Home » Eclipse Projects » JFace » How to use Databinding to provide content and labels for editable viewers with calculated values?
How to use Databinding to provide content and labels for editable viewers with calculated values? [message #21864] Fri, 17 July 2009 04:26 Go to next message
Originally posted by: TheRealHawk.Freenet.de
I know that I can do something like that:
IObservableMap[] labelMape = BeansObservables.observeMaps(
cp.getKnownElements(), new String[] { "name", "address", "phone" } );
viewer.setLabelProvider(new ObservableMapLabelProvider(labelMaps));
This works if I only want to display some properties of a list of beans.
But what should I do if I want to display calculated values in the viewer or
use an EditingSupport in the columns?
Markus
Re: How to use Databinding to provide content and labels for editable viewers with calculated values [message #21912 is a reply to message #21864] Fri, 17 July 2009 05:20 Go to previous messageGo to next message
I wrote a general purpose LabelProvider which uses Message.format() to
calculate Labels from different Attributes [1] including formatting.
I'm not sure what you mean here? You want to edit calcuated values?
Tom
[1] http://tomsondev.bestsolution.at/2009/06/27/galileo-emf-data binding-part-5/
Re: How to use Databinding to provide content and labels for editable viewers with calculated values [message #21956 is a reply to message #21912] Fri, 17 July 2009 06:31 Go to previous messageGo to next message
"Tom Schindl" <tom.schindl@bestsolution.at> schrieb im Newsbeitrag
news:h3pfop$ef7$1@build.eclipse.org...
>> "phone" } );
>> or
Of course not. :-)
Just an example: I have a list of persons with property name, surname,
dateOfBirth
If I only want to display the properties in a TableViewer I can use the
ObservableMapLabelProvider.
But what if:
1. I want to also display calculated values - e.g. age?
For this I don't can use the ObservableMapLabelProvider - I need an
ObservableValueLabelProvider for each TableViewerColumn, so that I also can
display CalculatedValues in the viewer.
2. I want to edit some properties?
For this I also have to create my own TableViewerColumn with an
ObservableValueEditingSupport.
Now my question is: Is there a eclipse-default-way like
ObservableValueLabelProvider or ObservableValueEditingSupport?
Markus
> Tom
Re: How to use Databinding to provide content and labels for editable viewers with calculated values [message #22000 is a reply to message #21956] Fri, 17 July 2009 06:36 Go to previous messageGo to next message
No.
>>> "phone" } );
>>> or
> Of course not. :-)
> dateOfBirth
> But what if:
> Markus
>> Tom
Re: How to use Databinding to provide content and labels for editable viewers with calculated values [message #22044 is a reply to message #21956] Fri, 17 July 2009 13:27 Go to previous message
Markus,
See answers below
> dateOfBirth
> But what if:
We do have ObservableMapCellLabelProvider if this is what you're
thinking about, but it won't help you with calculated values. And since
we don't yet have ComputedMap yet then that won't work either. Probably
the simplest route is to implement a SimpleValueProperty that converts a
birth date to an age:
public class DateAgeProperty extends SimpleValueProperty {
public INativePropertyListener adaptListener( ISimplePropertyListener
listener ) {
return null;
protected Object doGetValue( Object source ) {
Date date = (Date) source;
// convert date to age and return
protected void doSetValue( Object source, Object value ) {
throw new UnsupportedOperationException();
public Object getValueType() {
return Integer.class;
Then chain the dateOfBirth and age properties together:
IObservableMap ages = BeanProperties
.value("dateOfBirth")
.value(new DateAgeProperty())
.observeDetail(contentProvider.getKnownElements());
I don't follow you here. Could you elaborate?
Matthew
Previous Topic:Form head client next to title like before 3.3 or replace title with StyledText?
Next Topic:ComboBoxPropertyDescriptor is not intended to be subclassed
Current Time: Sun Jul 27 03:12:02 EDT 2025
Powered by FUDForum. Page generated in 0.08311 seconds
