Home » Eclipse Projects » Plugin Development Environment (PDE) » headless product build creating different folders for each config
headless product build creating different folders for each config [message #1864] Sun, 20 April 2008 05:47 Go to next message
I'm using the headless product build (on 3.4m6) and want to have it
create a different folder for each configuration, and do multiple
configurations in the same build step for a single product.
When I look at the generated assembly script, it very nicely assembles
everything to a different folder, and then (I am using the "folder"
output) it copies everything back to the parent folder and deletes the
per-configuration folder. So at the end, I get a single folder which
has the union of all of my configurations.
It would be nice if it just left is alone, as what it emits is just what
I want.
Here is my build.properties file:
topLevelElementType = feature
topLevelElementId = com.oaklandsw.transform.feature.product0
product=/com.oaklandsw.transform.feature.product0/transform. product
collectingFolder=transform0
archivePrefix=${collectingFolder}
runPackager=true
assemblyTempDir=${builder}/buildOutput
defaultAssemblyEnabled=true
If I export the same product using the product wizard it also creates a
folder per platform (when I select multiple platforms - actually it
fails to export platforms that are not the platform I'm running against
because it can't find the plugins for those, but I think that's a p2/pde
issue that's already known). What the export does is exactly what I want.
Re: headless product build creating different folders for each config [message #1893 is a reply to message #1864] Mon, 21 April 2008 13:50 Go to previous message
Francis,
Unfortunately there is an outstanding bug about this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=143243
Basically, when using the "folder" output, you can only do 1 config at a time.
If you were to use an archive output (zip/tar) then the separate configs would
be done properly.
The export works because it only builds 1 config at a time, and essentially does
n exports when n configs are selected.
If you want separated folders at the end, one workaround would be to use zips or
tars and then add a custom step in the customTargets.xml postBuild target that
unzips the archives into separate folders.
-Andrew
> I want.
> runPackager=true
Re: headless product build creating different folders for each config [message #566046 is a reply to message #1864] Mon, 21 April 2008 13:50 Go to previous message
Francis,
be done properly.
-Andrew
> I want.
> runPackager=true
Previous Topic:Using the "pde.build" target of generated ant scripts
Next Topic:Sending data to View
Current Time: Tue Jul 08 11:11:13 EDT 2025
Powered by FUDForum. Page generated in 0.04996 seconds
