| Home » Eclipse Projects » Plugin Development Environment (PDE) » Launching a "RunAs" Task from a Wizard
 Goto Forum:|
| Launching a "RunAs" Task from a Wizard [message #21851] | Sat, 13 September 2008 07:18  |  |
| Eclipse User  |  |  |  |  | I would like to integrate an available RunAs task (called "oaw workflow", BTW) in a wizard I currently implementing, that is the call of this task
 shall have the same effect to the eclipse project as the task would have
 manually launched by a user.
 In this context:
 1. Can I identify how the "RunAS Oaw workflow" entry is attached
 to the underlying code (oaw plugin)?
 That is, I need the method call that is represented by "RunAS Oaw
 workflow".
 I guess that the menu item "RunAs" is an extension point.
 2. ...
 Thanks in advance for your support
| Re: Launching a "RunAs" Task from a Wizard [message #40443 is a reply to message #21851] | Wed, 14 January 2009 10:24  |  |
| Eclipse User  |  |  |  |  | Originally posted by: szchaler.acm.org
 --------------000600030706050706080009
 Look into the oAW source code. In the org.openarchitectureware.workflow
 you'll find LaunchDelegate implementations that do what you need.
 There's also code there that helps you understand how to call them. I
 used something like the following:
 ILaunchConfigurationType configType =
 DebugPlugin.getDefault()
 .getLaunchManager()
 .getLaunchConfigurationType(
 IWfLaunchConfigurationConstants.WORKFLOW_LAUNCH_CONFIGURATIO N_TYPE_ID);
 ILaunchConfigurationWorkingCopy launchConfig =
 configType.newInstance(null, "generate.oaw");
 launchConfig.setAttribute(
 IWfLaunchConfigurationConstants.ATTR_OAW_WORKFLOW_FILE,
 workflowFile.getFullPath().toString());
 IJavaLaunchConfigurationConstants.ATTR_PROJECT_NAME,
 project.getName());
 * Wait for build jobs here. For some reason, whenever I am not
 * debugging this code, DebugUITools run into a NullPointerException
 * when trying to do the waiting themselves
 * This workaround code was copied from WorkflowLaunchDelegate.launch()
 Job[] autoBuildJobs;
 Job[] manBuildJobs;
 do {
 autoBuildJobs = Job.getJobManager().find(
 ResourcesPlugin.FAMILY_AUTO_BUILD);
 manBuildJobs = Job.getJobManager().find(
 ResourcesPlugin.FAMILY_MANUAL_BUILD);
 } while (autoBuildJobs.length > 0 || manBuildJobs.length > 0);
 DebugUITools.launch(launchConfig, "run");
 Notice, that this will trigger the workflow in a separate launch; that
 is in a separate Job. I have still to figure out how to wait till its done.
 Steffen
 > of this task shall have the same effect to the eclipse project as the
 > task would have manually launched by a user.
 > In this context:
 > workflow".
 > 2. ...
 Dr. rer. nat. Steffen Zschaler
 Senior Research Associate
 Lancaster University
 Lancaster, United Kingdom
 Email szschaler@acm.org
 Phone +44 (01524) 510354
 WWW   http://www.steffen-zschaler.de/
 Consider submitting to ECMDA-FA 2009, the 5th European Conference on
 Model-Driven Architecture Foundations and Applications.
 http://www.ecmda-fa.org/
 Consider submitting to QoSA 2009, the 5th International Conference on
 the Quality of Software-Architectures.
 http://qosa.ipd.uka.de/
 Consider submitting to MiSE 2009, the 3rd International Workshop on
 Models in Software Engineering
 http://wikiserver.sse.cs.tu-bs.de/mise09
 <html>
 <head>
 http-equiv="Content-Type">
 </head>
 Hi,<br>
 <br>
 used something like the following:<br>
 <br>
 <blockquote>
 <pre>ILaunchConfigurationType configType =
 .getLaunchManager()
 project.getName());
 Job[] manBuildJobs;
 do {
 </pre>
 </blockquote>
 done.<br>
 <br>
 Regards,<br>
 <br>
 Steffen<br>
 <br>
 Karl Philipp wrote:
 <blockquote
 cite="mid:ab5cc0f38aa7b88c28e8af6e13016798$1@www.eclipse.org"
 type="cite">I would like to integrate an available RunAs task (called
 call of this task shall have the same effect to the eclipse project as
 the task would have manually launched by a user.
 <br>
 <br>
 In this context:
 <br>
 <br>
 <br>
| Re: Launching a "RunAs" Task from a Wizard [message #588252 is a reply to message #21851] | Wed, 14 January 2009 10:24  |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------000600030706050706080009
 .getLaunchManager()
 project.getName());
 Job[] manBuildJobs;
 do {
 Steffen
 > In this context:
 > workflow".
 > 2. ...
 <html>
 <head>
 </head>
 Hi,<br>
 <br>
 <br>
 <blockquote>
 .getLaunchManager()
 project.getName());
 Job[] manBuildJobs;
 do {
 </pre>
 </blockquote>
 done.<br>
 <br>
 Regards,<br>
 <br>
 Steffen<br>
 <br>
 Karl Philipp wrote:
 <blockquote
 <br>
 <br>
 In this context:
 <br>
 <br>
 <br>
 Current Time: Fri Oct 31 15:55:24 EDT 2025
 Powered by FUDForum . Page generated in 0.23829 seconds |
