Home » Language IDEs » C / C++ IDE (CDT) » Another JNI UnsatisfiedLinkError
Another JNI UnsatisfiedLinkError [message #222937] Wed, 03 September 2008 13:21 Go to next message
Originally posted by: dontreplyhere.inter.net
I know there are a lot of answers to this question, and I'm pretty sure all
the usual stuff (package name, location of the dll) is correct in my case.
I reduced the issue to a simple HelloWorld style problem and I fear I have
to a CDT problem, that's why I'm posting for help here.
I use the same .cpp file and javah generated .h file for a VisualStudio
project, which creates a DLL that works fine.
Creating that dll with latest Eclipse CDT and its built-in make (using
minGW)
creates a libMyLib.dll file, which can be loaded, but produces this
Exception in thread "main" java.lang.UnsatisfiedLinkError:
com.osisoft.JNITest.GetMessage()Ljava/lang/String;
at com.osisoft.JNITest.GetMessage(Native Method)
at com.osisoft.JNITest.main(JNITest.java:18)
The java code is:
package com.osisoft;
public class JNITest {
static String LibPathVS =
"D:\\MyDocuments\\Visual Studio
2008\\Projects\\JNITest\\Release\\JNITestLib.dll";
static String LibPathCDT =
" D:\\EclipseWorkspaceC_J\\JNITestLib\\Release\\libJNITestLib. dll ";
static {
//System.loadLibrary("JNITestLib");
System.load(LibPathCDT);
native String GetMessage();
JNITest t = new JNITest();
String s= t.GetMessage(); // fails here, but only with LibPathCDT
System.out.println(s);
I copied the method declaration from the generated include file and
implemented the c++ this way:
#include "com_osisoft_JNITest.h"
JNIEXPORT jstring JNICALL Java_com_osisoft_JNITest_GetMessage
(JNIEnv * env, jobject) {
return env->NewStringUTF("Hello from JNITestLib.dll");
All includes are fine, everything compiles and links without error, of
course:
**** Build of configuration Release for project JNITestLib ****
**** Internal Builder is used for build ****
g++ -ID:\EclipseWorkspaceC_J\JavaTest\Output
-IC:\Program Files\Java\jdk1.6.0_07\include
-IC:\Program Files\Java\jdk1.6.0_07\include\win32
-O0 -Wall -c -fmessage-length=0
-oJNITestLib.o ..\JNITestLib.cpp
g++ -shared -olibJNITestLib.dll JNITestLib.o
Build complete for project JNITestLib
The DLLs are there and the System.load() works well.
What else to observe ? Which setting did I miss?
Re: Another JNI UnsatisfiedLinkError [message #222976 is a reply to message #222937] Thu, 04 September 2008 04:43 Go to previous messageGo to next message
> static {
On Windows, . is added to the path, such that if you execute this
program from the folder D:\MyDocuments\Visual Studio
2008\Projects\JNITest\Release, it will find JNITestLib.dll. It will,
however, not find the other one!
How do you specify the -I’s? Or does Eclipse do that for you?
I’d recommend using System.loadLibrary() and putting the dll in a
suitable place, or starting the jvm with
-Djava.library.path=/path/to/dll. You can also do this from the Eclipse
launch configuration editor.
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Re: Another JNI UnsatisfiedLinkError [message #223096 is a reply to message #222937] Thu, 04 September 2008 08:50 Go to previous messageGo to next message
Just in case it helps anyone else:
> case.
Finally I found the strange linker flag
-Wl,--kill-at
"to ensure that the __stdcall naming convention is used"
I added this to Project Properties --> C/C++ Build -->Settings
In the tab Tool Settings at MinGW C++ Linker --> Miscellaneous
there's an all-purpose Linker flags field, where it is really applied:
g++ -Wl,--kill-at -shared -olibJNITestLib.dll JNITestLib.o
And the UnsatisfiedLinkError is gone !!!
What a strange thing:
IMO Eclipse CDT is not yet really helpful for Java JNI
( and initially I thought to even get mixed debugging for free ;)
Re: Another JNI UnsatisfiedLinkError [message #223103 is a reply to message #222976] Thu, 04 September 2008 12:08 Go to previous messageGo to next message
> How do you specify the -I's? Or does Eclipse do that for you?
You can, and should, add paths to the Eclipse environment.
Project properties --> C++ General --> Paths and symbols
They show up in the "includes" folder.
> I'd recommend using System.loadLibrary() and putting the dll in a
Sure, System.loadLibrary() is -finally- the recommended way, because
it's platform independent. But I wanted to be sure to easily switch to the
freshly generated dll and make sure not to be fooled by some library
searching mechanism (finding something I did not expect).
Thus I chose the full path and file extension. And, the dll was found
and loaded.
No, it was the missing -Wl,--kill-at (what an obscure syntax;)
MinGW linker option, which produced wrong method names ...
And CDT does not really help with this setting (or I did not find the
correct location but used C/C++ Build -->Settings
BTW: Thanks for your reply, Hendrik!
- M
Re: Another JNI UnsatisfiedLinkError [message #223164 is a reply to message #223103] Fri, 05 September 2008 06:32 Go to previous message
Yes, but unfortunately, I am unable to let Eclipse generate the
makefiles since I use SWIG also.
Unless someone knows how to add additional targets to the
Eclipse-generated makefiles, in which case I might consider trying that.
And it should be cross-platform, of course.
Blame gcc.
Indeed, it is in the MinGW FAQ: http://www.mingw.org/node/41.
Specifically, it refers to http://www.mingw.org/node/41. I agree they
might stress the -Wl,--kill-at, since it is what makes the MinGW style
different from Linux. You could see that by comparing the usual
compilation options. (It’s what I did: I have one general makefile
which contains the common options and then three platform-dependent
makefiles which are included based on a shell escape to uname -a, and
which add platform-specific options.
For Linux:
# fPIC is necessary for the linker
CFLAGS += -fPIC
# create a shared library
LINKERFLAGS += -shared
For MinGW:
# MinGW needs some extra linker flags, see
http://www.mingw.org/mingwfaq.shtml#faq-jni-dll
LINKERFLAGS += -D_JNI_IMPLEMENTATION_ -Wl,--kill-at
For Mac (OS X):
# fPIC is necessary for the linker, arch for Mac
CFLAGS += -fPIC -arch x86_64
LINKERFLAGS += -bundle
# extra linker flags for Mac
LINKERFLAGS += -arch x86_64 -framework JavaVM
Additionally, they define the name of the library and the jdk include
paths.)
I had similar trouble trying to compile a JNI jar on Linux: the Eclipse
makefile did not include -fPIC, which made the lib unusable. Similarly,
you’d expect it to include -Wl,--kill-at if you compile a shared library
with MinGW. Or at least ask you whether you want it, since I think
non-Java libraries might not need it.
Cheers, H.
Hendrik Maryns
Previous Topic:Software update problem in Eclipse Platform
Next Topic:org.eclipse.ant.AntBuilderLaunchConfigurationType does not exist
Current Time: Tue Jun 03 06:08:10 EDT 2025
Powered by FUDForum. Page generated in 0.03674 seconds
