Home » Eclipse Projects » Eclipse Platform » Modification Timesstamp change in the complete project. Why ?
Modification Timesstamp change in the complete project. Why ? [message #21970] Tue, 29 April 2003 08:11 Go to next message
Originally posted by: aheid.gmx.de
Hi, we are using Eclipse 2.1 with a Solaris based CVS 1.11 Repository that
is accessed via pserver protocol. We are quite happy with this, but from
time to time all files in a project are marked as changed. When you
Team-Syncronize with repository... , all Files are marked for an outgoing
change. In fact, the content is the same as in the archive and when you
commit them all, no new version will be created. Instead, the CVS console
says:
Modification Timestamp was changed for xxx but the content match that on the
server. The timestamp has been reset.
We use Window NT as client OS.
Anyone saw this in his CVS Installation ? Is there a solution for that ? As
this happens every 2 or 3 days, it is sometimes difficult to identify real
changes in my local copy.
Thanx
Andreas
Re: Modification Timesstamp change in the complete project. Why ? [message #22061 is a reply to message #21970] Tue, 29 April 2003 08:49 Go to previous message
Originally posted by: Michael_Valenta.oti.com
I don't know if this is the cause but Eclipse only supports CVS server
versions 1.11.1p1 and beyond.
> says:
> Thanx
> Andreas
Previous Topic:How do i open up the 'Properties' page and the Java Build Path screen?
Next Topic:View full filenames of opened java files
Current Time: Sat Jul 12 14:32:50 EDT 2025
Powered by FUDForum. Page generated in 0.03524 seconds
