Home » Eclipse Projects » Eclipse Platform » Team work with Eclipse v2 and v3
Team work with Eclipse v2 and v3 [message #223173] Tue, 06 April 2004 17:15 Go to next message
Originally posted by: news-reply-200404.iclipse.org
I use Eclipse 3.0M8, my collegues use version 2. We use the CVS
support of Eclipse to access our Java project repository. When I try
to checkout the project from the repository, Eclipse does not treat it
as a Java project, and I cannot work on it. Is there an
incompatibility between v2 and v3 at that point?
Igor
Igor
the [i]clipse project
www.iclipse.org
Re: Team work with Eclipse v2 and v3 [message #223189 is a reply to message #223173] Tue, 06 April 2004 17:33 Go to previous messageGo to next message
Originally posted by: smesh.openrules.com
Some requirements for Java project:
- '.classpath' file in project's root
- javanature and builder in '.project' file
Are they satisfied?
Sam Mesh - http://openrules.com
Re: Team work with Eclipse v2 and v3 [message #223237 is a reply to message #223173] Tue, 06 April 2004 18:14 Go to previous messageGo to next message
Yeah, I had some difficulty here too. Try this way:
Goto the CVS repos perspective.
Pick your project.
From the pop-up, checkout-as
checkout w/ "New Project Wizard"
java->java project (the crucial step)
It is not a 2 vs 3 issue. We use 2 & 3 and Codeguide and who knows
whatelse here, without probs.
Igor Akkerman wrote:
> Igor
> Igor
> www.iclipse.org
Re: Team work with Eclipse v2 and v3 [message #223242 is a reply to message #223237] Tue, 06 April 2004 18:36 Go to previous messageGo to next message
Usually, we organize our CVS not in the CVS-module <-> Eclipse-project
way. It's not convenient to have either modules or projects as a
first-level entities. (what make first-level children so special?:) So,
we did not have mentioned here 2.X & 3.X problems yet.
Re: Team work with Eclipse v2 and v3 [message #223506 is a reply to message #223237] Wed, 07 April 2004 08:11 Go to previous messageGo to next message
Originally posted by: news-reply-200403.iclipse.org
Thanks! That worked. I didn't try it that way.
Igor
>Pick your project.
>> Igor
>> Igor
>> www.iclipse.org
Re: Team work with Eclipse v2 and v3 [message #223514 is a reply to message #223189] Wed, 07 April 2004 08:12 Go to previous message
It seems that my checkout operation was wrong. It works now. Thank
you!
Igor
>Are they satisfied?
Previous Topic:Disable finish button in multi-page wizard
Next Topic:binary .jar files as plugin
Current Time: Sat Jun 07 17:08:04 EDT 2025
Powered by FUDForum. Page generated in 0.23792 seconds
