Home » Archived » Glimmer » (suse) I can't install glimmer
(suse) I can't install glimmer [message #1844] Sun, 19 April 2009 06:24 Go to next message
hi there!
here is my problem : I downloaded eclipse 3.4; then I compiled JRuby
from the subversion directory (it ran well), and I installed the RDT
plugin; at the first launch, eclipse told me it has detected the JRuby
installation : all this is good.
but my aim is to use eclipse, JRuby and glimmer (a project whose goal is
to build easily GUIs) (see
http://eclipse.dzone.com/articles/an-introduction-glimmer).
but I don't see clearly how to make it run all together.
from the archive of glimmer (at the address
https://rubyforge.org/frs/?group_id=4782&release_id=2178 8), I tried to
run a tic-tac-toe sample, without success :
this file:
# Copyright (C) 2007-2008 Nick Malnick and Annas Al Maleh
# Licensed under the LGPL. See /COPYING.LGPL for more details.
#require File.dirname(__FILE__) + "/../../src/swt"
require File.dirname(__FILE__) + "/tic_tac_toe_board"
class TicTacToe
include_package 'org.eclipse.swt'
include_package 'org.eclipse.swt.widgets'
include_package 'org.eclipse.swt.layout'
include Glimmer
def initialize
causes this error:
tic_tac_toe.rb:10:in `method_missing': undefined method
`include_package' for TicTacToe:Class (NoMethodError)
from tic_tac_toe.rb:5
and this file:
class TicTacToe
# include_package 'org.eclipse.swt'
# include_package 'org.eclipse.swt.widgets'
# include_package 'org.eclipse.swt.layout'
include Glimmer
def initialize
causes this error:
tic_tac_toe.rb:14:in `const_missing': uninitialized constant
TicTacToe::Glimmer (NameError)
could you help me to make this sample run (maybe many steps will be
necessary, due to the successive errors that will appear).
thank you for having all read,
olivier.
Re: (suse) I can't install glimmer [message #495380 is a reply to message #1844] Wed, 04 November 2009 11:46 Go to previous message
Glimmer's source code moved to eclipse.org, so grab it from there instead:
http://dev.eclipse.org/svnroot/technology/org.eclipse.glimme r.core
And here are the up-to-date instructions:
http://eclipse.org/glimmer/instructions.php
Andy
Re: (suse) I can't install glimmer [message #565883 is a reply to message #1844] Wed, 04 November 2009 11:46 Go to previous message
Andy
Previous Topic:Glimmer Webinar - Sept. 23
Next Topic:is there anybody in there?
Current Time: Fri Jul 25 09:43:57 EDT 2025
Powered by FUDForum. Page generated in 0.32560 seconds
