Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Plugin dependencies and cspex file
Re: [buckminster-dev] Plugin dependencies and cspex file [message #22037] Mon, 21 July 2008 10:04
Hi Joseph,
Do you put this in a file called buckminster.cspex (note the 'x' at the
end) in the project root?
If you right-click on the project and do "Buckminster" - "View
CSpec...", can you see the dependency there?
Thomas Hallgren
Joseph Campolongo wrote:
> Looking in the archives, it is clear that Buckminster supports only
> specified dependencies (in the manifest.mf file) during its actions.
> Hi Ikuo,
> We are currently looking at how we can improve the Buckminster search
> algorithms so that it
> will be able to find bundles based on a need to import specific
> packages. Someone must
> provide a list of bundles that can be searched for exports that match.
> The problem is a bit
> similar to finding a suitable runtime implementation for something
> that implements an
> interface that you have expressed a dependency towards.
> The design is not yet finished, so the current answer to your question
> is no, we cannot
> resolve these dependencies today. You will need to add a bundle
> requirement or a feature
> that will bring the providing bundles into the graph somehow in order
> for it to build properly.
> Kind Regards,
> Thomas Hallgren
> Due to this, I decided that I would create a cspex extension file and
> add the dependencies directly:
> <cspecExtension
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
> xmlns="http://www.eclipse.org/buckminster/CSpec-1.0">
> <dependencies>
> <!-- Place your Dependencies here -->
> <dependency name="OSGi_Project" componentType="osgi.bundle"
> versionDesignator="1.0.0" versionType="OSGi"/>
> </dependencies>
> </cspecExtension>
> Strangely, this doesn’t work (the dependency isn’t resolved). It still
> doesn’t work if I add the OSGi_Project to my manifest file as a
> dependency. It does work if I remove my extension file and keep the
> OSGi_Project in my manifest file.
> Is this a bug? Should this work? I note that in the response above,
> the solution was not to create an extension file (which seemed the
> obvious solution to me, but then, what do I know), but rather to add
> the dependency to the manifest or to create a feature.
> Joseph Campolongo
> Charles River Analytics, Inc.
> THIS MESSAGE IS INTENDED FOR THE USE OF THE PERSON TO WHOM IT IS
> ADDRESSED. IT MAY CONTAIN INFORMATION THAT IS PRIVILEGED, CONFIDENTIAL
> AND EXEMPT FROM DISCLOSURE UNDER APPLICABLE LAW. If you are not the
> intended recipient, your use of this message for any purpose is
> strictly prohibited. If you have received this communication in error,
> please delete the message and notify the sender so that we may correct
> our records.
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:[buckminster-dev] Plugin dependencies and cspex file
Next Topic:Re: Re: [buckminster-dev] Plugin dependencies and cspex file
Current Time: Sat Jul 26 14:04:42 EDT 2025
Powered by FUDForum. Page generated in 0.03536 seconds
