Folding in java classes [message #21665] |
Sun, 12 August 2007 03:36  |
I actually don't like the folding of Java method implementations, and the
default short cut key to unfold (CTRL-Num Pad *) is hard to reach and to
remember. I have enabled folding for header comments and imports, but not
for members, but everything still seems to be folded by default (I assume
Mylyn is responsible for this). Can I switch it off?
Re: Folding in java classes [message #26027 is a reply to message #24129] |
Thu, 06 September 2007 17:51  |
Originally posted by: beatmik.acm.org
Yes, the annotations being hidden by folding is an annoying problem with
the Eclipse text editor, even without Mylyn. The more folding that's
happening, the worse it is, which is why Mylyn exacerbates this problem.
Please consider voting for the corresponding Platform/Text bug and
commenting about the problem you are experiencing:
63692: [projection] Annotations in folded region are not rendered in
overview ruler
https://bugs.eclipse.org/bugs/show_bug.cgi?id=63692
Mik
Dave Syer wrote:
> I think that works. But I still don't like filding because I use the "Mark
> Occurrences" feature of the Java editor quite a lot and it doesn't mark any
> occurrences in folded elements. I would say it is a problem with the editor
> not with Mylyn, but while it doesn't work, Mylyn (because it prefers
> folding) is in the firing line.
Re: Folding in java classes [message #577206 is a reply to message #21665] |
Thu, 16 August 2007 21:06  |
There should be a button in the workbench toolbar that looks similar to
the focus on Workweek button in the Task List. That button
enables/disables auto folding in the editors.
-Rob
Re: Folding in java classes [message #577554 is a reply to message #22111] |
Sat, 18 August 2007 12:35  |
Stupid question: what's the workbench toolbar?
"Robert Elves" <rob.elves@eclipse.org> wrote in message
news:fa2sba$crr$1@build.eclipse.org...
> -Rob
>> not for members, but everything still seems to be folded by default (I
>> assume Mylyn is responsible for this). Can I switch it off?
Re: Folding in java classes [message #577768 is a reply to message #22859] |
Mon, 20 August 2007 14:22  |
The workbench toolbar or window toolbar are the buttons located just
below the File, Edit.... menu. When you have a source editor open the
folding button should be visible in the workbench window toolbar.
-Rob
>> -Rob
Re: Folding in java classes [message #577906 is a reply to message #23126] |
Mon, 20 August 2007 17:38  |
Awesome, thanks.
news:facm4k$83v$1@build.eclipse.org...
> The workbench toolbar or window toolbar are the buttons located just below
> the File, Edit.... menu. When you have a source editor open the folding
> -Rob
>>> -Rob
>>>> the default short cut key to unfold (CTRL-Num Pad *) is hard to reach
>>>> and to remember. I have enabled folding for header comments and
>>>> imports, but not for members, but everything still seems to be folded
>>>> by default (I assume Mylyn is responsible for this). Can I switch it
>>>> off?
Re: Folding in java classes [message #578304 is a reply to message #21665] |
Mon, 27 August 2007 01:26  |
David: note that if the active folding is working properly you should
never need to manually unfold, because as soon as you click on the
method signature it will unfold for you. If this is not the case please
file a bug.
Mik
Re: Folding in java classes [message #578465 is a reply to message #23780] |
Mon, 27 August 2007 11:57  |
"Mik Kersten" <beatmik@acm.org> wrote in message
news:fatn9n$h9h$1@build.eclipse.org...
> never need to manually unfold, because as soon as you click on the method
> signature it will unfold for you. If this is not the case please file a
> bug.
> Cheers,
> Mik
Re: Folding in java classes [message #579884 is a reply to message #24129] |
overview ruler
Mik
FUDForum. Page generated in 0.05785 seconds
