Home » Newcomers » Newcomers » Facing Problems Installing the FTP and Webdav plugin
Facing Problems Installing the FTP and Webdav plugin [message #225059] Wed, 01 August 2007 04:08
Originally posted by: arpit.selectronicindia.com
I am facing Facing Problems Installing the FTP and Webdav plugin 3.1x.
I downloaded plug-in from
( http://archive.eclipse.org/eclipse/downloads/drops/R-3.1.2-2 00601181600/index.php)
I am following this procedure given at this link
( http://devresource.hp.com/drc/resources/vxml_plug_install.js p?jumpid=reg_R1002_USEN)
1. Unzipped the plug-in in the directory that contains your Eclipse
directory. For instance if you unzipped Eclipse in C:\myDev\, also unzip
the FTP and Webdav plugin in C:\myDev\.
2. Start Eclipse and check that the FTP and Webdav plug-in is installed by
clicking on Help > About Eclipse. Click on Feature details. The FTP and
Webdav plug-in should be listed.
My problem is that sometimes it shows plug-in but sometimes it doesn't.
When it doesn't work then I tried this method also.
I copied files of "Features" && " Plugin" folders present under FTP and
Webdav folder to "Features" && " Plugin" folders under Eclipse folder.
Again same issue, sometimes it shows plug-in but sometimes it doesn't.
Please give best solution for this.
I have 1 more problem.
I have installed HP OCMP Voice Application Developer Toolkit plug-in also.
Before you create a VoiceXML project or CCXML project in Eclipse,we have
to set the preferences for them
When I click on Windows>>Preferences>>Select "Open Call Voice Application"
Then it is not opening properly. I cannot select "Schema Version" &&
"Testing Mode". As Display is not proper.
Rest of Applications are opening properly.
Please help me ASAP.
Previous Topic:BIRT Report - Platform startup
Next Topic:BIRT Report - Run time configuration files
Current Time: Fri Jul 18 22:24:59 EDT 2025
Powered by FUDForum. Page generated in 0.07636 seconds
