Exception in thread "WorkbenchTestable" [message #21605] |
Thu, 12 February 2009 16:13  |
I am new to SWTBot. I just got it up and running on my environment a
couple of days ago. However, when I try to execute the sample SWTBot Test
for eclipse plugins from the user's guide, it gives me the following
error, after the eclipse workbench gets launched:
Exception in thread "WorkbenchTestable" java.lang.NoClassDefFoundError:
net.sf.swtbot.eclipse.finder.SWTBotEclipseTestCase
at java.lang.ClassLoader.defineClassImpl(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:228)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:165)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:554)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:524)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:455)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:443)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:423)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:573)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r$BundleClassLoader.findClass(RemotePluginTestRunner.java:38 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:607)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lass(RemoteTestRunner.java:683)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lasses(RemoteTestRunner.java:425)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:445)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:62)
net.sf.swtbot.eclipse.ui.TestApplication.runTests(TestApplic ation.java:112)
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
at java.lang.Thread.run(Thread.java:801)
My classpath includes the following classes for swtbot:
C:\swtbotbm\net.sf.swtbot.finder_1.2.0.921.jar;C:\swtbotbm\o rg.apache.commons.collections_3.2.0.v200803061811.jar;C:\swt botbm\org.apache.log4j_1.2.13.v200806030600.jar;C:\swtbotbm\ net.sf.swtbot.eclipse.finder_1.2.0.921.jar;C:\swtbotbm\org.e clipse.swt.win32.win32.x86_3.3.0.v3346.jar
I would be extremely glad if I get any help to get this problem solved.
Bhooshan.
Re: Exception in thread "WorkbenchTestable" [message #24131 is a reply to message #23798] |
Tue, 24 February 2009 23:04  |
Bhooshan Mogal wrote:
> Hi folks,
> Sorry for the delay in responding. I managed to get swtbot to run with the
> eclipse environment on my machine over the last week using some local
> help. I also managed to write some testcases and it is working just fine.
Can you please help on how to execute an SWTBot testcase?
> Thanks a lot for the help.
> I am trying to use SWTBot to automate our products installer. The
> installer is built on eclipse/swt (The name of the installer is IBM
> Installation Manager), so I would think SWTBot supports it. However, I am
> not sure how to set up and run the application so it can be automated.
> The SWTBot docs say to launch the Main() method in it's own thread, but we
> have no access to the source code.. I only have the .exe. Am I supposed
> to launch it using Java Runtime/Java Process? Any advice would be very
> helpful.
> Bhooshan
FUDForum. Page generated in 0.34113 seconds
