| Re: Differences Eclipse Classic <> Eclipse IDE? [message #225753 is a reply to message #225727] |
Sat, 04 August 2007 22:58  |
Originally posted by: eclipse5.rizzoweb.com
M.J.Wijaya wrote:
> Absolutely new comer on Eclipse.
> What're differences between Eclipse Classic & Eclipse IDE ?
> ( http://www.eclipse.org/downloads/ )
> Which one I've to download?
That depends on what you want to do with the tool. I think the
explanations on that page do a pretty good job of guiding you, but there
are also links to "Find out more..." under each package description.
Usually what a Java programmer wants is the Eclipse IDE for Java
Developers. Even if you eventually want more of the tools, you can
easily use the built-in Update Manager to download and install them.
> Can I use JDK/JRE 6 for Eclipse ?
Yes, Eclipse runs under Java 6 just fine.
Hope this helps,
Eric
FUDForum. Page generated in 0.08475 seconds
