Home » Modeling » Epsilon » NPE on transformation.
NPE on transformation. [message #21720] Fri, 03 July 2009 10:15 Go to next message
Hi Dimitris, I'm trying to make the composition/transformation that we
were talking about in the other thread.
However, I'm getting a NPE when running it (whole stack below).
For what I see, the problem is while saving the results (I cleaned all
ConcurrentModificationExceptions thrown by the transf. after realizing
that where cause by opposite references).
So my guess is that the transformation should be ok.
The resulting file is created, although it's empty. The target metamodel
was previously registered.
Do you have any ideas of which could be the cause of such exception?.
Does Epsilon has any restrictions on the use of library (Ecore, UML,
XSD) types?, I believe I've seen similar error messages in other tools,
related to the use of external types . I'm using Ecore primitive types
in the target metamodel.
Juan Pedro
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eURIFragmentSegm ent(BasicEObjectImpl.java:294)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getURIFragm ent(ResourceImpl.java:671)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.getURIFragmen t(XMLResourceImpl.java:422)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getURIFragment( XMLHelperImpl.java:718)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getIDREF(XMLHel perImpl.java:753)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveIDRefSingle(X MLSaveImpl.java:1954)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1300)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2667)
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:90)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:592)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:256)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:205)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1344)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:986)
at org.eclipse.epsilon.emc.emf.EmfModel.store(EmfModel.java:202 )
at org.eclipse.epsilon.eol.models.Model.dispose(Model.java:153)
org.eclipse.epsilon.emc.emf.AbstractEmfModel.dispose(Abstrac tEmfModel.java:464)
org.eclipse.epsilon.eol.models.ModelRepository.dispose(Model Repository.java:217)
org.eclipse.epsilon.eol.dt.launching.EclipseContextManager.t eardown(EclipseContextManager.java:55)
org.eclipse.epsilon.eml.dt.launching.EmlLaunchConfigurationD elegate.launch(EmlLaunchConfigurationDelegate.java:91)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:880)
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1083)
Re: NPE on transformation. [message #21765 is a reply to message #21720] Fri, 03 July 2009 10:17 Go to previous messageGo to next message
Hi Juan Pedro,
Could you please attach your programs/metamodels/models (or a minimal
subset that reproduces the problem) so that I can have a look?
Dimitris
> Juan Pedro
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: NPE on transformation. [message #21810 is a reply to message #21765] Fri, 03 July 2009 11:11 Go to previous message
I just sent it to your private email box.
Juan Pedro
Dimitris Kolovos escribió:
> Hi Juan Pedro,
> Cheers,
> Dimitris
>> we were talking about in the other thread.
>> all ConcurrentModificationExceptions thrown by the transf. after
>> realizing that where cause by opposite references).
>> metamodel was previously registered.
>> tools, related to the use of external types . I'm using Ecore
>> primitive types in the target metamodel.
>> Regards,
>> Juan Pedro
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: NPE on transformation. [message #570377 is a reply to message #21720] Fri, 03 July 2009 10:17 Go to previous message
Hi Juan Pedro,
Dimitris
> Juan Pedro
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NPE on transformation. [message #570394 is a reply to message #21765] Fri, 03 July 2009 11:11 Go to previous message
Juan Pedro
> Hi Juan Pedro,
> Cheers,
> Dimitris
>> Regards,
>> Juan Pedro
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:NPE on transformation.
Next Topic:Odd behaviour when using EuGENia
Current Time: Sat Jul 26 13:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.09727 seconds
