M5 remove {} brackets feature. [message #225169] |
Sun, 05 March 2006 19:47  |
Hi JDT guys,
I haven't been following 3.2 dev lately, so I might have missed the
discussion
on this topic. so if I did, I apologize in advance.
It seems to me that this feature contradicts a popular programming paradigm
of placing the braces for every for/if/while. I don't want to argue
about whether
this is a good paradigm or not, but I think using braces leads to safer
and less error
prone code (ok, that was a little bit of arguing).
I think that Eclipse should encourage safer programming techniques, and this
feature (IMHO) goes the opposite way. I don't think it should be removed
once it has
been implemented, but maybe a warning in the preview window will be
appropriate.
Personally I'd add the word "recommended" to the relevant section of the
clean up dialog.
Except that - amazing job. I had no idea Eclipse/JDT could be made
better, but
it's getting better with every new milestone...
Genady Beryozkin
http://www.genady.net/
Re: M5 remove {} brackets feature. [message #225292 is a reply to message #225173] |
Mon, 06 March 2006 09:58   |
There's also bug 128780, see more comments there.
The Quick Fix you saw in Ed's blog is not intended, we'll remove that
one; it's making the list of QF too long. But for 'clean up' we want to
provide symetical options. The opinions on using braces or not are not
clear-cut as many here want to make believe. I'm a bracket fan, but I
think I'm only one of ten here in the lab.
Martin
Genady wrote:
> I now see that Ed wrote about it too:
> http://blogs.zdnet.com/Burnette/?p=16
> Genady Beryozkin
> Genady wrote:
>> Hi JDT guys,
>> discussion
>> paradigm
>> about whether
>> safer and less error
>> and this
>> removed once it has
>> appropriate.
>> the clean up dialog.
>> better, but
Re: M5 remove {} brackets feature. [message #225381 is a reply to message #225292] |
Mon, 06 March 2006 18:08  |
Commented and CC'd myself. I have no problem with the cleanup dialog.
How about adding a web link to the description/discussion for each code
style option/warning?
Genady
> to provide symetical options. The opinions on using braces or not are
> not clear-cut as many here want to make believe. I'm a bracket fan,
> but I think I'm only one of ten here in the lab.
> Martin
>> Genady Beryozkin
>> Genady wrote:
>>> Hi JDT guys,
>>> discussion
>>> paradigm
>>> about whether
>>> and this
>>> removed once it has
>>> appropriate.
>>> better, but
FUDForum. Page generated in 0.06120 seconds
