Home » Eclipse Projects » Nebula » Grid, GridViewer, large data sets
Grid, GridViewer, large data sets [message #21525] Fri, 29 December 2006 23:03 Go to next message
How does the Grid/GridViewer handle large data sets in terms of
performance? An SWT VIRTUAL table handles large data sets very nicely,
but I have run into problems with VIRTUAL support in the TableViewer
API, particularly with the DeferredContentProvider. If the Grid scales
well for large data sets, I'd like to consider replacing some
Table/TableViewer code because the Grid otherwise provides some features
that I'd like to utilize.
- John
Re: Grid, GridViewer, large data sets [message #21929 is a reply to message #21525] Thu, 04 January 2007 11:22 Go to previous message
Hi John,
Hope life's treatin you well.
The Grid handles larger datasets moderately better than the normal Table
(on Win anyway), but when you start to get into the tens of thousands
you will see a significant slow down during population. Once the grid
is populated, the performance should be fine. The Table + SWT.VIRTUAL
will perform better. I do plan on implementing a virtual mode for Grid
as well.
The Grid will not be a panacea for large datasets. I think you should
go back to the business 'experts' who believe a user can really do much
with so many records ;)
-Chris
> - John
Re: Grid, GridViewer, large data sets [message #573772 is a reply to message #21525] Thu, 04 January 2007 11:22 Go to previous message
Hi John,
as well.
-Chris
> - John
Previous Topic:Maximize problem
Next Topic:Grid Item Height
Current Time: Sat Jul 26 10:35:39 EDT 2025
Powered by FUDForum. Page generated in 0.03625 seconds
