Home » Modeling » GMF (Graphical Modeling Framework) » how to listen to the change when I add a connection in editor?
how to listen to the change when I add a connection in editor? [message #21770] Wed, 16 August 2006 22:41 Go to next message
Originally posted by: dzhpingbo.sohu.com
I use AdapterFactoryContentProvider and overwrite its
notifyChanged(Notification notification) method, it can listen most of the
changes in the Editor,such as add,delete nodes and so on,but can not listen
to the change when I add a connection between nodes.
It looks strange, I think it should do the listening of connections, but it
didn't in my case, I want to know if there is any other way to listen for
the change when I add a connection between nodes?
Re: how to listen to the change when I add a connection in editor? [message #22463 is a reply to message #21770] Thu, 17 August 2006 10:25 Go to previous messageGo to next message
Connecting 2 nodes will result in changing at least three EObjects :
1 - The Source View, this will result in firing an add event on the
SourceEdges EStructual feature of this view
2- The target View, this will result in firing an add event on the
TargetEdges EStructual feature of this view
3- The diagram that contain this edge, this will fire an add event on
the persistedChildren or the transientChildren EStructual feature of
this Diagram
so, you can catch the event you like in the appropriate edit part.
Re: how to listen to the change when I add a connection in editor? [message #22550 is a reply to message #22463] Thu, 17 August 2006 11:46 Go to previous message
> 3- The diagram that contain this edge, this will fire an add event on the
> persistedChildren or the transientChildren EStructual feature of this
> Diagram
yes, I agree with you. But I don't want to change the code which is
generated by gmf, regarding that gmf will be updated in future.
First try, I new AdapterFactoryContentProvider() and overwrite its
notifyChanged(Notification notification) method and listen to the changes,
unfortunately, it doesn't work in my case.
How can I listen to this change without change the code generated by gmf?
thank you.
Previous Topic:Menu for items
Next Topic:GMF questions
Current Time: Tue Jul 08 19:47:32 EDT 2025
Powered by FUDForum. Page generated in 0.03746 seconds
