Home » Language IDEs » Java Development Tools (JDT) » Performance problem during debug of Swing application
Performance problem during debug of Swing application [message #222405] Wed, 18 January 2006 08:53 Go to next message
Originally posted by: gross.dig.de
I get serious performance and time problems, when debugging Swing
applications. Startup of application is awfully slow and when eventually
loaded, debugging is also slow.
Does anybody has similar experiences or any suggestions?
When running the Swing application through eclipse without debugging, it
shows regular behavior.
I'm using eclipse 3.1 (and also JDT 3.1) on a Windows XP SP2 2GB RAM,
Pentium 3,2GHz.
Thanks in advance
Re: Performance problem during debug of Swing application [message #222412 is a reply to message #222405] Wed, 18 January 2006 09:22 Go to previous messageGo to next message
Originally posted by: ifedorenko.rogers.com
What JRE do you use? Older VMs do not go too fast in debug mode, try
using a more recent version. SUN 1.5 is ok, IBM 1.4.2 with J9 JIT
compiler is even better.
Jens Gross wrote:
> Pentium 3,2GHz.
> Thanks in advance
Re: Performance problem during debug of Swing application [message #222418 is a reply to message #222412] Wed, 18 January 2006 09:39 Go to previous message
I'm using Sun JRE 1.5 Update 3.
> Jens Gross wrote:
>> eventually loaded, debugging is also slow.
>> it shows regular behavior.
>> Pentium 3,2GHz.
>> Thanks in advance
Previous Topic:Quick Fix Question
Next Topic:Reading java project
Current Time: Sun Jul 27 11:10:28 EDT 2025
Powered by FUDForum. Page generated in 1.04418 seconds
