Home » Eclipse Projects » GEF » SWTError: No more handles
SWTError: No more handles [message #21577] Thu, 26 September 2002 22:03 Go to next message
Originally posted by: julien.omondo.com
I have a question about draw2D. I don\'t if it belong to this group or to
eclipse.tools.
We run into another problem with Image which is hold in draw2d.Label. In
our UML Plugin, if we create a huge diagram, we got the following error:
at org.eclipse.swt.SWT.error(SWT.java:2144)
at org.eclipse.swt.SWT.error(SWT.java:2051)
at org.eclipse.swt.graphics.Image.internal_new_GC(Image.java:18 48)
at org.eclipse.swt.graphics.GC.<init>(GC.java:70)
com.ibm.etools.draw2d.BufferedGraphicsSource.getGraphics(Buf feredGraphicsSource.java:63)
com.ibm.etools.draw2d.DeferredUpdateManager.getGraphics(Defe rredUpdateManager.java:68)
com.ibm.etools.draw2d.DeferredUpdateManager.repairDamage(Def erredUpdateManager.java:133)
com.ibm.etools.draw2d.DeferredUpdateManager.performUpdate(De ferredUpdateManager.java:92)
com.ibm.etools.draw2d.DeferredUpdateManager.performUpdate(De ferredUpdateManager.java:82)
com.ibm.etools.draw2d.LightweightSystem.paint(LightweightSys tem.java:167)
com.ibm.etools.draw2d.LightweightSystem$2.handleEvent(Lightw eightSystem.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:66 5)
We have followed the article \"Using Images in the Eclipse UI\" and using
shared image. When I trace the ImagerRegister\'s counter, I used only
about 30 images. I cannot figure out what is wrong ? Can someone help me ?
Julien
Re: SWTError: No more handles [message #21894 is a reply to message #21577] Fri, 27 September 2002 11:44 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
Do you have a large diagram and the overview window?
Use the latest drop. It fixes this problem.
"Julien" <julien@omondo.com> wrote in message
news:an0ea2$mbt$1@rogue.oti.com...
> eclipse.tools.
> at
rce.java:63)
> at
r.java:68)
> at
er.java:133)
> at
ger.java:92)
> at
ger.java:82)
> at
> at
:89)
> Julien
Re: SWTError: No more handles [message #22112 is a reply to message #21894] Fri, 27 September 2002 15:21 Go to previous messageGo to next message
You means last version of GEF ?
Julien
> > eclipse.tools.
> > at
> rce.java:63)
> > at
> r.java:68)
> > at
> er.java:133)
> > at
> ger.java:92)
> > at
> ger.java:82)
> > at
> > at
> :89)
> > Julien
Re: SWTError: No more handles [message #22156 is a reply to message #22112] Fri, 27 September 2002 16:00 Go to previous messageGo to next message
Yes, he's talking about GEF. The overview was causing this exception if the
diagram was very large. The newest GEF drop includes the fix.
Eric
> Julien
>>>eclipse.tools.
>>>at
>>rce.java:63)
>>>at
>>r.java:68)
>>>at
>>er.java:133)
>>>at
>>ger.java:92)
>>>at
>>ger.java:82)
>>>at
>>>at
>>:89)
>>>Julien
Re: SWTError: No more handles [message #22199 is a reply to message #22156] Fri, 27 September 2002 19:15 Go to previous messageGo to next message
> Eric
I just passed to GEF 20020821. Nothing changed. The Eclipse crash after I
minimize a class and then maximize the class to display all members in the
case I have a huge diagram. It seems that problem is relative with the
Label deleting. Is it helpfull to remove "Overview" thumbnail ?
Julien
> > Julien
> >>>eclipse.tools.
> >>>at
> >>rce.java:63)
> >>>at
> >>r.java:68)
> >>>at
> >>er.java:133)
> >>>at
> >>ger.java:92)
> >>>at
> >>ger.java:82)
> >>>at
> >>>at
> >>:89)
> >>>Julien
Re: SWTError: No more handles [message #22379 is a reply to message #22199] Sat, 28 September 2002 18:49 Go to previous messageGo to next message
It is probably a different exception, please post the .log stacktrace.
Re: SWTError: No more handles [message #22719 is a reply to message #22379] Tue, 01 October 2002 19:33 Go to previous messageGo to next message
> > Label deleting. Is it helpfull to remove \"Overview\" thumbnail ?
Here you are:
org.eclipse.swt.SWTError: No more handles
org.eclipse.draw2d.BufferedGraphicsSource.getGraphics(Buffer edGraphicsSource.java:63)
org.eclipse.draw2d.DeferredUpdateManager.getGraphics(Deferre dUpdateManager.java:68)
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:133)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:92)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:82)
at org.eclipse.draw2d.LightweightSystem.paint(LightweightSystem .java:171)
org.eclipse.draw2d.LightweightSystem$2.handleEvent(Lightweig htSystem.java:93)
Il seems to us the culprit is the call
GraphicalViewerImpl.setcontent(null) to force the total update in the
disgram.
Julien
Re: SWTError: No more handles [message #22805 is a reply to message #22719] Wed, 02 October 2002 09:49 Go to previous message
It sounds like you are leaking GCs. Try to find a place where you new a GC
and don't dispose it.
There is an SWT tool to help you track resource leaks. See the SWT article
on managing resources.
"julien" <julien@omondo.com> wrote in message
news:andbbk$ldp$1@rogue.oti.com...
after I
the
> Here you are:
> at
..java:63)
> at
ava:68)
> at
java:133)
> at
..java:92)
> at
..java:82)
> at
> disgram.
> Julien
Previous Topic:Dumb's man guide to porting GEF 2.0 application to GEF 1.0 / WSAD 4.0.3
Next Topic:Delete
Current Time: Mon Sep 01 00:34:31 EDT 2025
Powered by FUDForum. Page generated in 0.03303 seconds
