An error has occurred when creating this editor [message #21921] |
Mon, 18 March 2002 08:44  |
Originally posted by: mwisse.hs-harz.de
Hallo!
I try to use
cdt-eclipse-R2-0125-20020308
with
eclipse-SDK-20020214-linux-motif .
I created a first C/C++ project for testing with the wizard and imported
some files. When I try to view a .c or a .h file, I get following error:
"An error has occurred when creating this editor".
What can I do?
Best regards and thanks for assistance.
Michael
Re: An error has occurred when creating this editor [message #22336 is a reply to message #22274] |
Tue, 19 March 2002 11:13   |
Hi Michael,
It sounds like you have installed and re-installed incompatible versions of
the CDT and Eclipse. Therefore, it is not clear what you currently have
installed and why you are getting the errors. To help us diagnose the
problem, can you do the following to make sure you have a "clean"
installation:
1. Remove your current eclipse\cdt installation (if possible).
2. Install the eclipse-SDK-20020214-linux-motif.zip Stable Eclipse Build.
3. Then install the cdt-eclipse-R2-0214-20020308.zip Stable CDT Build.
If you still get the same errors, can you let us know the following:
1. What Linux Distribution\Level you are running.
2. Provide a copy of your workspace/.metadata/.log file
3. Provide the steps that you went through to produce the problem.
Thanks alot...
Jeff Turnham
"Michael Wisse" <mwisse@hs-harz.de> wrote in message
news:3C96F043.2178FB8E@hs-harz.de...
> Hello Adrian!
> You are right, I used the wrong sdk. I changed to eclipse R2-0125, but I
> have the same problem, that the editor can not be created.
> Now I want to try a newer jdk, I use 1.3.0.
> I already tried to use eclipse R1.0, but I am not able to start it:
> "memory access error". Perhaps it is a problem of the jdk.
> Michael
> Michael Wisse wrote:
> > Hallo!
> > I try to use
> > with
> > What can I do?
> > Michael
Re: An error has occurred when creating this editor [message #22492 is a reply to message #22274] |
Thu, 21 March 2002 02:38  |
Now it works, with jdk 1.3.0, too. I was confused with the versions.
Thanks for assistance.
What jdk do you recommend?
Michael
> Hello Adrian!
> Michael
> > Hallo!
> > I try to use
> > with
> > What can I do?
> > Michael
FUDForum. Page generated in 1.19605 seconds
