Home » Archived » Riena » [Ridgets] Support for EMFDatabinding
[Ridgets] Support for EMFDatabinding [message #21682] Tue, 17 February 2009 09:11 Go to next message
Probably I'm doing something wrong, but I declare a binding as follow:
IObservableValue emfObs = EMFEditObservables.observeValue(editingDomain,
getModelObject(),
MyEMFPackage.Literals.MYOBJ__MYEATT);
myTextRidget.bindToModel(emfObs);
myTextRidget.updateFromModel();
but this does not work, The #updateFromModel is executed and the value
is rendered in the text-field, but a UI-to-Model Update does not work.
EMF has a separate DataBindingContext with different
UpdateValueStrategies. Is it possible to use a EMFDataBindingContext (I
want the use the capabilities EMF.Edit provides)? -
I didn't see any possibility to override or extend to provide my own
databinding-context.
Thx for your help
Tom
Re: [Ridgets] Support for EMFDatabinding [message #21727 is a reply to message #21682] Tue, 17 February 2009 09:26 Go to previous messageGo to next message
If you rely on the default converters you need to use an
EMFDatabindingContext because EMFObservables report the structural
feature as the value-type.
If Riena doesn't allows you to set it you can work around by explicitly
setting an converter but that's far from ideal :-)
Tom
Tom Seidel schrieb:
> getModelObject(),
> Thx for your help
> Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Ridgets] Support for EMFDatabinding [message #21772 is a reply to message #21727] Tue, 17 February 2009 09:30 Go to previous messageGo to next message
Hi Tom,
> need to use an
that's exactly the problem. It seems to me I can not set this context.
Tom
Tom Schindl schrieb:
> Tom
> Tom Seidel schrieb:
>> getModelObject(),
>> Thx for your help
>> Tom
Re: [Ridgets] Support for EMFDatabinding [message #21815 is a reply to message #21772] Tue, 17 February 2009 10:04 Go to previous messageGo to next message
Tom Seidel schrieb:
> Hi Tom,
>> need to use an
This is one of the rare cases the DB creators failed a bit because the
Databinding-Context is not the appropriate location for this. It would
be better if I one could plug-in his/her own converters.
Something like:
------------8<------------
DatabindingContext dbc = ... ;
dbc.setConverterStrategy(....);
dbc.setValidatorStrategy(....);
There's a bug with a discussion about this problem and possible solution
but this won't get fixed in time of 3.5.
Tom
Re: [Ridgets] Support for EMFDatabinding [message #21950 is a reply to message #21815] Sun, 22 February 2009 07:56 Go to previous messageGo to next message
Maybe. But I'm wondering if this "failure" can't be workarounded by
Riena itself with providing some API for using my own DatabindingContext.
Any thoughts?
> Tom Seidel schrieb:
>> Hi Tom,
>>> need to use an
> Something like:
> Tom
Re: [Ridgets] Support for EMFDatabinding [message #21995 is a reply to message #21682] Mon, 23 February 2009 23:31 Go to previous message
Originally posted by: evolanakis.innoopract.com
Hi Tom,
- using your own DataBindingContext is not supported. Please file an
enhancement request so we can keep track of this.
http://www.eclipse.org/riena/bugs.php
- feel free to attach a standalone example (or projects) to that bug, so
we can experiment with your issue without spending lot of time with EMF.
- I know that other people on the newsgroup use EMF and Riena. Has this
been a problem, or how did you work around this?
Kind regards,
Elias.
Tom Seidel wrote:
> getModelObject(),
> Thx for your help
> Tom
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Re: [Ridgets] Support for EMFDatabinding [message #580683 is a reply to message #21682] Tue, 17 February 2009 09:26 Go to previous message
Tom
Tom Seidel schrieb:
> getModelObject(),
> Thx for your help
> Tom
Re: [Ridgets] Support for EMFDatabinding [message #580702 is a reply to message #21727] Tue, 17 February 2009 09:30 Go to previous message
Hi Tom,
> need to use an
Tom
> Tom
> Tom Seidel schrieb:
>> getModelObject(),
>> Thx for your help
>> Tom
Re: [Ridgets] Support for EMFDatabinding [message #580727 is a reply to message #21772] Tue, 17 February 2009 10:04 Go to previous message
Tom Seidel schrieb:
> Hi Tom,
>> need to use an
Something like:
Tom
Re: [Ridgets] Support for EMFDatabinding [message #580798 is a reply to message #21815] Sun, 22 February 2009 07:56 Go to previous message
Any thoughts?
> Tom Seidel schrieb:
>> Hi Tom,
>>> need to use an
> Something like:
> Tom
Re: [Ridgets] Support for EMFDatabinding [message #580820 is a reply to message #21682] Mon, 23 February 2009 23:31 Go to previous message
Hi Tom,
Kind regards,
Elias.
Tom Seidel wrote:
> getModelObject(),
> Thx for your help
> Tom
Elias Volanakis
Innoopract, Inc.
Previous Topic:[Ridgets] Support for EMFDatabinding
Next Topic:Riena BOF at Eclipse Con 2009
Current Time: Tue Jul 08 11:31:28 EDT 2025
Powered by FUDForum. Page generated in 0.05415 seconds
