Breakpoints in "action" scripts [message #21557] |
Thu, 17 May 2007 17:05  |
Originally posted by: dserodio.gmail.com
Thanks to the excellent documentation at
http://www.thierryb.net/pdtwiki/index.php?title=PDT_User_Gui de I managed
to create a breakpoint on my "index.php" page, and the execution
actually stopped at this breakpoint.
Now, I need to set a breakpoint on a page which processes the form
submission, ie the 'process.php' in '<form action="process.php">'.
How can I make the execution stop at this breakpoint?
Daniel Serodio
Re: Breakpoints in "action" scripts [message #21958 is a reply to message #21644] |
Fri, 18 May 2007 09:11   |
> It should stop there if you set the breakpoint in some php block inside
> the process.php file. If it’s mixed html and php and you try to set a
> breakpoint into a line where no php is found, the breakpoint is set to
> the next available php line. Does that help you?
The problem is that I need to set a breakpoint in process.php, and start
the request in index.php.
If I choose "Debug As > PHP Web Page" in process.php, it opens
process.php in the Web Browser.
If I choose "Debug As > PHP Web Page" in index.php, it opens index.php
in the browser and then the debugger session ends.
I need it to open index.php in the browser, so I can fill the form and
then submit to process.php, where the breakpoint is.
Daniel Serodio
Re: Breakpoints in "action" scripts [message #24520 is a reply to message #22625] |
Tue, 29 May 2007 14:45  |
Originally posted by: Darnell.Turner.gmx.net
> But these parameters won't be sent to process.php, so if debugging
> depends on them, how could process.php "know" that it must run in debug
> mode?
By the session cookie in your browser.
> Also, this "send_sess_end=1" seems suspicious, it sounds like it's
> asking to end the debugging session.
Well, does it? What if you just call it manually and omit that part?
Could it be that you have some security software running that kills
sessions or cookies?
-dT
FUDForum. Page generated in 0.03356 seconds
