TPTP 4.0 perfmonagent problem [message #21754] |
Tue, 12 July 2005 02:43  |
Originally posted by: varaya.syamanond.centrelink.gov.au
Hi all,
I'm trying to work through launching PerfMon agent and I'm not sure if
it's even monitoring anything at all. When I opened the Agent Control
view, there are no data in there. Also, I can't open of the Statistics
views. Can you please point me in the right direction?
Thank you :-)
Sylvia
Re: TPTP 4.0 perfmonagent problem [message #21932 is a reply to message #21843] |
Tue, 12 July 2005 21:19   |
Hi George,
I'm using TPTP version 4.0. Once I launch the agent, I do see the agent
appearing in the Profiling Monitor with the pause symbol beside it. I then
right click and select "Start Monitoring". The agent icon then has the
"monitoring" underneath it. However, when I select Agent Control view,
there are no data anywhere (ie. the agent icon just appear by itself in
the Agent Control view). Thank you very much for your help :-)
Sylvia
George Christelis wrote:
> Hi Sylvia,
> Once you launch the agent, what do you see in the Profiling Monitor?
> Does the agent appear, with a pause symbol beside it? If so, remember
> that you need to Start Monitoring the agent from the Profiling Monitor
> in order to gather data or control the agent.
> Finally, what version of TPTP are you using?
> Thanks!
> George
> Sylvia S. wrote:
>> Hi all,
>> Thank you :-)
>> Sylvia
Re: TPTP 4.0 perfmonagent problem [message #21977 is a reply to message #21932] |
Wed, 13 July 2005 21:25  |
Okie, I have decided to go back to Hyades v3.2.0 and I can get the
perfmonagent to launch and collect data properly now :-)
Sylvia
Sylvia S. wrote:
> Hi George,
> Sylvia
>> Hi Sylvia,
>> Thanks!
>> George
>> Sylvia S. wrote:
>>> Hi all,
>>> Thank you :-)
>>> Sylvia
FUDForum. Page generated in 0.04436 seconds
