Home » Language IDEs » C / C++ IDE (CDT) » Why does CDT build every project if I execute an Ant script?
Why does CDT build every project if I execute an Ant script? [message #225846] Fri, 24 October 2008 05:42 Go to next message
Originally posted by: 4cs6fcg02.sneakemail.com
Hi all,
If I execute a target of an Ant script (in a Java project), the CDT
builder runs for every project it is enabled on, even if these have
nothing to do with the project that I run the Ant script on. This is
very annoying and it wastes time. I have ‘Build automatically’ selected
in Window → Preferences → General → Workspace.
Ok, I found now that I can uncheck ‘Open console when building’ under
the C/C++ prefs, which will save me from seeing the messages flash by,
but it still happens in the background and wastes time. Can I disable this?
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Re: Why does CDT build every project if I execute an Ant script? [message #225906 is a reply to message #225846] Fri, 24 October 2008 10:27 Go to previous messageGo to next message
Hendrik Maryns wrote:
> Hi all,
Well, this is exactly because you have Build automatically enabled. CDT
always triggers a full build and delegates responsibility to determine
what to build (if anything at all) to make command. If you use your own
make command it should handle the dependencies itself and build only what
is necessary.
Andrew
> H.
Re: Why does CDT build every project if I execute an Ant script? [message #225914 is a reply to message #225906] Fri, 24 October 2008 10:32 Go to previous messageGo to next message
>> Hi all,
>> very annoying and it wastes time. I have �Build automatically�
>> selected
>> in Window � Preferences � General � Workspace.
> what is necessary.
Of course, my makefile takes care of dependencies. But that still means
I see all ‘Entering directory’ etc. messages flashing by.
By ‘Full build’, do you mean workspace-wide? Why is that? Isn’t that
what project dependencies are for?
H.
Hendrik Maryns
Re: Why does CDT build every project if I execute an Ant script? [message #225923 is a reply to message #225914] Fri, 24 October 2008 12:04 Go to previous messageGo to next message
>>> Hi all,
>>> very annoying and it wastes time. I have âᅵᅵBuild
automaticallyâᅵᅵ
>>> selected
>>> in Window âᅵᅵ Preferences âᅵᅵ General âᅵᅵ Workspace.
>> what is necessary.
I agree with you that it is not ideal for C++ projects but that's just how
it is. If it is too big roadblock (which I agree that it is) I suppose
somebody would take the pain to volunteer and improve it.
Full build as opposed to Incremental build. Incremental build means that
the builder takes care of dependencies, building incrementally. Consider
that CDT builder would figure that no build is necessary and not to go to
the trouble of "make all". But instead it delegates to make command.
Andrew
> H.
Re: Why does CDT build every project if I execute an Ant script? [message #225980 is a reply to message #225923] Mon, 27 October 2008 08:55 Go to previous messageGo to next message
>>>> Hi all,
> automaticallyâᅵᅵ
>>>> selected
>>> what is necessary.
>> I see all �Entering directory� etc. messages flashing by.
> how it is. If it is too big roadblock (which I agree that it is) I
> suppose somebody would take the pain to volunteer and improve it.
>> By �Full build�, do you mean workspace-wide? Why is that?
>> Isn�t that
> to the trouble of "make all". But instead it delegates to make command.
Understand.
But I am still bothered why it does a build of totally unrelated
projects if I save a file in another project, or launch a program or
whatever.
H.
Hendrik Maryns
Re: Why does CDT build every project if I execute an Ant script? [message #225987 is a reply to message #225980] Mon, 27 October 2008 10:14 Go to previous messageGo to next message
>>>>> Hi all,
>> automaticallyâᅵᅵ
>>>>> selected
âᅵᅵ Workspace.
>>>> what is necessary.
>>> I see all âᅵᅵEntering directoryâᅵᅵ etc. messages flashing by.
>>> By âᅵᅵFull buildâᅵᅵ, do you mean workspace-wide? Why is that?
>>> Isnâᅵᅵt that
> Understand.
> whatever.
If "Build automatically" is selected then *every" project in the workspace
is build i.e. its builder is called. This is okay for Java projects where
the build step is very fast but very annoying for C/C++ projects.
Therefore, the CDT usually disables this option.
You can prevent a rebuild when you launch a program if you unselect "Build
before launching" in Windows->Preferences->Run/Debug->Launching->General
Options
Axel
Re: Why does CDT build every project if I execute an Ant script? [message #226008 is a reply to message #225846] Mon, 27 October 2008 17:56 Go to previous messageGo to next message
Fri, 24 Oct 2008 11:42:13 +0200, /Hendrik Maryns/:
Every Ant run configuration (Run -> External Tools -> External Tools
Configurations...) has a "Build before launch" option (at the
"Build" tab) which is checked by default - see if unchecking it will
make any difference.
Stanimir
Re: Why does CDT build every project if I execute an Ant script? [message #226117 is a reply to message #225846] Wed, 29 October 2008 11:50 Go to previous message
Check your Ant launch configuration. There is an option to control what gets built before the launch
is executed. This may help.
Dave Kelsey
> Hi all,
> H.
Previous Topic:Trigger-happy task tags
Next Topic:Help!!! Cant run CDT
Current Time: Tue Nov 04 18:45:08 EST 2025
Powered by FUDForum. Page generated in 0.03558 seconds
