Home » Archived » M2M (model-to-model transformation) » [ATL] transforming UML to EJB
[ATL] transforming UML to EJB [message #21911] Wed, 07 March 2007 13:59 Go to next message
Originally posted by: walcir.fontanini.cenpra.gov.br
Hi all,
Please, tell me if I am not in the wrong place. I am trying to transform
some UML model to an EJB model. The "parameter" target pattern is
not working, and I think I need a lot more "distinct-foreach" !!! It
seems that I need just one big "rule" with every possible target pattern
there .
-walcir
=== UML model ====
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="UML">
<DataType name="String"/>
<DataType name="Integer"/>
<Class name="BreakfastOrder">
<feature xsi:type="Operation" name="calculatePrice">
<parameter name="year_price" type="/1"/>
<parameter name="rate" type="/1"/>
</feature>
<feature xsi:type="Attribute" name="deliveryStatus" type="/0"/>
<feature xsi:type="Attribute" name="deliveryDate" type="/0"/>
<feature xsi:type="AssociationEnd" name="customer" lower="1"
upper="1" otherEnd="/3/@feature.3"/>
<feature xsi:type="AssociationEnd" name="breakfasts" lower="1"
upper="-1" composition="true" otherEnd="/4/@feature.2"/>
</Class>
</xmi:XMI>
==== EJB model ====
<?xml version="1.0" encoding="ISO-8859-1"?>
xmlns="EJB">
<EJBEntityComponent name="BreakfastOrder" usedTable="/1">
<feature xsi:type="EJBAttribute" name="deliveryStatus"/>
<feature xsi:type="EJBAttribute" name="deliveryDate"/>
<feature xsi:type="EJBAssociationEnd" name="customer" lower="1"
upper="1"/>
<feature xsi:type="EJBAssociationEnd" name="breakfasts" lower="1"
upper="-1" composition="true"/>
<feature xsi:type="EJBBusinessMethod" name="calculatePrice">
</feature>
</EJBEntityComponent>
<Table/>
</xmi:XMI>
And I am using an ATL code like this:
... some helpers deleted here ...
lazy rule kkkk {
from umlOper : UML!Operation
to Parameters : distinct EJB!EJBParameter
foreach (par in umlOper.parameter) (
name <- par.name
rule ClassToEntityComponent{
from class : UML!Class
( not class.isAComposition() )
to entityComponent : EJB!EJBEntityComponent (
name <- class.name.debug('debug here'),
feature <- ATTRS->union(ASSOCENDS)->union(OPERS),
usedTable <- EJBTable
EJBTable : EJB!Table (
OPERS : distinct EJB!EJBBusinessMethod
foreach (oper in class.operations()) (
name <- oper.name,
parameter <- oper->collect(e | thisModule.kkkk(e))
ATTRS : distinct EJB!EJBAttribute
foreach (attr in class.attributes())(
name <- attr.name
ASSOCENDS : distinct EJB!EJBAssociationEnd
foreach (assocEnd in class.getAssociationEnds())(
name <- assocEnd.name,
lower <-assocEnd.lower,
upper <- assocEnd.upper,
composition <- assocEnd.composition
Re: [ATL] transforming UML to EJB [message #22002 is a reply to message #21911] Wed, 07 March 2007 16:07 Go to previous messageGo to next message
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
Hi Walcir,
maybe I am missing some details about your metamodels, but I think you could write your
transformations in a different way, taking advantage of the declarative nature of ATL. See
the example rewritten below:
feature <- class.feature,
rule Operation {
from
oper : UML!Operation
to
method : EJB!EJBBusinessMethod
OPERS : distinct EJB!EJBBusinessMethod (
name <- oper.name,
parameter <- oper.parameter
rule Parameter {
from
parameter : UML!Parameter
to
out : EJB!Parameter (
name <- parameter.name
rule Attribute {
from
attr : UML!Atribute
to
out : EJB!EJBAttribute (
name <- attr.name
rule AssocEnds {
from
assocEnd : UML!AssociationEnd
to
ASSOCENDS : EJB!EJBAssociationEnd
Marcos.
walcir fontanini wrote:
> Hi all,
> some UML model to an EJB model. The "parameter" target pattern is not
> working, and I think I need a lot more "distinct-foreach" !!! It seems
> that I need just one big "rule" with every possible target pattern there .
> -walcir
> === UML model ====
> xmlns:xmi="http://www.omg.org/XMI"
> xmlns="UML">
> </feature>
> </Class>
> </xmi:XMI>
> ==== EJB model ====
> xmlns="EJB">
> upper="1"/>
> </feature>
> <Table/>
> </xmi:XMI>
> lazy rule kkkk {
> name <- par.name
> name <- oper.name,
> name <- attr.name
Re: [ATL] transforming UML to EJB (continuing) [message #22179 is a reply to message #22002] Wed, 07 March 2007 17:20 Go to previous messageGo to next message
Hello again,
I tested the code I wrote in the previous message with the EJB and UML files you provided
some days ago in the post
( http://www.eclipse.org/newsportal/article.php?id=313&gro up=eclipse.modeling.m2m#313), and
it worked fine.
The transformation generated a EJBBusinessMethod with a set of parameters (2 on that example).
Marcos.
PS.: I copied below the transformation I executed. Then you can add any extra processing
you need.
module UML2EJB; -- Module Template
create OUT : EJB from IN : UML ;
-- Tested: OK
helper context UML!Class def: getAssociationEnds(): Sequence( UML!AssociationEnd) =
let associationEnds : Sequence(UML!AssociationEnd) = self.feature->
select( e | e.oclIsKindOf(UML!AssociationEnd)) in
if associationEnds->notEmpty() then
associationEnds->iterate( e;
acc: Sequence(UML!AssociationEnd) = Sequence{} |
acc.append(e) )
else
Sequence{}
endif;
-- Tested: OK
helper context UML!Class def:isAComposition(): Boolean =
self.getAssociationEnds()->exists(end | end.otherEnd.composition = true)
rule Operation {
from
to
method : EJB!EJBBusinessMethod (
name <- oper.name,
rule Parameter {
from
to
out : EJB!EJBParameter (
rule Attribute {
from
attr : UML!Attribute
to
name <- attr.name
rule AssocEnds {
from
to
Marcos Didonet Del Fabro wrote:
> Hi Walcir,
> could write your transformations in a different way, taking advantage of
> the declarative nature of ATL. See the example rewritten below:
>> Hi all,
>> transform some UML model to an EJB model. The "parameter" target
>> pattern is not working, and I think I need a lot more
>> "distinct-foreach" !!! It seems that I need just one big "rule" with
>> Thanks,
>> -walcir
>> === UML model ====
>> xmlns="UML">
>> </feature>
>> </Class>
>> </xmi:XMI>
>> ==== EJB model ====
>> xmlns="EJB">
>> upper="1"/>
>> </feature>
>> <Table/>
>> </xmi:XMI>
>> lazy rule kkkk {
>> name <- par.name ) }
>> name <- oper.name,
>> name <- attr.name
Re: [ATL] transforming UML to EJB (continuing) [message #22300 is a reply to message #22179] Thu, 08 March 2007 09:14 Go to previous message
Marcos,
It works fine now !!! You are very right !!
Thanks a lot,
-walcir
> Hello again,
> files you provided some days ago in the post
> and it worked fine.
> Marcos.
> extra processing you need.
> -- Tested: OK
> acc.append(e) )
> else
> Sequence{}
> endif;
> -- Tested: OK
> true)
> rule Operation {
> from
> to
> name <- oper.name,
> rule Parameter {
> from
> to
> rule Attribute {
> from
> to
> name <- attr.name
> rule AssocEnds {
> from
> to
>> Hi Walcir,
>> of the declarative nature of ATL. See the example rewritten below:
>>> Hi all,
>>> Thanks,
>>> -walcir
>>> === UML model ====
>>> xmlns="UML">
>>> </feature>
>>> </Class>
>>> </xmi:XMI>
>>> ==== EJB model ====
>>> xmlns="EJB">
>>> upper="1"/>
>>> </feature>
>>> <Table/>
>>> </xmi:XMI>
>>> lazy rule kkkk {
>>> name <- oper.name,
>>> name <- attr.name
Previous Topic:Using ATL and UML2
Next Topic:EMF M1 model transformation with ATL
Current Time: Fri Jul 18 02:15:43 EDT 2025
Powered by FUDForum. Page generated in 0.29176 seconds
