TTS Portuguese Characters [message #21987] |
Thu, 12 March 2009 19:07  |
For Portuguese Language
when I try to use a TTS prompts with this Latin characters(é,ã) ,I have a
wrong exporting WAR. When I export the Call Flow as a Web Application I
get the error: null Reason: null!!!!
How can I configure this in OpenVxml 3.0?
Re: TTS Portuguese Characters [message #22453 is a reply to message #22031] |
Fri, 17 April 2009 16:41   |
Hi Fernando--
This issue should be fixed; the application's XML file now handles the full
UTF-8 characterset. Update your source from the VTP repository and
recompile; if you can't do this, let me know and I'll send you a current set
of the plugins directly.
Randy
On 3/13/09 4:37 PM, in article C5E03C44.3FED%randy@openmethods.com, "Randy
Childers" <randy@openmethods.com> wrote:
> Hi Fernando--
> I believe this is an encoding issue in regards to the way the CallDesign.xml
> file is being saved. We're currently working on a separate issue which may,
> inadvertently, resolve this problem. I'll make an announcement on this list
> if it does.
> Randy Childers
> OpenMethods
> On 3/12/09 6:07 PM, in article
> 55b3ca9b8b40925d3fdf4d435d1f9c6c$1@www.eclipse.org, "Fernando Pesssoa"
>> Thanks,
Re: TTS Portuguese Characters [message #22497 is a reply to message #22453] |
Mon, 11 May 2009 19:04  |
Hi Randy,
We have same issue with UTF-8 missing xml header file for Spanish TTS
engines. Would you please send me the plugins directory too?
Thanks in advance
Luis Guaman
Interlancompu.com
Quito - Ecuador
Re: TTS Portuguese Characters [message #578253 is a reply to message #21987] |
Fri, 13 March 2009 17:37  |
Hi Fernando--
if it does.
Randy Childers
OpenMethods
Re: TTS Portuguese Characters [message #578431 is a reply to message #22031] |
Hi Fernando--
Randy
> Hi Fernando--
> if it does.
> Randy Childers
> OpenMethods
>> Thanks,
Re: TTS Portuguese Characters [message #578440 is a reply to message #22453] |
Hi Randy,
Thanks in advance
Luis Guaman
Interlancompu.com
Quito - Ecuador
FUDForum. Page generated in 0.04846 seconds
