Home » Modeling » OCL » error in creating expression using EMF enumeration
error in creating expression using EMF enumeration [message #22007] Tue, 08 May 2007 17:38 Go to next message
I am trying to create an OCL expression where the value can be anything
(i.e. an EObject, a primitive, an enumeration).
I get a Sematic exception (ERROR in (variableExpCS): (Unrecognized
variable: (ACTIVE))
when executing the following:
ExpressionsUtil.createQuery(environment, "ProductStatus.ACTIVE", true)
ProductStatus in an Enumeration where ACTIVE is one possible value.
Assuming that this API is the right API, Do I need to prepare the
"environment" to let it know about the enumerations?
kagan
Re: error in creating expression using EMF enumeration [message #22231 is a reply to message #22007] Wed, 09 May 2007 08:30 Go to previous message
Hi, Kagan,
No, you just need to use the OCL syntax for qualified names, which uses the
UML-style '::' separator instead of the Java-style '.':
ExpressionsUtil.createQuery(environment, "ProductStatus::ACTIVE", true);
OCL thought you were trying to access a static property named "ACTIVE" of
the ProductStatus classifier. :-)
Christian
> variable: (ACTIVE))
> kagan
Previous Topic:problem with parsing ocl expression in a standalone environment
Next Topic:Re: integrating ocl with emf
Current Time: Sat Jul 26 14:04:41 EDT 2025
Powered by FUDForum. Page generated in 0.24074 seconds
