Home » Modeling » OCL » Re: OCL function
Re: OCL function [message #21693] Thu, 03 May 2007 08:04 Go to next message
Andrej,
OCL has its own newsgroup where you should ask this question. I've
added it to the "to" list in my reply so you don't need to repost your
question.
Andrej S wrote:
> Hallo all!
> I am trying to describe a constraint for a non-cyclic relation with OCL,
> therefor I need a recursive function, like this
> def: parents : Set = self.super->
> union (self.super ->collect ( p | p.parents()))
> inv: not self.parents() ->includes (self)
> But this does not work.
> Any suggestions? Can I write it so, as is, in EMF model?
> I'm using OCL 1.1M6 and EMF 2.3.0M6
> regards
> Andrej
Re: OCL function [message #21738 is a reply to message #21693] Thu, 03 May 2007 11:16 Go to previous messageGo to next message
Hi, Andrej,
You need to specify an element type for your collection type. e.g.,
def: parents : Set(Thing) = self.super->union(
self.super->collect(p | p.parents()))
inv: not self.parents()->includes(self)
Note, just for fun, that you can write this a little more succinctly:
def: parents : Set(Thing) = super->union(super.parents())
If the absence of an element type in your posting was just a typo, then
perhaps you are running into the following bug?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=176109
HTH,
Christian
Ed Merks wrote:
> Andrej,
> question.
> Andrej S wrote:
>> Hallo all!
>> regards
>> Andrej
Re: OCL function [message #21917 is a reply to message #21738] Mon, 07 May 2007 10:01 Go to previous messageGo to next message
Originally posted by: nospam74.gmx.net
Hi, Christian!
thanks for your answer. It was not a typo, in fact I forgot to declare
the type of set, but it does not work with type specification neither. I
get even for simply examples such as
def: n: String = 'test'
an error "Invalid OCL" ( I use interactive OCL console on dynamic instances)
Do I miss anything?
Christian W. Damus wrote:
> Hi, Andrej,
> HTH,
> Christian
Re: OCL function [message #21962 is a reply to message #21917] Mon, 07 May 2007 15:32 Go to previous messageGo to next message
Hi, Andrej,
The interactive OCL Console example (even the vastly improved version coming
in M7) currently does not support def: expressions. Nor, indeed, does it
support the context declaration syntax (including the "inv:" token).
In M2 (metamodel) mode, the console will parse all expressions as query
expressions. In M1 (model) mode, it will parse the expressions that you
type in as follows:
- when the selection is a classifier (Ecore EClassifier or UML CLassifier)
it parses the expression as an invariant constraint
- when the selection is an operation (EOperation or Operation), it parses
as a post-condition constraint
- when the selection is an attribute (EStructuralFeature or Property), it
parses as a derivation constraint
Note that, for parsing OCL from text files, I have just committed a fix for
in which constraints in the OCL document are, in fact, parsed in reverse
order, so that your def: expression would not have been processed when the
inv: constraint attempted to use it.
Christian
Andrej S wrote:
> Hi, Christian!
> instances)
> Do I miss anything?
>> Hi, Andrej,
>> HTH,
>> Christian
Re: OCL function [message #22097 is a reply to message #21962] Wed, 09 May 2007 07:44 Go to previous messageGo to next message
Hi!
Every def: expression is marked as invalid by validation in GMF mapping.
inv: n = 'test'
results in "Invalid expression body [...] Invalid OCL"
Is there another way to set OCL constraints?
greets
Andrej
> Hi, Andrej,
> type in as follows:
> Cheers,
> Christian
Re: OCL function [message #22187 is a reply to message #22097] Wed, 09 May 2007 08:26 Go to previous messageGo to next message
Hi, Andrej,
It would be better to ask that question on the GMF newsgroup (which I have
included in the To: list).
From the result, I would guess that GMF expects as input simply a
boolean-valued expression. However, it may be that GMF provides some means
to specify additional operations and attributes that I don't know about.
Christian
Andrej S wrote:
> Hi!
> inv: n = 'test'
> greets
> Andrej
>> Hi, Andrej,
>> coming
>> type in as follows:
>> CLassifier)
>> parses
>> it
>> for
>> the inv: constraint attempted to use it.
>> Cheers,
>> Christian
Re: OCL function [message #22337 is a reply to message #22187] Wed, 09 May 2007 12:14 Go to previous messageGo to next message
Hi Christian,
Right, looks like GMF related but I am not sure I fully understand
what Andrej has done.
Andrej,
could you please submit some more details or a test model which would
help me reproduce this problem?
/Radek
On Wed, 09 May 2007 14:26:54 +0200, Christian W. Damus <cdamus@ca.ibm.co=
m> =
wrote:
> Hi, Andrej,
> It would be better to ask that question on the GMF newsgroup (which I =
> have
> boolean-valued expression. However, it may be that GMF provides some =
> means
> to specify additional operations and attributes that I don't know abou=
t.
> Cheers,
> Christian
> Andrej S wrote:
>> Hi!
>> Every def: expression is marked as invalid by validation in GMF mappi=
ng.
>> def: n: String =3D 'test'
>> inv: n =3D 'test'
>> greets
>> Andrej
>>> Hi, Andrej,
>>> The interactive OCL Console example (even the vastly improved versio=
n
>>> coming
>>> in M7) currently does not support def: expressions. Nor, indeed, do=
es =
>>> it
>>> support the context declaration syntax (including the "inv:" token).=
>>> In M2 (metamodel) mode, the console will parse all expressions as qu=
ery
>>> expressions. In M1 (model) mode, it will parse the expressions that=
>>> you
>>> type in as follows:
>>> CLassifier)
>>> - when the selection is an operation (EOperation or Operation), it=
>>> parses
>>> - when the selection is an attribute (EStructuralFeature or =
>>> Property),
>>> it
>>> Note that, for parsing OCL from text files, I have just committed a =
fix
>>> for
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D176109
>>> in which constraints in the OCL document are, in fact, parsed in =
>>> reverse
>>> order, so that your def: expression would not have been processed wh=
en
>>> Cheers,
>>> Christian
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: OCL function [message #22776 is a reply to message #22337] Thu, 10 May 2007 04:37 Go to previous messageGo to next message
Hi, Radek!
I don't believe that my problem is GMF related, I tried it in EMF too.
I have model that includes inheritance relation, so I want to forbid
cyclic inheritance. For this purpose is a recursive function needed,
defined with "def:" keyword.
My problem is that "def:", however, does not work correctly.
Andrej
Radek Dvorak wrote:
> Hi Christian,
> Andrej,
> /Radek
Re: OCL function [message #22864 is a reply to message #22776] Thu, 10 May 2007 08:52 Go to previous message
Hi, Andrej,
The concrete syntax for context declarations (including the def, inv, etc.
keywords) is only supported by the OCL.parse(OCLInput) API. If you are
using the OCLHelper API, then you must supply only the OCL constraint or
body expression (depending on whether an invariant, precondition,
definition, etc.).
Which of these APIs is ultimately trying to parse your input?
Christian
Andrej S wrote:
> Hi, Radek!
> Regards
> Andrej
> Radek Dvorak wrote:
>> Hi Christian,
>> Andrej,
>> Regards,
>> /Radek
Previous Topic:three entries so far, and growing
Next Topic:OCL Models Regenerated -- Action for Extenders
Current Time: Tue Jul 22 20:11:07 EDT 2025
Powered by FUDForum. Page generated in 0.77728 seconds
