Home » Language IDEs » ServerTools (WTP) » Why does completion work with a DTD, but not with a schema?
Why does completion work with a DTD, but not with a schema? [message #222550] Wed, 01 October 2008 22:40 Go to next message
Eclipse 3.3.2.
If I edit an XML file that's defined with a DTD, I can do completion on
element names. However, if it's instead defined with a schema, I don't
get any completion choices.
For instance, if I start with the following "faces-config.xml" file,
completion works fine:
<!DOCTYPE faces-config PUBLIC
"-//Sun Microsystems, Inc.//DTD JavaServer Faces Config 1.1//EN"
"http://java.sun.com/dtd/web-facesconfig_1_1.dtd">
<faces-config>
</faces-config>
However, if I instead use this:
<faces-config xmlns="http://java.sun.com/xml/ns/javaee"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/javaee
http://java.sun.com/xml/ns/javaee/web-facesconfig_1_2.xsd"
version="1.2">
</faces-config>
then attempts to do completion give me empty lists.
Am I missing something simple?
Re: Why does completion work with a DTD, but not with a schema? [message #222555 is a reply to message #222550] Thu, 02 October 2008 10:46 Go to previous messageGo to next message
Hi David,
Try going to the XML menu item and choose Reload Dependencies under that.
David M. Karr wrote:
> Eclipse 3.3.2.
> <faces-config>
> </faces-config>
> version="1.2">
> </faces-config>
Re: Why does completion work with a DTD, but not with a schema? [message #222557 is a reply to message #222555] Thu, 02 October 2008 11:41 Go to previous messageGo to next message
Nope. No dice. Nothing new happened. After executing "Reload
Dependencies", I entered "<man" in the body of my "faces-config" element
and pressed ctl-space, and it brought up a menu that listed "man", instead
of the several "managed-..." elements.
If this is SUPPOSED to work, then I guess I'll file a bug, after I try
this same scenario in a newer release.
Re: Why does completion work with a DTD, but not with a schema? [message #222558 is a reply to message #222557] Thu, 02 October 2008 11:51 Go to previous message
Ok, well, never mind on that. I just tried it on 3.4.1, and it works fine.
Previous Topic:Determining the client project of an EJB project from a plugin
Next Topic:Getting Server Runtime ClasspathEntry
Current Time: Fri Sep 05 15:39:30 EDT 2025
Powered by FUDForum. Page generated in 0.04075 seconds
