Home » Eclipse Projects » Remote Application Platform (RAP) » Relation to Portals
Relation to Portals [message #1852] Thu, 30 November 2006 14:44 Go to next message
Originally posted by: mail.miketech.net
I am currently exploring portals/portlets and wsrp. The RCP has some
similarities to a portal. Different portlets, that can be minimized, or
maximized. Or the view can be customized.
Is RAP similar to RCP? So that I can build RCP with web components and
ajax? Or is the idea only to write web applications with java, without
writing html and javascript manually?
My idea is: Is there any relation of RAP to portals? Are there any
similarities? So that maybe RAP is an alternative to actual portals?
Or is this not comparable?
Greetings
Michael
Re: Relation to Portals [message #1871 is a reply to message #1852] Tue, 05 December 2006 05:21 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
at the current stage there are no plans for RAP to support portals/portlets,
since this is beyond the scope of the technology project. The RAP rendering
engine manages the whole client side document and does not support simple
snippets that could be included into portal pages as laid down by the portal
specification. But it may be possible to build an application on top of RAP
that integrates portlet snippets into a kind of portlet view. But actually
I'm not familiar enough with the portlet specification to answer that point
thoroughly.
Frank Appel
"Michael Gebhart" <mail@miketech.net> schrieb im Newsbeitrag
news:pan.2006.11.30.19.44.30.447973@miketech.net...
> Greetings
> Michael
Re: Relation to Portals [message #1883 is a reply to message #1871] Tue, 05 December 2006 09:25 Go to previous messageGo to next message
thanks for your answer. So RAP is "only" the equivalent of RCP for the
web, right? So the idea is to create web applications not portals in the
way at it is done by Java Portal + Portlets and so on.
Greetings
Mike
Re: Relation to Portals [message #1897 is a reply to message #1883] Thu, 07 December 2006 02:46 Go to previous message
Hi again,
you are right, RAP provides a programming model for web-development that is
known by RCP developers. As RCP RAP will provide a workbench with view-/
editor-parts and selection-service for example, using a similar widget
library (RWT equivalent to SWT) and a JFace derivative.
Frank Appel
Previous Topic:Failed to register resource
Next Topic:RAP sample archive corrupted
Current Time: Fri Jul 25 02:27:10 EDT 2025
Powered by FUDForum. Page generated in 0.32147 seconds
