Home » Eclipse Projects » GEF » Logic Editor Question: Add a LogicLabel to Circuit
Logic Editor Question: Add a LogicLabel to Circuit [message #21711] Fri, 27 September 2002 02:01 Go to next message
I would like to change the logic in logic editor example, so that every
circuit has an logic label inside it everytime a user seclect that
component.
So In the constructor of teh CircuitEditPart, I add this line:
addChildVisual(new LogicLabelEditPart(), 0);
I can see the label in the editor, but
- it just should an empty rectangle, the text "label" is missing.
- which I click the mose over it, the curser did not change and I can't add
text inside that logic label
Is there something I miss?
Thanks for your help again.
Re: Logic Editor Question: Add a LogicLabel to Circuit [message #22028 is a reply to message #21711] Fri, 27 September 2002 14:19 Go to previous messageGo to next message
I tried addChild(new LogicLabelEditPart(), -1) instead of addChildVisual(),
it fails with a NullPointer Exception.
When I manually add a LogicLabel to the Container, it did break at
addChildVisual(), so I don't know what I am missing.
Thanks.
"Sam Cheung" <scheung@novarra.com> wrote in message
news:an0r2k$rgo$1@rogue.oti.com...
> component.
add
Re: Logic Editor Question: Add a LogicLabel to Circuit [message #22071 is a reply to message #21711] Fri, 27 September 2002 15:24 Go to previous message
> component.
I already responded to this question below. Do NOT new an EditPart. You
need a Label in the *model*, not just in the EditParts.
add
Previous Topic:Printer, graphic export and zoom supports in GEF
Next Topic:Using TreeViewer with GrapicalViewerWithPalette
Current Time: Sat Jul 26 06:43:55 EDT 2025
Powered by FUDForum. Page generated in 0.26590 seconds
