Home » Language IDEs » ServerTools (WTP) » XML comment colors
XML comment colors [message #223461] Tue, 04 November 2008 14:48 Go to next message
Originally posted by: nowhere.a.com
If I have comments in an XML file which are outside the DTD portion,
then the syntax colors in the XML editor preferences are honoured.
However I cannot find where to change the colours of the comments
inside the DTD portion. I must have done it somewhere at one time,
because the colour is light grey which I prefer.
Eclipse 3.4.0 WPT 1.1.2
Wojtek :-)
Re: XML comment colors [message #223469 is a reply to message #223461] Tue, 04 November 2008 15:58 Go to previous messageGo to next message
> However I cannot find where to change the colours of the comments inside
> the DTD portion. I must have done it somewhere at one time, because the
Take a look at the XML->DTD Files->Syntax Coloring. I suspect you'll
find it there.
Dave
Re: XML comment colors [message #223477 is a reply to message #223469] Tue, 04 November 2008 16:13 Go to previous message
David Carver wrote :
> Wojtek wrote:
>> If I have comments in an XML file which are outside the DTD portion, then
> Take a look at the XML->DTD Files->Syntax Coloring. I suspect you'll find
> it there.
I need to see an optometrist...
Wojtek :-)
Previous Topic:Can Native2Ascii write to the /build directory?
Next Topic:Sharing Servers and runtimes in WTP
Current Time: Thu Jul 17 21:01:29 EDT 2025
Powered by FUDForum. Page generated in 0.28025 seconds
