download which eclipse? [message #221495] |
Sat, 14 July 2007 22:06 |
Originally posted by: lsloan-eclipseusenet.umich.edu
A very newbie question:
I find the Eclipse download page (http://www.eclipse.org/downloads/) to be
confusing. I will be developing JSE and JEE apps. I can see the strong
possibility that I might need to work with C++ as well. Do I need to
download those three different Eclipse packages to get all of that
functionality?
Thanks in advance. Please respond to my email address as well as the
newsgroup.
Re: download which eclipse? [message #221577 is a reply to message #221495] |
Mon, 16 July 2007 00:09 |
> be confusing. I will be developing JSE and JEE apps. I can see the
> strong possibility that I might need to work with C++ as well. Do I
> need to download those three different Eclipse packages to get all of
> that functionality?
If you click the "Find out more..." link under one of the packages,
you'll find a link on that page called "Adding Features from the Europa
Discovery Site"
That is a short screencast that demonstrates how easy it is to add
additional features once you have a base Eclipse installed.
Hope this helps,
Eric
Re: download which eclipse? [message #221723 is a reply to message #221529] |
Mon, 16 July 2007 13:43 |
Oh, I see. So what about "Eclipse Classic"? It's a pretty big download,
larger than everything else except for the "RCP" package. Does Classic
include several of the other packages?
J Michael Dean wrote:
> These are just convenience packages. You can always add any component in
> Eclipse later. You should probably load the one closest to your JEEE needs,
> and then go to update and add the C stuff.
Re: download which eclipse? [message #221754 is a reply to message #221723] |
Mon, 16 July 2007 16:58 |
> download, larger than everything else except for the "RCP" package.
> Does Classic include several of the other packages?
Right on the downloads page under the Eclipse Classic heading, it says:
"The classic Eclipse download: the Eclipse Platform, Java Development
Tools, and Plug-in Development Environment, including source and both
user and programmer documentation."
Along with a link "Find our more..."
Eric
FUDForum. Page generated in 0.09103 seconds
