Home » Language IDEs » AspectJ » Ajdt plugin questions
Ajdt plugin questions [message #21856] Fri, 16 May 2003 01:09 Go to next message
Originally posted by: delasoul.operamail.com
I am still quite new to aop and hope to find some answers to my questions
here:
I have installed Eclipse 2.1 with the newest ajdt plugin and am trying to
run the examples that come with aspectj from Eclipse.
1. Is there any way to have code completion when coding an aspect(Eclipse
wants
a class or interface keyword instead of aspect)
2. Do I have to create an AspectJ project - or will a normal java project,
where I create my aspects and compile with the aspectj compiler do as
well?
Which disadvantages come with this approach?
3. When trying to run the tracing examples in Eclipse I have the following
problem:
In Tracing version 2, where you have an abstract aspect that holds the
tracing methods and an aspect that inherits from this one, the main()
is also in this derived aspect.
When trying to run this in Eclipse it complains about "This selection
does
not contain a main type"
I then tried to write a class with a main but there the methods of the
aspects are not recognized.
Is there any way to run this in Eclipse - or can I only do it from
command
line?
Thanks very much in advance for any help
deLaSoul
Re: Ajdt plugin questions [message #21949 is a reply to message #21856] Fri, 16 May 2003 04:21 Go to previous message
Originally posted by: clemas.hursley.ibm.com
Let me go through your questions...
> wants a class or interface keyword instead of aspect)
Not yet. Because the eclipse parser doesn't understand the format of code
within aspects, it can't provide either the eager parsing facility or the
code completion behaviour. But that will come in time, its on our to-do
list :)
> well?
If it is a normal Java project, then it will use the normal java builder -
this won't understand aspects. If you change the java project to an
AspectJ project, we swap out the java builder and swap in the aspectj
builder (ajc). The main disadvantage of using the aspectj builder rather
than the java builder is that we don't fully support incremental
compilation yet - so you have to do a full build every time. There is
some experimental incremental compilation behaviour in the latest AJDT
(1.1.2) but its not ready for production use yet.
> problem:
> does
> command
> line?
Hmm - I've never run that example from aspectj in eclipse - can anyone
else help with this point?
On the second point, you can run everything from the command line, but
you'll need to download the aspectj install image (see
http://eclipse.org/aspectj) - if you download and install AspectJ 1.1 you
will get the command line compiler 'ajc'.
cheers,
Andy.
AJDT Development.
Re: Ajdt plugin questions [message #567308 is a reply to message #21856] Fri, 16 May 2003 04:21 Go to previous message
list :)
> well?
> problem:
> does
> command
> line?
cheers,
Andy.
AJDT Development.
Previous Topic:Ajdt plugin question2
Next Topic:Ajdt plugin question2
Current Time: Thu May 08 04:13:07 EDT 2025
Powered by FUDForum. Page generated in 0.26462 seconds
