org/eclipse /core/commands/contexts/*;+org/eclipse/core/commands/operati ons/*;+org/eclipse/core/commands/util/*;~org/eclipse/core/in ternal/commands/operations/*;~org/eclipse/core/internal/comm ands/util/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse. ui.workbench_3.4.0.I20080606-1300.jar[+org/eclipse/ui/*;+org /eclipse/ui/about/*;+org/eclipse/ui/actions/*;+org/eclipse/u i/activities/*;+org/eclipse/ui/application/*;+org/eclipse/ui /branding/*;+org/eclipse/ui/browser/*;+org/eclipse/ui/comman ds/*;+org/eclipse/ui/contexts/*;+org/eclipse/ui/dialogs/*;+o rg/eclipse/ui/dnd/*;+org/eclipse/ui/fieldassist/*;+org/eclip se/ui/handlers/*;+org/eclipse/ui/help/*;~org/eclipse/ui/inte rnal/*;~org/eclipse/ui/internal/about/*;~org/eclipse/ui/inte rnal/actions/*;~org/eclipse/ui/internal/activities/*;~org/ec lipse/ui/internal/activities/ws/*;~org/eclipse/ui/internal/a pplication/*;~org/eclipse/ui/internal/browser/*;~org/eclipse /ui/internal/commands/*;~org/e
clipse/ui/internal/contexts/*;~org/eclipse/ui/internal/decor ators/*;~org/eclipse/ui/internal/dialogs/*;~org/eclipse/ui/i nternal/dnd/*;~org/eclipse/ui/internal/editorsupport/*;~org/ eclipse/ui/internal/expressions/*;~org/eclipse/ui/internal/h andlers/*;~org/eclipse/ui/internal/help/*;~org/eclipse/ui/in ternal/intro/*;~org/eclipse/ui/internal/keys/*;~org/eclipse/ ui/internal/keys/model/*;~org/eclipse/ui/internal/layout/*;~ org/eclipse/ui/internal/menus/*;~org/eclipse/ui/internal/mis c/*;~org/eclipse/ui/internal/model/*;~org/eclipse/ui/interna l/operations/*;~org/eclipse/ui/internal/part/*;~org/eclipse/ ui/internal/preferences/*;~org/eclipse/ui/internal/presentat ions/*;~org/eclipse/ui/internal/presentations/classic/*;~org /eclipse/ui/internal/presentations/defaultpresentation/*;~or g/eclipse/ui/internal/presentations/util/*;~org/eclipse/ui/i nternal/progress/*;~org/eclipse/ui/internal/provisional/appl ication/*;~org/eclipse/ui/internal/provisional/presentations /*;~org/eclipse/ui/internal/qu
ickaccess/*;~org/eclipse/ui/internal/registry/*;~org/eclipse /ui/internal/services/*;~org/eclipse/ui/internal/splash/*;~o rg/eclipse/ui/internal/statushandlers/*;~org/eclipse/ui/inte rnal/testing/*;~org/eclipse/ui/internal/themes/*;~org/eclips e/ui/internal/tweaklets/*;~org/eclipse/ui/internal/util/*;~o rg/eclipse/ui/internal/wizards/*;~org/eclipse/ui/internal/wi zards/preferences/*;+org/eclipse/ui/intro/*;+org/eclipse/ui/ keys/*;+org/eclipse/ui/menus/*;+org/eclipse/ui/model/*;+org/ eclipse/ui/operations/*;+org/eclipse/ui/part/*;+org/eclipse/ ui/plugin/*;+org/eclipse/ui/preferences/*;+org/eclipse/ui/pr esentations/*;+org/eclipse/ui/progress/*;+org/eclipse/ui/ser vices/*;+org/eclipse/ui/splash/*;+org/eclipse/ui/statushandl ers/*;+org/eclipse/ui/swt/*;+org/eclipse/ui/testing/*;+org/e clipse/ui/themes/*;+org/eclipse/ui/views/*;+org/eclipse/ui/w izards/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.ui. workbench.compatibility_3.2.0.I20080509-2000\compatibility.j ar[+org/eclipse/ui/*;+org/ecli
pse/ui/about/*;+org/eclipse/ui/actions/*;+org/eclipse/ui/act ivities/*;+org/eclipse/ui/application/*;+org/eclipse/ui/bran ding/*;+org/eclipse/ui/browser/*;+org/eclipse/ui/commands/*; +org/eclipse/ui/contexts/*;+org/eclipse/ui/dialogs/*;+org/ec lipse/ui/dnd/*;+org/eclipse/ui/fieldassist/*;+org/eclipse/ui /handlers/*;+org/eclipse/ui/help/*;~org/eclipse/ui/internal/ *;~org/eclipse/ui/internal/about/*;~org/eclipse/ui/internal/ actions/*;~org/eclipse/ui/internal/activities/*;~org/eclipse /ui/internal/activities/ws/*;~org/eclipse/ui/internal/applic ation/*;~org/eclipse/ui/internal/browser/*;~org/eclipse/ui/i nternal/commands/*;~org/eclipse/ui/internal/contexts/*;~org/ eclipse/ui/internal/decorators/*;~org/eclipse/ui/internal/di alogs/*;~org/eclipse/ui/internal/dnd/*;~org/eclipse/ui/inter nal/editorsupport/*;~org/eclipse/ui/internal/expressions/*;~ org/eclipse/ui/internal/handlers/*;~org/eclipse/ui/internal/ help/*;~org/eclipse/ui/internal/intro/*;~org/eclipse/ui/inte rnal/keys/*;~org/eclipse/ui/in
ternal/keys/model/*;~org/eclipse/ui/internal/layout/*;~org/e clipse/ui/internal/menus/*;~org/eclipse/ui/internal/misc/*;~ org/eclipse/ui/internal/model/*;~org/eclipse/ui/internal/ope rations/*;~org/eclipse/ui/internal/part/*;~org/eclipse/ui/in ternal/preferences/*;~org/eclipse/ui/internal/presentations/ *;~org/eclipse/ui/internal/presentations/classic/*;~org/ecli pse/ui/internal/presentations/defaultpresentation/*;~org/ecl ipse/ui/internal/presentations/util/*;~org/eclipse/ui/intern al/progress/*;~org/eclipse/ui/internal/provisional/applicati on/*;~org/eclipse/ui/internal/provisional/presentations/*;~o rg/eclipse/ui/internal/quickaccess/*;~org/eclipse/ui/interna l/registry/*;~org/eclipse/ui/internal/services/*;~org/eclips e/ui/internal/splash/*;~org/eclipse/ui/internal/statushandle rs/*;~org/eclipse/ui/internal/testing/*;~org/eclipse/ui/inte rnal/themes/*;~org/eclipse/ui/internal/tweaklets/*;~org/ecli pse/ui/internal/util/*;~org/eclipse/ui/internal/wizards/*;~o rg/eclipse/ui/internal/wizards
/preferences/*;+org/eclipse/ui/intro/*;+org/eclipse/ui/keys/ *;+org/eclipse/ui/menus/*;+org/eclipse/ui/model/*;+org/eclip se/ui/operations/*;+org/eclipse/ui/part/*;+org/eclipse/ui/pl ugin/*;+org/eclipse/ui/preferences/*;+org/eclipse/ui/present ations/*;+org/eclipse/ui/progress/*;+org/eclipse/ui/services /*;+org/eclipse/ui/splash/*;+org/eclipse/ui/statushandlers/* ;+org/eclipse/ui/swt/*;+org/eclipse/ui/testing/*;+org/eclips e/ui/themes/*;+org/eclipse/ui/views/*;+org/eclipse/ui/wizard s/*;?**/*];C:\DATA\test\eclipse\plugins\com.ibm.icu_3.8.1.v2 0080530.jar[?**/*];C:\DATA\test\eclipse\plugins\org.eclipse. help_3.3.100.v20080610.jar[?**/*];C:\DATA\test\eclipse\plugi ns\org.eclipse.core.expressions_3.4.0.v20080603-2000.jar[?** /*];C:\DATA\test\eclipse\plugins\org.eclipse.jface.databindi ng_1.2.0.I20080515-2000a.jar[?**/*];C:\DATA\test\eclipse\plu gins\org.eclipse.core.databinding_1.1.0.I20080527-2000.jar[? **/*];C:\DATA\test\eclipse\plugins\org.eclipse.core.resource s_3.4.0.v20080604-1400.jar[?**
/*];C:\DATA\test\eclipse\plugins\org.eclipse.core.resources. compatibility_3.4.0.v20080604-1400.jar[?**/*];C:\DATA\test\e clipse\plugins\org.eclipse.core.resources.win32.x86_3.4.0.v2 0071204.jar[?**/*];C:\DATA\test\eclipse\plugins\org.eclipse. ant.core_3.2.0.v20080529.jar[?**/*];C:\DATA\test\eclipse\plu gins\org.eclipse.core.variables_3.2.100.v20080529-1300.jar[? **/*];C:\DATA\test\eclipse\plugins\org.eclipse.core.filesyst em_1.2.0.v20080604-1400.jar[?**/*];C:\DATA\test\eclipse\plug ins\org.eclipse.core.filesystem.win32.x86_1.1.0.v20080604-14 00.jar[?**/*];C:\DATA\test\build\plugins\core\src;C:\DATA\te st\build\plugins\core\test;C:\DATA\test\build\plugins\core\r esource'
> [java] [javac] '-d'
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> arguments are
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> [java] [javac]
> - #5/84]
> - #6/84]
> - #7/84]
> - #8/84]
> - #9/84]
> - #10/84]
> - #11/84]
> (at line 0)
> [java] [javac] ^
> [java] [javac]
>> Hi all,
>> I'm totally lost. I have an automated build that has been working for
>> java -jar
>> C:/eclipse/plugins/org.eclipse.equinox.launcher_1.0.100.v200 80509-1800.jar
>> C:/eclipse/plugins/org.eclipse.pde.build_3.4.0.v20080604/scr ipts/productBuild/productBuild.xml
>> -Dbuilder=C:/DATA/build/conf
>> A couple days ago, it started failing. On the first failure, I
>> actually see an InvocationTargetException (see below). But on every
>> subsequent build, it runs out of memory. While running the
>> generateFeature ant target, the script fails because of an
>> OutOfMemoryError. I tried adding -Xmx500 to the build command, and it
>> didn't help.
>> Also, I don't know if this makes a difference, but I also can't open
>> that's related or not. If I can't work this out, we'll have to find
>> another way to build. I desperately don't want to do that, so I would
>> Thanks!
>> -Matt
>> [java]
>> [java] build.jars:
>> [java]
>> [java] properties:
>> [java]
>> [java] init:
>> [java]
>> [java] @dot:
>> [java] [mkdir] Created dir:
>> [java] [javac] Compiling 84 source files to
>> [java] [parsing
>> #1/84]
>> [java]
>> [java] BUILD FAILED
>> [java]
>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\productBuild\productBuild.xml:29:
>> The following error occurred while executing this line:
>> [java]
>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\build.xml:78:
>> [java]
>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\templates\headless-build\customTargets.xml:12:
>> [java]
>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\productBuild\allElements.xml:9:
>> [java]
>> C:\DATA\test\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20 080604\scripts\genericTargets.xml:95:
>> [java]
>> C:\DATA\test\build\features\org.eclipse.pde.build.container. feature\build.xml:94:
>> [java]
>> C:\DATA\test\build\features\org.eclipse.pde.build.container. feature\build.xml:20:
>> [java] C:\DATA\test\build\plugins\core\build.xml:169: The
>> [java] C:\DATA\test\build\plugins\core\build.xml:104:
>> java.lang.reflect.InvocationTargetException
>> [java]
>> [java] Total time: 1 minute 51 seconds
Re: PDE Build failure: OutOfMemoryError: Java heap space [message #580514 is a reply to message #22320] |
Mon, 15 September 2008 20:42  |
I tried upping the memory in numerous places. Mainly, I tried adding
the -Xmx arg to the java task that runs ant on productBuild.xml. I also
tried adding the -Xmx arg to the compileArgs property in the
build.properties that I pass to productBuild.xml. Neither fixed the
problem.
However, I tried a bunch of almost random things today, and it finally
started working. One of the changes I made was setting the ANT_OPTS
environment variable to -Xmx1024M -XX:CompileThreshold=1500 -Xms512M. Does
that sound right? I'm glad it's working now, but I'd still like to get to
the bottom of this so I can prevent the problem in the future.
Matt
"Will Horn" <will.horn@gmail.com> wrote in message
news:gamhsu$jp9$1@build.eclipse.org...
>> build.jars target.
>> [java] build.jars:
>> [java] [available] Unable to find @dot to set property @dot
>> [java] Project base dir set to: C:\DATA\test\build\plugins\core
>> [java] [antcall] calling target(s) [@dot] in build file
>> [java] Override ignored for property "basews"
>> [java] Override ignored for property "baseos"
>> [java] Override ignored for property "basearch"
>> [java] Property "nl" has not been set
>> [java] Override ignored for property "basenl"
>> [java] Override ignored for property "bundleId"
>> [java] Override ignored for property "bundleVersion"
>> [java] Override ignored for property "javacFailOnError"
>> [java] Override ignored for property "javacDebugInfo"
>> [java] Override ignored for property "javacVerbose"
>> [java] Override ignored for property "logExtension"
>> [java] Override ignored for property "compilerArg"
>> [java] Override ignored for property "javacSource"
>> [java] Override ignored for property "javacTarget"
>> [java] Override ignored for property "dir_bootclasspath"
>> [java] Override ignored for property "bootclasspath"
>> [java] Override ignored for property "bundleJavacSource"
>> [java] Override ignored for property "bundleJavacTarget"
>> [java] Override ignored for property "bundleBootClasspath"
>> @dot]
>> zip.src.zip, ]
>> [java] [antcall] Entering
>> C:\DATA\test\build\plugins\core\build.xml...
>> @dot]
>> zip.src.zip, ]
>> [java]
>> [java] properties:
>> [java] Override ignored for property "build.compiler"
>> [java]
>> [java] init:
>> [java] Property "buildTempFolder" has not been set
>> [java] Override ignored for property "pluginTemp"
>> [java] Override ignored for property "build.result.folder"
>> [java] Override ignored for property "temp.folder"
>> [java] Override ignored for property "plugin.destination"
>> [java]
>> [java] @dot:
>> [java] [javac] com\etm\AbstractEtmPlugin.java added as
>> com\etm\AbstractEtmPlugin.class doesn't exist.
>> [java] [javac] com\etm\EtmLogger.java added as
>> com\etm\EtmLogger.class doesn't exist.
>> [java] [javac] com\etm\EtmPlugin.java added as
>> com\etm\EtmPlugin.class doesn't exist.
>> exist.
>> as com\etm\application\AbstractWorkspace.class doesn't exist.
>> as com\etm\application\DefaultApplication.class doesn't exist.
>> [java] [javac]
>> com\etm\application\IApplicationEnvironmentFactory.java added as
>> com\etm\application\IApplicationEnvironmentFactory.class doesn't exist.
>> [java] [javac] com\etm\application\IRepository.java added as
>> com\etm\application\IRepository.class doesn't exist.
>> com\etm\application\LocalRepository.class doesn't exist.
>> [java] [javac] com\etm\application\Workspace.java added as
>> com\etm\application\Workspace.class doesn't exist.
>> com\etm\application\WorkspaceState.class doesn't exist.
>> exist.
>> [java] [javac]
>> com\etm\application\module\IApplicationModuleListener.java added as
>> exist.
>> [java] [javac] com\etm\cache\Cache.java added as
>> com\etm\cache\Cache.class doesn't exist.
>> [java] [javac] com\etm\cache\CacheListener.java added as
>> com\etm\cache\CacheListener.class doesn't exist.
>> [java] [javac] com\etm\cache\ImageCache.java added as
>> com\etm\cache\ImageCache.class doesn't exist.
>> [java] [javac] com\etm\event\CardEvent.java added as
>> com\etm\event\CardEvent.class doesn't exist.
>> [java] [javac] com\etm\event\Event.java added as
>> com\etm\event\Event.class doesn't exist.
>> [java] [javac] com\etm\event\EventHistory.java added as
>> com\etm\event\EventHistory.class doesn't exist.
>> [java] [javac] com\etm\event\EventListener.java added as
>> com\etm\event\EventListener.class doesn't exist.
>> [java] [javac] com\etm\event\EventProducer.java added as
>> com\etm\event\EventProducer.class doesn't exist.
>> [java] [javac] com\etm\event\EventRelay.java added as
>> com\etm\event\EventRelay.class doesn't exist.
>> [java] [javac] com\etm\model\Access.java added as
>> com\etm\model\Access.class doesn't exist.
>> [java] [javac] com\etm\model\CardModel.java added as
>> com\etm\model\CardModel.class doesn't exist.
>> [java] [javac] com\etm\model\Comment.java added as
>> com\etm\model\Comment.class doesn't exist.
>> as com\etm\model\ExternalizableJaxObject.class doesn't exist.
>> [java] [javac] com\etm\model\Modifiable.java added as
>> com\etm\model\Modifiable.class doesn't exist.
>> [java] [javac] com\etm\model\Note.java added as
>> com\etm\model\Note.class doesn't exist.
>> [java] [javac] com\etm\model\Summary.java added as
>> com\etm\model\Summary.class doesn't exist.
>> com\etm\model\attachment\Attachment.class doesn't exist.
>> com\etm\model\attachment\MimeType.class doesn't exist.
>> [java] [javac] com\etm\model\event\CardUpdate.java added as
>> com\etm\model\event\CardUpdate.class doesn't exist.
>> as com\etm\model\event\IPropertyListener.class doesn't exist.
>> as com\etm\model\event\PropertyEventType.class doesn't exist.
>> com\etm\model\event\PropertyUpdate.class doesn't exist.
>> exist.
>> as com\etm\model\property\ComplexProperty.class doesn't exist.
>> [java] [javac] com\etm\model\property\Property.java added as
>> com\etm\model\property\Property.class doesn't exist.
>> com\etm\model\property\PropertyInfo.class doesn't exist.
>> com\etm\model\property\PropertyType.class doesn't exist.
>> com\etm\model\property\PropertyTypes.class doesn't exist.
>> as com\etm\model\property\SimpleProperty.class doesn't exist.
>> [java] [javac]
>> exist.
>> [java] [javac] com\etm\model\xml\XmlCards.java added as
>> com\etm\model\xml\XmlCards.class doesn't exist.
>> [java] [javac] com\etm\model\xml\XmlError.java added as
>> com\etm\model\xml\XmlError.class doesn't exist.
>> [java] [javac] com\etm\model\xml\XmlList.java added as
>> com\etm\model\xml\XmlList.class doesn't exist.
>> com\etm\model\xml\XmlListListener.class doesn't exist.
>> [java] [javac] com\etm\model\xml\XmlMapping.java added as
>> com\etm\model\xml\XmlMapping.class doesn't exist.
>> as com\etm\model\xml\XmlStackTraceElement.class doesn't exist.
>> [java] [javac] com\etm\model\xml\XmlWrapper.java added as
>> com\etm\model\xml\XmlWrapper.class doesn't exist.
>> com\etm\service\AttachmentService.class doesn't exist.
>> [java] [javac] com\etm\service\EtmService.java added as
>> com\etm\service\EtmService.class doesn't exist.
>> [java] [javac] com\etm\service\EtmServices.java added as
>> com\etm\service\EtmServices.class doesn't exist.
>> [java] [javac] com\etm\service\UrlInputStream.java added as
>> com\etm\service\UrlInputStream.class doesn't exist.
>> [java] [javac] com\etm\util\FileUtils.java added as
>> com\etm\util\FileUtils.class doesn't exist.
>> [java] [javac] com\etm\util\ImageUtils.java added as
>> com\etm\util\ImageUtils.class doesn't exist.
>> [java] [javac] com\etm\util\ImportExportUtils.java added as
>> com\etm\util\ImportExportUtils.class doesn't exist.
>> [java] [javac] com\etm\util\LocaleUtils.java added as
>> com\etm\util\LocaleUtils.class doesn't exist.
>> [java] [javac] com\etm\util\MhtmlUtils.java added as
>> com\etm\util\MhtmlUtils.class doesn't exist.
>> [java] [javac] com\etm\util\UrlUtils.java added as
>> com\etm\util\UrlUtils.class doesn't exist.
>> [java] [javac] com\etm\util\XmlUtils.java added as
>> com\etm\util\XmlUtils.class doesn't exist.
>> [java] [javac] com\etm\util\ZipUtility.java added as
>> com\etm\util\ZipUtility.class doesn't exist.
>> [java] [javac] com\etm\CoreTests.java added as
>> com\etm\CoreTests.class doesn't exist.
>> [java] [javac] com\etm\MockBundle.java added as
>> com\etm\MockBundle.class doesn't exist.
>> [java] [javac] com\etm\MockBundleContext.java added as
>> com\etm\MockBundleContext.class doesn't exist.
>> com\etm\application\WorkspaceIOTest.class doesn't exist.
>> com\etm\application\WorkspaceTest.class doesn't exist.
>> [java] [javac] com\etm\event\MockEventListener.java added as
>> com\etm\event\MockEventListener.class doesn't exist.
>> [java] [javac] com\etm\model\BasicCardModel.java added as
>> com\etm\model\BasicCardModel.class doesn't exist.
>> [java] [javac] com\etm\model\xml\XmlErrorTest.java added as
>> com\etm\model\xml\XmlErrorTest.class doesn't exist.
>> as com\etm\repository\LocalRepositoryTest.class doesn't exist.
>> [java] [javac] com\etm\util\FileUtilsTest.java added as
>> com\etm\util\FileUtilsTest.class doesn't exist.
>> [java] [javac] com\etm\util\MhtmlUtilsTest.java added as
>> com\etm\util\MhtmlUtilsTest.class doesn't exist.
>> [java] [javac] com\etm\util\TestUtils.java added as
>> com\etm\util\TestUtils.class doesn't exist.
>> [java] [javac] com\etm\util\XmlUtilsTest.java added as
>> com\etm\util\XmlUtilsTest.class doesn't exist.
>> to handle it
>> how to handle it
>> how to handle it
>> know how to handle it
>> how to handle it
>> handle it
>> to handle it
>> how to handle it
>> handle it
>> to handle it
>> to handle it
>> handle it
>> [java] [javac] test\repo\test.txt skipped - don't know how to
>> handle it
>> to handle it
>> handle it
>> to handle it
>> handle it
>> [java] [javac] Using JDT compiler
>> [java] dropping
>> C:\DATA\test\eclipse\plugins\org.eclipse.core.runtime.compat ibility.registry_3.2.200.v20080610\@dot
>> from path as it doesn't exist
>> [java] dropping
>> C:\DATA\test\eclipse\plugins\org.eclipse.ui.workbench.compat ibility_3.2.0.I20080509-2000\@dot
>> [java] [javac] Compilation arguments:
>> [java] [javac] '-noExit'
>> [java] [javac] '-bootclasspath'
>> [java] [javac] 'C:\Program Files
>> (x86)\Java\jdk1.6.0\jre\lib\charsets.jar;C:\Program Files
>> (x86)\Java\jdk1.6.0\jre\lib\deploy.jar;C:\Program Files
>> (x86)\Java\jdk1.6.0\jre\lib\javaws.jar;C:\Program Files
>> (x86)\Java\jdk1.6.0\jre\lib\jce.jar;C:\Program Files
>> (x86)\Java\jdk1.6.0\jre\lib\jsse.jar;C:\Program Files
>> (x86)\Java\jdk1.6.0\jre\lib\management-agent.jar;C:\Program Files
>> (x86)\Java\jdk1.6.0\jre\lib\plugin.jar;C:\Program Files
>> (x86)\Java\jdk1.6.0\jre\lib\resources.jar;C:\Program Files
>> (x86)\Java\jdk1.6.0\jre\lib\rt.jar'
>> [java] [javac] '-classpath'
>> [java] [javac]
>> [java] [javac] '-d'
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> arguments are
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> [java] [javac]
>> #1/84]
>> - #5/84]
>> - #6/84]
>> - #7/84]
>> - #8/84]
>> - #9/84]
>> - #10/84]
>> - #11/84]
>> (at line 0)
>> [java] [javac] ^
>> [java] [javac]
>>> Hi all,
>>> about a month now using this command to build:
>>> java -jar
>>> A couple days ago, it started failing. On the first failure, I actually
>>> appreciate any help anyone can give me.
>>> Thanks!
>>> -Matt
>>> [java]
>>> [java] build.jars:
>>> [java]
>>> [java] properties:
>>> [java]
>>> [java] init:
>>> [java]
>>> [java] @dot:
>>> [java] [parsing
>>> #1/84]
>>> [java]
>>> [java] BUILD FAILED
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java] C:\DATA\test\build\plugins\core\build.xml:169: The following
>>> [java]
Re: PDE Build failure: OutOfMemoryError: Java heap space [message #580541 is a reply to message #22363] |
Tue, 16 September 2008 12:00  |
That sounds exactly right to me. The Ant Java process was running out
of memory and ANT_OPTS is the way to configure its VM parameters.
At least on Windows (but I think everywhere), "ant" is a script that
eventually calls something like "java %ANT_OPTS%". So if you pass -Xmx
to the script it doesn't do anything.
-Will
> problem.
> Does that sound right? I'm glad it's working now, but I'd still like to
> get to the bottom of this so I can prevent the problem in the future.
> Matt
>> Sither wrote:
>>> In addition to the log below, I tried adding the verbose argument to
>>> get more info. I don't see anything suspect, aside from the sudden,
>>> build.jars target.
>>> [java] build.jars:
>>> [java] parsing buildfile
>>> C:\DATA\test\build\plugins\core\build.xml with URI =
>>> [java] Build sequence for target(s) `@dot' is [properties, init,
>>> @dot]
>>> [java] Complete build sequence is [properties, init, @dot,
>>> build.sources, gather.individual.sources, gather.sources, clean,
>>> copy.src.includes, zip.src.zip, ]
>>> @dot]
>>> [java]
>>> [java] properties:
>>> [java]
>>> [java] init:
>>> [java]
>>> [java] @dot:
>>> [java] [javac] com\etm\EtmCore.java added as
>>> [java] [javac]
>>> com\etm\application\AbstractApplicationModule.class doesn't exist.
>>> [java] [javac] com\etm\application\AbstractWorkspace.java
>>> added as com\etm\application\AbstractWorkspace.class doesn't exist.
>>> [java] [javac]
>>> com\etm\application\ApplicationEnvironment.java added as
>>> com\etm\application\ApplicationEnvironment.class doesn't exist.
>>> [java] [javac] com\etm\application\ApplicationException.java
>>> [java] [javac] com\etm\application\DefaultApplication.java
>>> added as com\etm\application\DefaultApplication.class doesn't exist.
>>> [java] [javac]
>>> [java] [javac] com\etm\application\LocalRepository.java added
>>> as com\etm\application\LocalRepository.class doesn't exist.
>>> [java] [javac] com\etm\application\WorkspaceState.java added
>>> as com\etm\application\WorkspaceState.class doesn't exist.
>>> [java] [javac]
>>> com\etm\application\module\IApplicationModule.class doesn't exist.
>>> [java] [javac]
>>> com\etm\application\module\IApplicationModuleListener.class doesn't
>>> exist.
>>> [java] [javac] com\etm\model\ExternalizableJaxObject.java
>>> added as com\etm\model\ExternalizableJaxObject.class doesn't exist.
>>> [java] [javac] com\etm\model\attachment\Attachment.java added
>>> as com\etm\model\attachment\Attachment.class doesn't exist.
>>> [java] [javac]
>>> com\etm\model\attachment\AttachmentListener.java added as
>>> com\etm\model\attachment\AttachmentListener.class doesn't exist.
>>> [java] [javac] com\etm\model\attachment\MimeType.java added
>>> as com\etm\model\attachment\MimeType.class doesn't exist.
>>> [java] [javac] com\etm\model\event\IPropertyListener.java
>>> added as com\etm\model\event\IPropertyListener.class doesn't exist.
>>> [java] [javac] com\etm\model\event\PropertyEventType.java
>>> added as com\etm\model\event\PropertyEventType.class doesn't exist.
>>> [java] [javac] com\etm\model\event\PropertyUpdate.java added
>>> as com\etm\model\event\PropertyUpdate.class doesn't exist.
>>> [java] [javac]
>>> com\etm\model\property\AbstractScopedProperty.class doesn't exist.
>>> [java] [javac] com\etm\model\property\ComplexProperty.java
>>> added as com\etm\model\property\ComplexProperty.class doesn't exist.
>>> [java] [javac] com\etm\model\property\CopyOfPropertyType.java
>>> [java] [javac]
>>> com\etm\model\property\MultiComplexProperty.java added as
>>> com\etm\model\property\MultiComplexProperty.class doesn't exist.
>>> [java] [javac] com\etm\model\property\MultiValueProperty.java
>>> [java] [javac] com\etm\model\property\PropertyInfo.java added
>>> as com\etm\model\property\PropertyInfo.class doesn't exist.
>>> [java] [javac] com\etm\model\property\PropertyType.java added
>>> as com\etm\model\property\PropertyType.class doesn't exist.
>>> [java] [javac] com\etm\model\property\PropertyTypes.java
>>> added as com\etm\model\property\PropertyTypes.class doesn't exist.
>>> [java] [javac] com\etm\model\property\SimpleProperty.java
>>> added as com\etm\model\property\SimpleProperty.class doesn't exist.
>>> [java] [javac] com\etm\model\property\UserScopedProperty.java
>>> [java] [javac]
>>> com\etm\model\property\WorkspaceScopedProperty.class doesn't exist.
>>> [java] [javac]
>>> com\etm\model\property\event\PropertyUpdater.java added as
>>> com\etm\model\property\event\PropertyUpdater.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlListListener.java added
>>> as com\etm\model\xml\XmlListListener.class doesn't exist.
>>> [java] [javac] com\etm\model\xml\XmlStackTraceElement.java
>>> added as com\etm\model\xml\XmlStackTraceElement.class doesn't exist.
>>> [java] [javac] com\etm\service\AttachmentService.java added
>>> as com\etm\service\AttachmentService.class doesn't exist.
>>> [java] [javac] com\etm\application\WorkspaceIOTest.java added
>>> as com\etm\application\WorkspaceIOTest.class doesn't exist.
>>> [java] [javac] com\etm\application\WorkspaceTest.java added
>>> as com\etm\application\WorkspaceTest.class doesn't exist.
>>> [java] [javac] com\etm\repository\LocalRepositoryTest.java
>>> added as com\etm\repository\LocalRepositoryTest.class doesn't exist.
>>> [java] [javac] EvtmResources.properties skipped - don't know
>>> how to handle it
>>> [java] [javac] filters\api\googleMaps.xml skipped - don't
>>> [java] [javac] filters\api\yahooMapImage.xml skipped - don't
>>> [java] [javac] filters\api\yahooWeather.new.xml skipped -
>>> don't know how to handle it
>>> [java] [javac] filters\api\yahooWeather.xml skipped - don't
>>> [java] [javac] log4j.properties skipped - don't know how to
>>> handle it
>>> [java] [javac] test\filter\amazon.html skipped - don't know
>>> how to handle it
>>> [java] [javac] test\filter\craigslist.html skipped - don't
>>> [java] [javac] test\filter\ebay.html skipped - don't know how
>>> to handle it
>>> [java] [javac] test\filter\netflix.html skipped - don't know
>>> how to handle it
>>> [java] [javac] test\filter\weather.html skipped - don't know
>>> how to handle it
>>> [java] [javac] test\images\logo.gif skipped - don't know how
>>> to handle it
>>> handle it
>>> [java] [javac] test\workspaces\ebay.ews skipped - don't know
>>> how to handle it
>>> [java] [javac] test\xquery\cnn.xhtml skipped - don't know how
>>> to handle it
>>> [java] [javac] test\zip\images\logo.gif skipped - don't know
>>> how to handle it
>>> [java] [javac] test\zip\test.txt skipped - don't know how to
>>> handle it
>>> [java] dropping
>>> [java] dropping
>>> [java] [javac]
>>> 'C:\DATA\test\build\plugins\core\temp.folder\@dot.bin;C:\DAT A\test\eclipse\plugins\org.eclipse.swt_3.4.0.v3448f.jar[+org /eclipse/swt/*;+org/eclipse/swt/accessibility/*;+org/eclipse /swt/awt/*;+org/eclipse/swt/browser/*;+org/eclipse/swt/custo m/*;+org/eclipse/swt/dnd/*;+org/eclipse/swt/events/*;+org/ec lipse/swt/graphics/*;+org/eclipse/swt/layout/*;+org/eclipse/ swt/opengl/*;+org/eclipse/swt/printing/*;+org/eclipse/swt/pr ogram/*;+org/eclipse/swt/widgets/*;~org/eclipse/swt/internal /*;~org/eclipse/swt/internal/image/*;~org/eclipse/swt/intern al/theme/*;+org/eclipse/swt/ole/win32/*;~org/eclipse/swt/int ernal/gdip/*;~org/eclipse/swt/internal/ole/win32/*;~org/ecli pse/swt/internal/win32/*;~org/eclipse/swt/internal/opengl/wi n32/*;?**/*];C:\DATA\test\eclipse\plugins\org.eclipse.swt.wi n32.win32.x86_3.4.0.v3448f.jar[+org/eclipse/swt/*;+org/eclip se/swt/accessibility/*;+org/eclipse/swt/awt/*;+org/eclipse/s wt/browser/*;+org/eclipse/swt/custom/*;+org/eclipse/swt/dnd/ *;+org/eclipse/swt/events
cali
roto
ecli
re/r
..8.2
200
core
rg/e
l/qu
ecli
i/in
ards
>>> [java] [javac] '-d'
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> arguments are
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> [java] [javac]
>>> #1/84]
>>> - #5/84]
>>> - #6/84]
>>> - #7/84]
>>> - #8/84]
>>> - #9/84]
>>> - #10/84]
>>> - #11/84]
>>> (at line 0)
>>> [java] [javac] ^
>>> [java] [javac]
>>>> Hi all,
>>>> for about a month now using this command to build:
>>>> java -jar
>>>> it didn't help.
>>>> would appreciate any help anyone can give me.
>>>> Thanks!
>>>> -Matt
>>>> [java]
>>>> [java] build.jars:
>>>> [java]
>>>> [java] properties:
>>>> [java]
>>>> [java] init:
>>>> [java]
>>>> [java] @dot:
>>>> [java] [parsing
>>>> #1/84]
>>>> [java]
>>>> [java] BUILD FAILED
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
>>>> [java]
Current Time: Fri Jul 25 02:35:48 EDT 2025
Powered by FUDForum. Page generated in 0.12395 seconds
