Home » Eclipse Projects » DSDP - Target Management » Re: rse; dstore connector service; using port 0 error
Re: rse; dstore connector service; using port 0 error [message #22054] Tue, 22 April 2008 11:48
Hi Sander,
please ask such questions on the eclipse.dsdp.tm newsgroup which
is specific for TM and RSE.
Your problem sounds like the wrong JVM is selected by the dstore daemon;
it supports the Sun JVM only, but not the gcj JVM. Please try explicitly
setting a PATH on the server that points to a Sun, IBM or BEA JVM before
you launch the Daemon. See also
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198093
https://bugs.eclipse.org/bugs/show_bug.cgi?id=153246
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Sander wrote:
> I installed RSE in Eclipse and the dstore server on a Linux system.
> The daemon is running at port 4075 (reachable from the workstation, can
> telnet to it).
> In the connector service port 4075 was defined..
> Still when coonecting apparently the connection is not made on port
> 4075, since this message appears:
> Daemon failed to launch server on SUTR101 using port 0
> Am I still missing something?
> Anyone?
> Sander de Boer
> Eclipse 3.3.1.1, Windows
> RSE server rseserver-3.0M6-linux
> RSE eclipse side: Remote System Explorer Extender SDK v 3.0.0
Previous Topic:Missing RemoteSystemsTempFiles (Remote Systems Explorer)
Next Topic:Re: rse; dstore connector service; using port 0 error
Current Time: Sun Aug 31 09:52:38 EDT 2025
Powered by FUDForum. Page generated in 0.02857 seconds
