Home » Archived » Maven Integration (M2E) » [tycho-dev-1819] error while building jar
[tycho-dev-1819] error while building jar [message #21925] Thu, 12 February 2009 08:02 Go to next message
Tycho is fantastic: I have been looking for years for a way of integrating
my eclipse RCP build with maven wihtout success, and this one looks like a
winner.
I have managed to successfully build and install a couple of my plugins,
but then I hit this blocker and don't know where to look...
Everything goes fine until the packaginf phase:
[INFO] [osgi-packaging:package-plugin]
[INFO] Building jar:
C:\workspaces\tycho\MyPlugin\target\MyPlugin-1.0.0-SNAPSHOT. jar
[ERROR]
Internal error in the plugin manager executing goal
'org.codehaus.tycho:maven-osgi-packaging-plugin:0.3.0-DEV-18 19:package-plugin':
Mojo execution failed.
with stackTrace turned on (-e) I have the following:
Error stacktrace:
org.apache.maven.lifecycle.LifecycleExecutionException: Internal error in
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalAndHandleFailures(DefaultLifecycleExecutor.java:528)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegmentForProject(DefaultLifecycleExecutor.java:288)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegments(DefaultLifecycleExecutor.java:214)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute( DefaultLifecycleExecutor.java:172)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:218)
org.apache.maven.embedder.MavenEmbedder.execute(MavenEmbedde r.java:899)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:176)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:63)
org.codehaus.plexus.classworlds.launcher.Launcher.launchEnha nced(Launcher.java:289)
org.codehaus.plexus.classworlds.launcher.Launcher.launch(Lau ncher.java:229)
org.codehaus.plexus.classworlds.launcher.Launcher.mainWithEx itCode(Launcher.java:408)
org.codehaus.plexus.classworlds.launcher.Launcher.main(Launc her.java:351)
at org.codehaus.classworlds.Launcher.main(Launcher.java:31)
Caused by: org.apache.maven.plugin.PluginExecutionException: Mojo
execution failed.
org.apache.maven.plugin.DefaultPluginManager.executeMojo(Def aultPluginManager.java:645)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalAndHandleFailures(DefaultLifecycleExecutor.java:521)
... 16 more
Caused by: org.apache.maven.plugin.MojoExecutionException: Error
assembling JAR
org.codehaus.tycho.eclipsepackaging.PackagePluginMojo.create PluginJar(PackagePluginMojo.java:151)
org.codehaus.tycho.eclipsepackaging.PackagePluginMojo.execut e(PackagePluginMojo.java:93)
org.apache.maven.plugin.DefaultPluginManager.executeMojo(Def aultPluginManager.java:623)
... 17 more
Caused by: org.codehaus.plexus.archiver.ArchiverException: Problem
creating jar: C:\workspaces\tycho\MyPlugin\target\MyPlugin.jar (The
filename, directory name, or volume label syntax is incorrect) (and the
archive is probably corrupt but I could not delete it)
org.codehaus.plexus.archiver.AbstractArchiver.createArchive( AbstractArchiver.java:690)
org.apache.maven.archiver.MavenArchiver.createArchive(MavenA rchiver.java:332)
org.codehaus.tycho.eclipsepackaging.PackagePluginMojo.create PluginJar(PackagePluginMojo.java:147)
... 19 more
Caused by: java.io.FileNotFoundException:
C:\workspaces\tycho\MyPlugin\target\MyPlugin-1.0.0-SNAPSHOT. jar (The
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
at java.io.FileOutputStream.<init>(FileOutputStream.java:131)
org.codehaus.plexus.archiver.zip.ZipOutputStream.<init>(ZipOutputStream.java:263)
org.codehaus.plexus.archiver.zip.AbstractZipArchiver.createA rchiveMain(AbstractZipArchiver.java:322)
org.codehaus.plexus.archiver.zip.AbstractZipArchiver.execute (AbstractZipArchiver.java:242)
org.codehaus.plexus.archiver.AbstractArchiver.createArchive( AbstractArchiver.java:673)
... 21 more
[INFO]
[INFO] BUILD FAILED
[INFO]
[INFO] Total time: 8 seconds
[INFO] Finished at: Thu Feb 12 23:51:46 EST 2009
[INFO] Final Memory: 10M/18M
[INFO]
What would cause such an error ? and most importantly how to fix it!
cheers,
Patrick
Re: [tycho-dev-1819] error while building jar [message #21971 is a reply to message #21925] Thu, 12 February 2009 09:52 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
This exception does not tell much, unfortunately.
Assuming you checked available disk space and file permissions already,
can you check if C:\workspaces\tycho\MyPlugin\target gets created during
the build? package-plugin mojo does not check/create project output
folder, so it would fail if previously executed mojos did not create the
folder.
Also check bin.includes and bin.excludes in build.properties.
If both target folder and build.properties are okay, then I would like
to see full debug log with stack traces (i.e. -X -e) or a sample project
that demonstrates the problem.
Igor
Patrick Roumanoff wrote:
> integrating my eclipse RCP build with maven wihtout success, and this
> one looks like a winner.
> [ERROR]
> Error stacktrace:
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> execution failed.
> at
> at
> ... 16 more
> assembling JAR
> at
> at
> at
> ... 17 more
> at
> at
> at
> ... 19 more
> at
> at
> at
> at
> ... 21 more
> [INFO]
> [INFO] BUILD FAILED
> [INFO]
> [INFO]
> cheers,
> Patrick
Re: [tycho-dev-1819] error while building jar [message #22015 is a reply to message #21971] Thu, 12 February 2009 21:02 Go to previous messageGo to next message
thanks for your quick reply Igor,
I have figured it out: once the pom was genrated, I used Ctrl+F in the
eclipse POM editor to format it and the artifactId was split on two lines
thus reading
<artifactId>MyPlugin
</artifactId>
removing the extra line break solved the problem.
cheers,
Patrick
> can you check if C:workspacestychoMyPlugintarget gets created during
> folder.
> Igor
>> C:workspacestychoMyPlugintargetMyPlugin-1.0.0-SNAPSHOT.jar
>> [ERROR]
>> Error stacktrace:
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> execution failed.
>> at
>> at
>> ... 16 more
>> assembling JAR
>> at
>> at
>> at
>> ... 17 more
>> creating jar: C:workspacestychoMyPlugintargetMyPlugin.jar (The
>> at
>> at
>> at
>> ... 19 more
>> C:workspacestychoMyPlugintargetMyPlugin-1.0.0-SNAPSHOT.jar (The
>> at
>> at
>> at
>> at
>> ... 21 more
>> [INFO]
>> [INFO] BUILD FAILED
>> [INFO]
>> [INFO]
>> cheers,
>> Patrick
Re: [tycho-dev-1819] error while building jar [message #22060 is a reply to message #22015] Fri, 13 February 2009 12:24 Go to previous message
This looks like a bug in tycho or maven. I've opened
http://jira.codehaus.org/browse/MNGECLIPSE-1192 to track it.
> lines thus reading
> </artifactId>
> cheers,
> Patrick
>> the folder.
>> project that demonstrates the problem.
>> Regards,
>> Igor
>>> Hi,
>>> plugins, but then I hit this blocker and don't know where to look...
>>> [ERROR]
>>> Error stacktrace:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> execution failed.
>>> at
>>> at
>>> ... 16 more
>>> assembling JAR
>>> at
>>> at
>>> at
>>> ... 17 more
>>> the archive is probably corrupt but I could not delete it)
>>> at
>>> at
>>> at
>>> ... 19 more
>>> at
>>> at
>>> at
>>> at
>>> ... 21 more
>>> [INFO]
>>> [INFO] BUILD FAILED
>>> [INFO]
>>> [INFO]
>>> cheers,
>>> Patrick
Previous Topic:pluginManagement, extensions versioning issue
Next Topic:Can't run Maven tests
Current Time: Thu May 08 01:34:26 EDT 2025
Powered by FUDForum. Page generated in 0.15528 seconds
